AVAILABLE
Author Topic: Dovetail Log Cabin  (Read 14013 times)
Offline fred in montana
    • log dovetail jig plans
Dovetail Log Cabin
« on: February 07, 2015, 08:22:35 AM »
Here are some photos of a cabin I built a couple of years ago. The one we will build during the workshop in June will be a similar size. There are details about the workshop in the services category.
In this first picture you can see the wavy edge. I moved the saw head up and down as I went along cutting the top and bottom edges of the log. This way the chink joints were not all a constant width. I think it looks less manufactured this way.
woodmizer lt15, mf 65 tractor
logdovetailjig.com
Re: Dovetail Log Cabin
« Reply #1 on: February 07, 2015, 08:24:18 AM »
logdovetailjig.com
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #2 on: February 07, 2015, 08:26:40 AM »
Love it.  There is a very nice, and considerably larger dovetail cabin just around the corner from our place. I admire it every time I go by.
« Reply #3 on: February 07, 2015, 08:31:01 AM »
logdovetailjig.com
Offline tule peak timber
  • roborob
    • tule peak timber
« Reply #4 on: February 07, 2015, 08:59:25 AM »
WOW, cute as heck.....Rob
Online beenthere
« Reply #5 on: February 07, 2015, 09:54:57 AM »
Looks cozy, and a welcome camp to come back to after a hike or a hunt.
You should treat yourself to a Logrite cant hook to replace the wood handled one shown. You won't regret it, and the 30" model would be real handy for logs around the mill and the cabin build. Just sayin...
Offline justallan1
  • living and learning
« Reply #6 on: February 07, 2015, 02:47:18 PM »
That's my next dream. Possibly a bit bigger.
Allan
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: February 08, 2015, 10:25:05 PM »
I love it.  A log cabin bunkhouse is in my dreams.  Hopefully these ole bones will allow me to fulfill that dream.  I looked at trees yesterday.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #8 on: February 09, 2015, 08:08:33 AM »
I like it, But to move the blade up and down to get the [look] Why not use a dull blade, Or did you? :D
« Reply #9 on: February 09, 2015, 08:24:50 PM »
The idea with moving the blade up and down was to vary the vertical dimension.
logdovetailjig.com
Online beenthere
« Reply #10 on: February 09, 2015, 09:13:26 PM »
Seems the same effect could be gained by just randomly easing off some of the corners with a draw knife, and not compromise the fit between "logs" with a wavy pattern.
« Reply #11 on: February 10, 2015, 08:07:38 PM »
I think the draw knife would work too.
logdovetailjig.com
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #12 on: February 12, 2015, 10:45:01 AM »
Is there a way to create the dove tails and have the logs flat against each other, with no chinking space?  I'm having to do some serious rethinking on the cabin I want to build due to the building inspectors requirements.  I have about 180 8-9" average diameter 8ft logs on site. I could build conventional horizontal log. I'd like to flatten the logs on two sides with the woodmizer, and use flat foam compressed between them and log screws to hold them together. Can you still do that with a dove tail corner?
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #13 on: February 12, 2015, 11:24:52 AM »
The short answer is "YES", you can.  You just have to be very accurate with your joinery, cutting the dovetails.  A close friend of mine built his cabin this way in Idaho, and he routed spline grooves between each log for a 1" thick spline.  This spline acts as an alignment aid, as well as keeping the "outside" outside.  He insulated between each layer and over the spline with foam rolled insulation.  The cabin is beautiful, and pretty efficient, too.
Being a professional woodworker, and not a log builder, he took his time, and cut the dovetails by hand with a hand saw, not a chainsaw.  I am personally in awe of seeing dovetails cut accurately with a chainsaw.  I do not think of a chainsaw as an accurate joinery tool, but there are those who are great with one.  I'm more of a handtool guy.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline 1938farmall
  • Uff-da
« Reply #14 on: February 12, 2015, 11:46:19 AM »
seems like you could save yourself endless heartache by just using a simple "butt & pass" corner with foam & logscrews.
aka oldnorskie
Online Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #15 on: February 12, 2015, 02:18:55 PM »
I totally agree. Problem is I have to conform to materials and methods the county inspector will allow. I would much rather do butt and pass as I understand the joint and it would be much easier for me.
Offline cbla
« Reply #16 on: February 12, 2015, 07:16:08 PM »
fred in montana that looks amazing!
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #17 on: February 12, 2015, 07:43:10 PM »
Here is a LINK to Fred's website discussing chink gap size.
I mentioned to him in a PM about using " and he said OK.  My plan is to use 6X8 Red Oak.
« Reply #18 on: February 13, 2015, 09:21:10 PM »
About 25% of my customers build with zero gap. Some even use factory milled logs having a tongue and groove.
When using any dovetail jig, every cut is precise so it works fine.
logdovetailjig.com
« Reply #19 on: February 13, 2015, 09:40:30 PM »
logdovetailjig.com
Dovetail Log Cabin Help
Started by ehewitt05 on Timber Framing/Log construction
Last post February 16, 2018, 02:59:42 PM
by ehewitt05
Dovetail log cabin repairs
Started by stickframer on Timber Framing/Log construction
Last post April 23, 2018, 07:17:31 AM
by Don P
compound dovetail log cabin
Started by james on Timber Framing/Log construction
Last post December 16, 2004, 02:13:34 AM
by Anthony
Buiilding another dovetail notched log cabin shell 18'x18'
Started by fred in montana on Timber Framing/Log construction
Last post May 15, 2011, 08:13:38 PM
by Stephen1
