Author Topic: Started the build.  (Read 81985 times)
Offline fishfighter
Re: Started the build.
« Reply #940 on: March 11, 2019, 02:56:08 PM »
Thanks Lynn. Got the room all primed out. Will paint the ceiling tomorrow. That will be white, but still haven't picked a color for the walls.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #941 on: March 11, 2019, 04:14:46 PM »
She will..... :D
Offline fishfighter
« Reply #942 on: March 14, 2019, 02:47:17 PM »
Been painting and got it all done. 8) And yes Lynn, I did pick the color. ;D
Today, I started boxing in the windows. Problem there, I had to shut it down due to rain. :(
Just have to add the outside trim.
I got to order some more knives for my planner. It's going to take just under 200 sf of flooring. Will be the same flooring as the kitchen/living room area.
Have another problem. Most of the oak I have sawed up is reading around 13-14% moisture. :(  Thinking of moving all inside the house and just run some fans on it 24/7 till I can get the moisture down below 11%.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #943 on: March 14, 2019, 05:26:21 PM »
I am just glad to see you stirring and getting-r-done.  8)
Offline fishfighter
« Reply #944 on: March 16, 2019, 09:05:33 PM »
So much for finishing the back bedroom. The more I got to thinking, the more there will be a change. I did finish up all painting, wood trim around the windows and installed plugs and switches.
Back to the change. This is outside the bedroom.
Inside in the room.
Boy, did I screw up or what? Even more so for a change I want to do. >:( Yep, I didn't center the door way to start with. Not to bad of a change/fix. The biggest change I want to do is add some timbers to the area outside of the bedrooms. By doing that, it would carry off from the kitchen/living room areas. ;D
So, this afternoon, after figuring out what I will have to do, I sawed up a couple beams. I will saw up what else that is needed tomorrow.
Big reason I am going to try this, if it works, I am wanting to do this in my house on a grand scale. 8)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #945 on: March 17, 2019, 08:21:34 AM »
As long as your mind has a plan, your butt is still in control.  Most of us fly by the seat of our pants anyway.  :D
Offline fishfighter
« Reply #946 on: March 17, 2019, 09:18:26 AM »
You got that right Lynn. :D One of the logs I sawed up yesterday had to be the nastiest logs that was ever sawed. Sucker had mushrooms growing off it. A lot of punk wood. Was a short log, but more then long enough to get a 4x10 out of it. I have around 6 more standing dead oaks that need to be felled. Might do that today. Having a very slow start to my day already. :(
Offline fishfighter
« Reply #947 on: March 19, 2019, 08:08:17 AM »
Door way moved and beams going up.
Going to try and finish this up today.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #948 on: March 19, 2019, 08:32:07 AM »
Looking good.  smiley_thumbsup  I believe that "Oakey Dokey" will be OK here.    ;D
Offline fishfighter
« Reply #949 on: Yesterday at 07:30:14 AM »
Wrap it up yesterday. Just need to stain them out with vinegar/steel wool mixture and add the braces.
I like it and it made the area to match the kitchen/living room area. 8)
started sawmill build
Started by staker on Sawmills and Milling
Last post April 08, 2013, 04:40:22 AM
by ND rancher
Yet another solar kiln build started
Started by SawyerBrown on Drying and Processing
Last post April 20, 2015, 10:02:35 PM
by Tree Dan
started to build platforms on the mill
Started by lyle niemi on Sawmills and Milling
Last post April 06, 2012, 10:27:46 PM
by lyle niemi
Wisconsin cabin build - just getting started
Started by dgrover13 on Timber Framing/Log construction
Last post November 29, 2017, 07:38:50 AM
by Don P
