Author Topic: thoughts on wallenstein firewood processor  (Read 8398 times)
Offline lopet
  • Do not climb any higher your comportable falling !
Re: thoughts on wallenstein firewood processor
« Reply #20 on: March 25, 2015, 07:34:47 PM »
local firewood delivery service $200 a cord, delivered, and stacked,
You have one heck of a deal. :o :o
Offline Ford_man
« Reply #21 on: March 25, 2015, 08:32:49 PM »
I like my Dayna a lot, I looked at the 12 when i was at the factory and they looked kind of small, I did see a log loading setup so you did not need a loader. When I ordered mine I got the feed trough 10 ft longer so i could handle longer logs, I have had 40 ft logs on it, I also looked at the Dyna 16 but decided on the 14 for price. I had a problem with a valve when I first got it and called them .they sent a new valve i had it the next day before noon. there ph no is on the decals on the machine.
Offline sawyerf250
« Reply #22 on: March 25, 2015, 09:16:14 PM »
@landscraper  What kinda processor are you going to run all lovely mess through? :D Just kidding that's not far from the kinda stuff I would be running through mine I acquire one..  ???
Massey Ferguson 375 w/838 loader, Wallenstien Fx 90 winch, 3 Husqvarna chainsaws
Offline landscraper
  • LT4H0DD47. Dyna SC14. Hudson Stake Sharpener.
« Reply #23 on: March 25, 2015, 09:36:32 PM »
Not ALL those logs are going to the processor  ;) the seriously oversized (18"+) or misfit logs are kicked to the side.
I've got a dyna sc14, and with the exception of really gnarly "S"-shaped logs that curve two different directions I can't complain one bit, it handles ugly logs pretty well.  The really curvy stuff either gets bridged up on the log deck or just chatters around in the feed trough, not worth the time to fool with.  My frame is extended too, not 10' though, I think I got 6' extra - most of the logs I get are are 12'-18' long, and I try to keep them in the 6"-18" diameter range.  I take all the stuff that isn't processor material and set it aside and buck it up and then my teenage son splits and stacks it and he sells that wood himself.  Works good for both of us that way.  I get rid of the hard to handle stuff that comes along with the good logs, and he gets a good supply of wood to sell.
I have an older brute/built rite processor also with a similar design, it did ok on wood like that too, just a little slower.  I'm going to advertise it for sale here shortly in the classifieds section on FF (I have read and I acknowledge the terms of doing so) now that I have the dyna up and running good.
Good luck with whatever machine you pick, definitely worth the time to study on for a while, it's a big investment even for the smaller ones.
Firewood is energy independence on a personal scale.
Offline logman81
« Reply #24 on: March 25, 2015, 10:02:04 PM »
This is great info guys I'm enjoying every ones thoughts and opinions on it. I to thought about the dyna sc12 seems like they make a good solid machine. I might even consider a used machine if the price was right.
Precision Firewood & Logging
Offline logman81
« Reply #25 on: March 26, 2015, 07:38:53 PM »
So after talking with a fellow dyna sc12xp owner I think the dyna is the better choice for me. We talked a lot about the machine and I'm quite impressed with what he has told me. Plus if it's going to be run by my dad or my wife it is the way to go because neither one of them will be able to start my big 660 saw. The dyna is a little more money but I feel it is a good machine and a good company to deal with.
Offline landscraper
« Reply #26 on: March 26, 2015, 08:05:25 PM »
Good luck, hope you get something that works well for you.  I know mine has exceeded my expectations so far.
Offline logman81
« Reply #27 on: March 27, 2015, 06:43:01 AM »
Thanks I really think that dyna is going to be the right machine as long as I can afford it.
Offline Tom L
« Reply #28 on: March 27, 2015, 08:27:51 AM »
I have noticed on my multitek that if the chainsaw blade starts to dull, the logs do not go correctly into the splitter channel
the saw blades need to be sharp, to cut thru any remaining wood cleanly on the downstroke of the hydraulic saw.
any little bit of tree still connected will cause the cut piece to roll as it falls and need to be repositioned to split.
with this machine, it is a joy to run and can do quite a bit of wood per hour if everything is sharp. with a dulling blade it becomes a hassle to run , as almost 50% of the wood has to be repositioned before splitting
so keep everything sharp and well maintained no matter what processor you get
Offline logman81
« Reply #29 on: March 27, 2015, 09:34:34 AM »
Thanks for the tip tom, I keep up on the maintenance of all my equipment religiously!
Offline sawyerf250
« Reply #30 on: March 27, 2015, 09:46:09 AM »
Kind of curious what Dyna is a actually asking for the 12 and 14 models if anybody knows a rock solid answer? I have tried calling the company and getting any info from them yet, trying to formulate a questionnaire in essence of everything I want to know before I call and waste their time.
Offline logman81
« Reply #31 on: March 27, 2015, 10:48:43 AM »
The sc12xp starts at 12k and goes up depending on options.
Offline logman81
« Reply #32 on: March 30, 2015, 07:27:00 AM »
Any one here have the cord king m18-20? Looks like a very good machine.
Offline dwchaisson
« Reply #33 on: April 12, 2015, 08:49:34 PM »
Does anybody know what kind of production rate the wallenstien has? 1/2 to 1 cord per hour? I'm in the process of building one which is similar in concept but unsure if it will be fast enough to overcome My ADHD
homemade skidder, homemade band mill, home made log loader and trailer, 1993 ford 1 ton,1996 Chevy 1Ton dump, 2010 john deere 5065M with loader, 1987 trackless with blower, 576 husky,565 husky 372husky, homemade processor in the build stage, 900 david brown. 2 fordson majors. Life Long Collector
Offline logman81
« Reply #34 on: April 13, 2015, 08:41:24 PM »
They claim one cord an hour, but I'm not sure if that's man hrs or machine hrs.
Offline DZell
« Reply #35 on: January 17, 2019, 06:18:38 AM »
Does anyone have experience or a review on the newest wallenstein wp 1624? I have only seen the videos from the manufacturer.
Turnner firewood processor any thoughts?
Started by logman81 on Firewood and Wood Heating
Last post February 25, 2013, 02:15:21 PM
by logman81
firewood processor circular blade thoughts
Started by icefishingrulz on Firewood and Wood Heating
Last post July 13, 2014, 08:50:20 AM
by North River Energy
Wallenstein wp 830 processor what's your take on them?
Last post July 15, 2014, 05:34:15 PM
by drlewis
wallenstein wood processor
Started by JPM on Drying and Processing
Last post April 01, 2011, 10:30:44 PM
by JPM
