Author Topic: Tree Climbing Experience  (Read 6227 times)
Offline Kevin
Re: Tree Climbing Experience
« Reply #20 on: September 07, 2004, 05:02:32 PM »
You will most likely want to have more than one climbing rope.
The static rope is good for mechanical access but that's it.
If you take a fall you will want to be tied into a dynamic rope to absorb some of the shock otherwise your body will take the shock.
Get a copy of the Tree Climbers Companion by Jeff Jepson and The Fundamentals of General Tree Work by Gerald Beranek.
Offline crtreedude
  • A proper coffee break...
    • Finca Leola Reforestation
« Reply #21 on: September 07, 2004, 08:09:58 PM »
Thanks all - it seems like this is on track with what I have been thinking - Florida, you can come and watch me fall.  :D
I am sure the group will need a report. Thanks for the tip on the books and static line, I figured that was all the static line was good for since in rock climbing they emphasis over and over (and over and over....) that you should never climbing with static rope. If you fall on it from any height, you can break your back.
Straight up ascending though, there is no need to have any give. I have plenty dynamic rope from my rock climbing days.
Fred
So, how did I end up here anyway?
Offline Kevin
« Reply #22 on: September 07, 2004, 08:27:00 PM »
Fred;
The static line is good for rigging also.
I use kermantle mostly for ascending with the Kong and Pantin.
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #23 on: September 08, 2004, 03:30:22 PM »
Quote
Fred;
Huh?
Offline Kevin
« Reply #24 on: September 08, 2004, 03:51:26 PM »
You're right, it's spelt wrong.
Kernmantle
Thanks.  ;D
Offline leweee
  • Illegitimus non tatem carborundum
« Reply #25 on: September 08, 2004, 03:55:31 PM »
Fla_Deadheader... Sounds like your a man of many UPS & DOWNS. :D   Couldn't resist that one.  ;D leweee :)
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #26 on: September 09, 2004, 05:09:06 AM »
Yeah, I used ta could do a lot more. Lately it's mostly down. ::) ;D
Offline leweee
« Reply #27 on: September 09, 2004, 11:03:54 AM »
Oldtimer once told me "Old age  isn't kind" I'am at that age now were I believe him. :( Parts just don't work like they used to. Eyes, ,joints , etc....I'am learning to pace myself, things take longer to accomplish...but slow and steady wins the race. :)
Offline Stephen_Wiley
  • Forester.
« Reply #28 on: September 13, 2004, 09:44:03 PM »
CR,
Climbing is only 1/3 of the knowledge involved in working in trees. The other 2/3's is knowing health and structural issues of the species you are climbing, specifically knowing the many ways a tree can structurally fail, recognizing suttle symptoms of bark, root and stem weaknesses, proper pruning techniques.
Kevin has recommended a couple of books good for the climbing aspect. But do not underestimate the potential of problems arising from the aforementioned. Make certain you have a basic understanding of root diseases, bark diseases (on more than one occasion I have rescued climbers for ignoring this) and other structural failure signs. Note branch ratio to trunk size can greatly determine a safe climb.  Also time of year (sap flow) can reduce the strength of branches.
Further, over thinning is just as harmful to tree health as is topping.
The more informed you are the better chance you will have of reducing risk to your health and the trees.
:P :P :P
" If I were two faced, do you think I would be wearing this one?"   Abe Lincoln
Offline farmerdoug
« Reply #29 on: March 02, 2007, 11:05:20 PM »
CRT,
Did you ever get around to climbing your trees?  I figure by now you have the locals swinging from the trees like tree monkeys. :D
Farmerdoug
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
Offline Kevin
« Reply #30 on: March 03, 2007, 09:06:01 AM »
Good response Stephen.
There are many experienced tree climbers that get hurt every year and we end up losing a few as well.
Listen to that gut feeling, if it doesn't feel right then it probably isn't safe.
Offline Ed_K
« Reply #31 on: March 03, 2007, 04:51:57 PM »
 You can have everything right and the gut will still say no.Thats why I have all the right climbing gear stored in a duffel bag and don't climb any higher than the roof of the skidder to hang a chocker  ;D.
Ed K
Online SwampDonkey
  • Large Tooth
« Reply #32 on: March 03, 2007, 05:08:52 PM »
Just fell'm on top of the skidder and forward them like lewee does. Don't need no cable. ;D
Move'n on.
Offline rebocardo
  • Atlanta GA
« Reply #33 on: March 06, 2007, 11:14:31 AM »
> This happened  to a very experienced treeclimber from Tuftonboro NH.
Same thing happened in MA about two years ago, experienced guy working by himself basically cut his own head off.
Do you remember hearing about the guy in NH last year that decided using a chainsaw on a ladder was a good idea and killed his wife? Kicked back out of his hands and fell running on his wife's head while she was steadying the ladder.
Tree Climbing
Started by Weekend_Sawyer on The Outdoor Board
Last post February 17, 2016, 04:29:58 AM
by Weekend_Sawyer
Tree Climbing
Started by lxskllr on Forestry and Logging
Last post August 27, 2018, 01:34:51 AM
by mike_belben
Tree Climbing
Started by tim1234 on General Board
Last post March 02, 2007, 10:07:57 PM
by PB Logging
Tree Climbing Basics
Started by Furby on General Board
Last post October 13, 2006, 12:00:41 PM
by Murf
