Compression Drop Test
Started by luvmexfood, July 17, 2015, 12:54:35 PM
luvmexfood
My old 029 seems to have lost power but not suddenly. Did the drop test. Saw just chugged down the starter rope. Is it time for a rebuild and is it worth rebuilding? Runs ok just lack of power.
What parts would probably be needed to rebuild assuming I used aftermarket parts? Don't want to put a whole lot in a saw that is around 14 years old.
Give me a new saw chain and I can find you a rock in a heartbeat.
sawguy21
I would pull the muffler and look at the piston but it sounds like the old girl is plumb wore out. I think that is the clam shell design which means completely stripping it to get the piston out. You can the assess the bottom end as well and make your call. A new MS291 is around 500 bucks
dougand3
+1 on pull muffler and look. It may be just piston and ring scored. But may be cylinder scoring and Al transfer. I'd put a new top end on it (Cyl, P&R, wrist pin, bearing, circlips). Normally, you can make it a 49mm bore 039 with a direct bolt on.
luvmexfood
I was leaning toward putting an 039 top end on it. But seeing that it just got run over by a tractor have to think somemore on it. Brakehandle, complete rear handle with all the associated workings and airfilter cover at first glance.
And I had thought about quitting earliar in the day because I was aggravated and tired. Should have.
sawguy21
Look for another or an 039 and use this one for parts.
