Arborwear
Author Topic: a couple questions about sealing logs  (Read 746 times)
Offline sawyer2015
« on: February 02, 2015, 07:10:22 PM »
Ok so am I supposed to use a different kind of sealer for different species? or can I just spray paint the end of all logs with cheap black spray paint. give me some suggestions...thanks
mj
Offline beenthere
Re: a couple questions about sealing logs
« Reply #1 on: February 02, 2015, 08:06:21 PM »
By starting a new thread, can't tell from where you got the idea of a different sealer for different species.
So:
One sealer.. Anchorseal
Use for all species if you want to impede some end checking. It isn't essential to end seal logs. Just sometimes prudent depending on what you are looking for out of the logs.
Paint will obscure the end grain when sawing the logs. Not recommended but may do in a pinch.
Offline sawyer2015
« Reply #2 on: February 02, 2015, 08:21:48 PM »
ok I don't have anchorseal now so I put some clear poly on the ends. sometimes my questions sound dumb but ask them because I am curious and want to learn. thanks for the advice.
mj
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #3 on: February 02, 2015, 08:46:50 PM »
Paint is not worthless as a end sealer for logs, just close.  Invest in some anchorseal.  Poly might be better than paint, but anchorseal is cheaper than poly and much, much better.
Offline sawyer2015
« Reply #4 on: February 02, 2015, 08:55:13 PM »
definitely will do
mj
Online YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #5 on: February 02, 2015, 09:39:04 PM »
Anchorseal is number one in my book, I won't cut the end off a log unless the paint brush is next to the chainsaw.
YH
HobbyHardwoodAlabama.com
Hi All Starting Band Mill Build Couple Questions OKAY more than a couple
Started by biggkidd on Sawmills and Milling
Last post August 01, 2014, 11:56:25 PM
by biggkidd
sealing between logs
Started by bic on Timber Framing/Log construction
Last post April 03, 2014, 12:20:49 PM
by Lakeerieloghomes
End-sealing logs
Started by yieldmap on Sawmills and Milling
Last post December 03, 2005, 10:26:55 PM
by dutchman
Sealing Logs
Started by Rookie on Drying and Processing
Last post November 28, 2004, 02:54:31 PM
by AtLast
