Author Topic: 518 Cat Grapple  (Read 793 times)
Offline mills
518 Cat Grapple
« on: June 24, 2015, 05:40:16 AM »
The grapple on my 518 turns freely, but can't control the rotation. Motor turns normally. It looks like the grapple has dropped about a half inch below the pivot block, so the pin is not catching in the groove. Book calls for an adjusting nut below the bearing, but no other details. Anybody worked on one of these before?
Offline kiko
Re: 518 Cat Grapple
« Reply #1 on: June 27, 2015, 09:13:35 PM »
It is just a spindle set with nut and lock tang.  I have found that most times the threads are damaged on the spindle and the nut.  Simply tightening it may not end the issue.
Offline mills
Re: 518 Cat Grapple
« Reply #2 on: June 28, 2015, 05:57:39 AM »
Yeah, that's what I'm afraid of. Haven't had time to dig into it yet, but it can't be good when the spindle has opened up, and the lock ring appears to be in place.  :(
Thank you for your reply, and also for the PM sent by coxy.
Offline mills
Re: 518 Cat Grapple
« Reply #3 on: July 05, 2015, 05:55:27 AM »
Well, sometimes you get the bear... :)
Got lucky, found that the lug on lock ring had broken and the spindle nut backed off. Top bearing came apart, but was able to repair it. Ready for work if it ever dries up. I appreciate kiko and coxy's replies. I don't mind working on something here and there as long as I have a basic understanding of what I'm facing.
Who sells a one-handed, small log / firewood grapple? Tongs with a grapple
Started by Jasperfield on Forestry and Logging
Last post August 28, 2008, 09:12:16 PM
by Dave Shepard
Grapple bucket or grapple forks?
Started by alan gage on Sawmills and Milling
Last post January 30, 2019, 04:31:15 PM
by alan gage
log grapple?
Started by treefarmer87 on Forestry and Logging
Last post February 15, 2011, 08:14:37 PM
by treefarmer87
Anybody need a log grapple?
Started by iffy on Forestry and Logging
Last post May 19, 2009, 11:08:41 AM
by iffy
