Arborwear
Author Topic: Shed For Woodmizer Finally (pics)  (Read 2644 times)
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« on: February 06, 2015, 10:57:53 AM »
Finally got my building dried in. Starting to wire it.Woodmizer will have a home & I wont have to saw in the elements.Need some pics of you guys dust collectors.Dont want to have tons of sawdust under the Shed ??? ???
Offline Jemclimber
Re: Shed For Woodmizer Finally (pics)
« Reply #1 on: February 06, 2015, 11:05:58 AM »
Looks nice, what are the dimensions?
lt15
Offline Percy
  • Resident trouble maker
« Reply #2 on: February 06, 2015, 11:06:27 AM »
Awesome building......you aint foolin around...
Offline EZ
  • Betya can't cut just one!
« Reply #3 on: February 06, 2015, 11:09:25 AM »
Now that's one heck of a shed. Good job dude.
Offline GAB
« Reply #4 on: February 06, 2015, 11:16:04 AM »
Woodweasel:
Looking at your roof line it appears you are not worried about 3" of ice on top of 2' of wet heavy snow.
Nice looking building though.
Gerald
Offline woodweasel
« Reply #5 on: February 06, 2015, 11:51:05 AM »
It's 42'x50',also have a 8'x12' on the back side that will be the head, (commode,urinal, tub, h20 heater) 30'x50' is inclosed. The shed is 12'x50'.The 30'x50' is insulated, the 12'x50' shed is insulated with a heat reflecting barrier to ward off the Texas sun! Peak is 16',slopes to15'. No I'm not worried about snow and ice.I'm in Central Texas, most snow I've seen has been 4''-6'' tops. It usually melts the next day.Wiring it under ground from transformer to a 200 amp box in building. Will have office/mancave with possible sleeping qtrs. upstairs. need some ideals on the dust collectors. also I basically did the entire project myself, I did have a concrete man set the anchor bolts  and spread and level slab. I've never done this so I made mistakes along the way smiley_turkey_dancing. HELP ON DUST COLLECTORS PLEASE ???
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: February 06, 2015, 12:39:10 PM »
Real nice sawshed you've got there!   smiley_thumbsup    smiley_thumbsup
~Chuck~
I LOVE MY SAWMILL
Offline Joe Hillmann
« Reply #7 on: February 06, 2015, 01:06:24 PM »
Woodweasel:
Gerald
I think a lot of us in the north get kind of aggravated (maybe a little bit jealous too) when we see what you guys can get away with in the south when building sheds when it comes to planing for snow.
Online pineywoods
« Reply #8 on: February 06, 2015, 01:14:25 PM »
Here's my sawdust collection system. Blower is a 2 hp 110 unit from a harbor freight shop dust collector. The metal pipe is six inch stove pipe from the hardware store. There are 3 swivel joints, home-made brazed up from sheet metal. Jug on the pole is an infinitely adjustable hi-tech counterbalance, just add or delete water.  ;D The curved outlet on the sawdust chute is pop riveted sheet metal. It handles the mess from a wm lt40 nicely, but I do have to occasionally scrape the bark and debris from under the mill.
Online POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #9 on: February 06, 2015, 03:50:09 PM »
Top shelf there Woodweasel.....nice and I mean NICE shed.  :)
Where's the Spoon?
Offline woodweasel
« Reply #10 on: February 06, 2015, 06:28:28 PM »
Pineywoods,  Thats what I'm looking for!! So the blower is in the rafters, with a swivel on it? Also what
is the counterbalance for? Do the swivels bind up witout it ???
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #11 on: February 06, 2015, 09:00:31 PM »
That's a Pineywoods semi-automatic-infinitley-adjustable-low-budget-anti-cantilever-oil jug. :)
Online pineywoods
« Reply #12 on: February 06, 2015, 10:05:48 PM »
Yeah, the blower is in the rafters, inlet pointed down with swivel attached to the inlet. Idea is to get all the plumbing above head height and out of the way. Without the counterbalance, the swivel tends to bind. There is a small cable wrapped around the blower swivel, then routed over a pulley, then down to an old window weight. Makes the whole assemley rotate in the right direction...Only problem I have is the short pieces of flex hose tend to split and break after lots of use.  Duct tape.....There's a post somewhere on how to make the swivels....
Offline woodweasel
« Reply #13 on: February 06, 2015, 10:23:57 PM »
Pineywoods,that's awsome!Did you get the lengths of the pipe and where the swivels needed to be located by trial and error or what??
Online thecfarm
« Reply #14 on: February 07, 2015, 06:08:43 AM »
You sure will enjoy that!!
Online pineywoods
« Reply #15 on: February 07, 2015, 10:53:47 AM »
Yup, how else do rednecks engineer things?? I used a mockup made of 1X2 strips to get in the ball park. The flex hoses were originally a little longer, when one splits, I just shorten the hose  ;D
Offline woodweasel
« Reply #16 on: February 07, 2015, 08:34:03 PM »
Thanks pineywoods, If you remember anything that may help me with the dust collector please post. Sure would like to the others similar to yours. I've started a mock-up based on your system!! Thanks smiley_beertoast
Finally got my saw shed built
Started by oakiemac on Sawmills and Milling
Last post January 20, 2010, 06:08:36 PM
by oakiemac
Mill Shed Finally Done
Started by tgalbraith on Sawmills and Milling
Last post June 04, 2013, 07:41:42 AM
by tgalbraith
Mill Shed - Finally
Started by ncsawyer on Sawmills and Milling
Last post October 22, 2015, 08:07:20 PM
by ncsawyer
Finally starting my sawmill shed.
Started by ForestMan on Sawmills and Milling
Last post December 23, 2010, 10:42:48 PM
by ForestMan
