Author Topic: Started the build.  (Read 82017 times)
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Re: Started the build.
« Reply #900 on: January 15, 2019, 07:26:50 PM »
Good job.
Eat the elephant one bite at a time (old saying).
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #901 on: January 15, 2019, 07:56:27 PM »
Beautiful work my Friend, keep on keeping on.  8)
Offline fishfighter
« Reply #902 on: January 17, 2019, 08:23:26 PM »
Got a little done.
Base board and she molding.
Top plate covering the sliding door tracks.
Of course I had to take the door down to varnish the door trim. Will get it back up in the morning.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #903 on: January 17, 2019, 09:13:00 PM »
That old Oak is showing out.   :)
Offline fishfighter
« Reply #904 on: January 17, 2019, 09:46:51 PM »
Lynn, I do have a problem. Checking my oak stash, I am short of some 2x6's. :( Guess I will try to fell a standing dead oak tomorrow and throw it on the mill. Got 5 or 6 of them to saw. I will pick out a small one just for 2x6's. ;D
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #905 on: January 17, 2019, 11:05:08 PM »
Like Lynn says that oak fantastic!
Have fun and stay safe tomorrow!
1992 LT40HD
Offline fishfighter
« Reply #906 on: January 25, 2019, 05:36:10 PM »
Just a update.
Had did some painting in the living/kitchen area. Finished all of that.
Way back when I started this build, some things new to timber framing I didn't know. :( The big problem I had was when I made the braces. The more I got to thinking about them, the more I hated the ones I installed. So, being a timber frame/stick build, is I took out the braces, I should have no problems due to the way all beams are supported by 2x4 walls.
So, I took a sawsall to them and out they came. Them I made new ones. To install them, I used biscuit jointer into the braces and post/beams with some good glue.
I have them all up. Problem, I have to stain them to match the posts and beams. Still working on a stain for that.
Had a little time to make thresh hole in between the bathroom/ other area out of oak. The difference in height is about a 1/4" in the flooring.
  Starting with some 2x4 oak stock, passing it thru the planner, I then put it to the table saw.
Sanding
Finished product. Just sitting in place till I finish out the pine flooring. Then it will be glued down.
Tomorrow I will try to fire up the saw mill. In need of some oak lumber. That, and I will start making some molding to trim out the post and beams.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #907 on: January 25, 2019, 07:26:33 PM »
That threshold is about what I had to do between the mudroom and back porch at the Cabin.  Took a full 2X6 White Oak board and started whittling.  Same situation between the new and old portion of the living room except I used a 1X6 Cypress.  Strangely, I do not have a picture of either.  :-\
Offline fishfighter
« Reply #908 on: January 26, 2019, 10:17:40 AM »
The difference between the floors is because I had installed 5/16" hardie board below the vinyl flooring in the bathroom. One of those, I didn't plan for. Oh well. ;D
Offline fishfighter
« Reply #909 on: January 28, 2019, 09:27:22 PM »
Sawed up one small oak and had to call it a day last Saturday.
Some 4/4 and some 1".
Today I broke down and started resawing, and planning out a bunch of lumber for all trim work that was needed done. Had a late start due to the coffee pot broke. >:(
Got all door trim hung in the living/kitchen area. Really looking nice. Sorry, didn't have my phone with me, no pictures. :(
I will be attacking the back bed room soon. There is a ton of junk I have to remove out of it and then I have to remove sheetrock off the walls. Reason, have some wiring to run along wanting to change a few things. I will have to frame a closet out too. Really nothing hard. I am also thinking of adding a door in that room that leads out to the back porch. Would be easy to do. This is a guest house and if two couples stay, ones in the back bed room would have a step out the back without going thru the rest of the house.
On a side note. Hopping to get a dusting of snow here by morning. ;D Had two last winter, but it could be 8-10 years before the next snow fall here. 8)
Offline Armymann50
« Reply #910 on: January 31, 2019, 03:21:32 AM »
Nice work
Offline fishfighter
« Reply #911 on: January 31, 2019, 05:43:54 PM »
Thanks Army.
Today, I did a clean out off on the porches. Had so much trash like scrap lumber. A lot to the point I couldn't use the areas. >:(
Then did a little corking inside.
After that, it was time to try out staining the braces to match out. Had fixed up a batch of vinegar 1 qt and two small pads of steel wool pulled apart. Been mixing it up every day for about 8 days and testing it.
Braces before stain.
After
Dang close match. ;D Once I clean and wipe down the posts and beams, it will match.
Tomorrow, some varnishing of trim work.
Offline Darrel
« Reply #912 on: January 31, 2019, 07:38:46 PM »
Looking mighty fine!
1992 LT40HD
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #913 on: February 04, 2019, 08:05:02 AM »
How are those angle braces attached?
In the last pic the brace on the left shows the pith.
I really like the the way that looks.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline fishfighter
« Reply #914 on: February 04, 2019, 11:02:45 AM »
1" dowel pins and glued.
I did saw up enough 4/4x6" pine boards for the front porch last Saturday. And then yesterday I fought a big SYP log. Had to trim it down a bunch just to be able to saw it up.
After the fight that I think I won. :D Was in need of 2x4's.
Offline Bruno of NH
« Reply #915 on: February 07, 2019, 03:29:27 PM »
Looking good fish you do nice work.
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline fishfighter
« Reply #916 on: February 07, 2019, 06:48:26 PM »
Thanks. The last couple days I had to clean out the back bedroom. Two trailer loads to the burn pile. :o Record breaking temps here. :o Talking hitting 82F, but having a cold front to come in tonight. :(
Today, I ripped down some sheetrock. :( Had to due to needing to do some rewiring. :( Got that done and also finished the rough in wiring.
Still have more stuff I have to go thru. A lot of loading ammo stuff and boat parts.
Sawed up some 2x4's, but they are still to wet to use. :( I need around 20 to build a closet. :( Guess if I have to wait, it would put me back a long time. >:( So, maybe I will just go :'( buy some tomorrow. :'( That hurt. :D
Offline fishfighter
« Reply #917 on: February 09, 2019, 11:14:43 AM »
Got the closet framed in yesterday. Cost me $60 for 2x4's and a box of framing nails. >:( DanG box store framing lumber is junk. >:( I hand picked and out of the ones I did, I would of rejected a 1/3 if I sawed them up. ;D
Fixing to head back and hand insulation. Maybe start hanging sheetrock tomorrow. This room will go very fast, I hope. 8)
Offline Tin Horse
« Reply #918 on: February 09, 2019, 01:33:53 PM »
I sure agree with that about the lumber thing. When I framed my shop with box store 2x6 I couldn't believe the bad quality. I had some dry milled lumber and things went better with it. I wouldn't ever try to sell that quality.
Bell 1000 Wood Processor. Enercraft 30HTL, Case 580SL. Kioti 7320.
Offline fishfighter
« Reply #919 on: February 09, 2019, 07:25:28 PM »
For sure about box store lumber. :( How in the world will a house stand 50+ years building with the junk they are selling?
Anyway, that room has new insulation. Took me longer that I expected, but done. Looking at the weather, I am hoping that I can order some sheet rock for Monday. It's going to be iffy with rain next week. :(
Forgot, it was 38F here this morning. Cold for me. Fired up the wood stove and with in a hours time, I was peeling everything off down to a Tee shirt. Bad thing, my 30+ year old staple gun broke. :o Had to run and buy a new one.
started sawmill build
Started by staker on Sawmills and Milling
Last post April 08, 2013, 04:40:22 AM
by ND rancher
Long and wide build started
Started by thinwater on Sawmills and Milling
Last post November 27, 2018, 07:29:18 PM
by thinwater
started to build platforms on the mill
Started by lyle niemi on Sawmills and Milling
Last post April 06, 2012, 10:27:46 PM
by lyle niemi
Manualish bandmill build started
Started by rrleesb on Sawmills and Milling
Last post June 03, 2018, 01:48:57 PM
by rrleesb
