Author Topic: Filling up your tensioner  (Read 946 times)
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« on: May 17, 2015, 07:28:09 PM »
I need to fill up my tensioner...there's got to be a better way to do it than they say in the manual, no?
Boy, back in my day..
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Filling up your tensioner
« Reply #1 on: May 17, 2015, 07:30:55 PM »
So that was what you were saying. I had bad service and couldn't quite make out your message. I haven't had to do anything to mine, so I don't know what they want you to do in the manual. Did it fail suddenly?
Offline GAB
« Reply #2 on: May 17, 2015, 07:47:32 PM »
If it helps you any I found that using a syringe to put the oil in was the easiest and least messy way of doing it.
Gerald
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #3 on: May 17, 2015, 08:19:53 PM »
Gerald
I have a syringe I bought when I bought Round Up at Lowes. It has a tube on the end of it to measure the amount of Round Up I put in a gallon of water.
I use this same syringe to add ATF to my tensioner. It works great.
Offline 4x4American
    • Website Link
« Reply #4 on: May 17, 2015, 08:25:42 PM »
Thanks fellers...no I just need to add fluid dave, it has air in it and turns over really hard to get up to psi.  No worries, my friend who has same mill is stopping in tomorrow am to help me with it.  He said he tensions/fills his a handful of times per year.  I asked him where the fluid was going he said he didn't know cause can't see any wet spots!
    • My homepage
« Reply #5 on: May 17, 2015, 08:41:11 PM »
That's odd. I'm headed into year eight and never added any. Like you said, must have had an air bubble in yours.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #6 on: May 18, 2015, 06:49:58 AM »
                Servicing the Blade Tensioner
Add an Automatic Transmission Fluid (ATF) such as Dexron III ATF to
the hydraulic blade tensioner as needed. To add enough fluid to completely fill the tensioner block:
1. Unscrew the tensioner handle to reveal 2” of thread. Remove the sawmill blade housing covers and blade.
2. Push the idle-side blade wheel/shaft housing all the way in to collapse the rear tensioner piston. Pull the idle-side blade wheel/shaft housing away from the tensioner.
3. There are two fill plugs provided on the tensioner. For easiest access, it is recommended to use the hole behind the gauge to refill the tensioner. Clean any dirt and debris from the plug area. Use a 7/16” wrench to remove the plug, making sure to keep the plug o-ring with the plug.
4. Use a small funnel, cup or squirt can to add hydraulic fluid through the fill plug hole until a puddle of fluid forms and is maintained over the fill hole. As you maintain the puddle, manually extend the rear piston. Be careful not to draw air into the tensioner. Use pliers to pull the rear piston if necessary, but only grip the outer 1/4” of the rear piston. Gripping or marring the surface beyond this point could result in seal damage and prevent the system
from holding tension. Continue pulling out the piston as far as it will travel.
5. Reinsert the plug and thread 2-3 turns. Turn the tension handle clockwise until 6 or 7 threads show beyond the front piston block. Tighten the plug all the way.
6. Push the idle-side blade wheel/shaft housing all the way in to collapse the rear tensioner piston. If the piston does not extend at least 2” from the end of the tensioner block, repeat Steps 1-5.
7. Reinstall the blade and blade housing covers. If you have trouble installing a blade, it may be necessary to remove some fluid. Open the plug one turn and turn the tension handle in until some fluid is pushed out. Tighten the plug and retry.
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
filling your OWB
Started by sparky1 on Firewood and Wood Heating
Last post February 13, 2012, 10:45:14 PM
by sawdustandmud
Filling in around a red maple
Started by kelLOGg on Ask The Forester
Last post May 26, 2016, 07:28:58 PM
by sprucebunny
wood filling
Started by rdhdfmn on General Board
Last post May 29, 2004, 05:09:55 PM
by Ianab
log yard filling up.
Started by weisyboy on Sawmills and Milling
Last post April 04, 2011, 07:13:14 AM
by sigidi
