cummins 6bt problem
Started by sshier, February 14, 2015, 09:54:29 PM
sshier
Well this all started off Monday when during warm up the deere in my loader cracked the head and spun a bearing. so started the fun a week of pulling motors and fabrication. finally got our new motor a cummins 6bt in and all ready to go. bleed the injectors and bang she was off and running ran about 45 to 60 seconds and bang sounded like a back fire blew the oil fill plug and the motor quit. thought maybe the blow bye vent was plugged and built pressure but it was clear any thoughts thinking possibly a head gasket or stuck exaust valve engine hasn't been run in a year but ran out fine then.
coxy
don't have any idea  but that really sucks
UN Hooker
   If the fill plug is in the valve cover, pull the cover and look - something may have broken (valve stem, rocker, pushrod etc.) and knocked the fill plug out.  If the crankcase gets over pressured on a Cummins, it usually blows the tappet cover gasket out behind the injection pump first.
         UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
sshier
Fill plug is on injection pump s idea below the pump
hubel458
Engine setting valve may have stuck open , pounded on piston.
hole in piston or stuck shut, then let loose, keepers loose
valve become free, then dropped down,  hole in piston.
Bad week you got. Ed
sshier
Never heard of that but I guess it could happen going to pull head on Monday should be able to get a idea then any more ideas are welcome thanks
barbender
Corley5
hubel458
We almost had same happen.  Rolled over a new engine, that set for
years and wouldn't start and it went clunk no more turn. Took off cover
and valve stuck down. Got valve free, rolled over ok with cover off to
be sure they all were working. A 4 cylinder but it still wouldn't start..
It had the opposed little cam operated piston in top  of injector pump
and they were set up closed, replaced them it started, run like a top.ED
snowstorm
didnt they problems with some of the older 5.9 with a dowel pin coming out and getting into the timing gears. several yrs ago i heard of a dodge pickup doing that
LeeB
sshier
Good news finally valve was stuck closed no damage done engine is running lIke a song thanks everyone
rockwall
Corley5
LeeB
Glad to hear the Cummins didn't let you down.
barbender
Right on 8) Glad to hear it ;)
On the dowel pin, I have been around b series Cummins engines my entire working career, and I have never seen or heard of this problem except on the internet. I'm not saying it doesn't happen, just that it isn't as common as some internet sites would leave you to believe. I had a guy that was on my case, he just couldn't believe that I was driving around in my Dodge/Cummins without having fixed the "killer dowel pin" (KDP) :o I told him it had made it 250K already, if it was going to fall out it would have done it already.
Decked
I bought a new Dodge/cummins in 1990 ( back when things were good!). I ran it 17 years, it had 314K when I put her to sleep. The engine was never looked at..but the rest of the truck finally rotted out. i actually teared up when they put it on the tilt bed :'(
snowstorm
Quote from: barbender on February 17, 2015, 08:12:40 AM
i know someone that had that happen
lopet
Quote from: Decked on February 17, 2015, 09:58:05 AM
Mine was a 90 as well ( only 3rd owner ). At 425000 I quit putting money in to it and parked it. Still have it, I know it's a bad habit , not throwing stuff away  ;D  Pulled the motor and it's sitting on a skid and waiting for somebody doing something with it. Pretty darn good motors for that time, but having said that, it really never had to work that hard in a 3/4 ton.
Driving a 98 now with 24 valves, so far so good.
eichenberg93
about 6 months ago I had the cummins in my 92 come to a stop real quick going down the freeway at 70. it was not the dowel pin but had the same result. after 200,000 miles a bolt came out that holds the timing case on right above the cam :o so after replacing the cam, pushrods, and a couple of gears I can say that geartrain related issues are possible every once and a while ;)
barbender
I'm not doubting it happens, to be clear ;) I might be responding to some of the guys I've come across that act like driving my truck without fixing the dowel pin is like running it without oil ::) Those dowel pins do come loose sometimes, but I think it is pretty rare.
