Author Topic: New owner.  (Read 20447 times)
Offline Satamax
  • Location: South eastern alps, in France but right on the italian border.
Re: New owner.
« Reply #20 on: August 16, 2015, 08:12:08 AM »
You must have some large support equipment to feed that beast.
Mick, i have the little white pupy behind!
Well, this thing ;D
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline fishpharmer
Re: New owner.
« Reply #21 on: August 16, 2015, 09:18:15 AM »
Satamax, glad to see you finally have a sawmill.  What a mill it is!!! :o 8)
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline Satamax
Re: New owner.
« Reply #22 on: August 16, 2015, 09:37:32 AM »
Thanks a lot Fishpharmer.
Guys, the next questions are:
How many log dogs do i need? Of what type?
I have two small hydraulic rams, which could do the job may be.
Log turner? I'd be keen on a chain one. That might wait, and i will use a cant hook and the crane.
Laser? I'd be real keen on a laser line. But on the cheap ;D
How do i set it up? I was thinking railways ties. Builders friends tell me concrete piers. But i don't know how all of that will evolve. I might be buying a little bit of land just next to mine, to square it off.  So the saw will move i think.
Any advice?
The motor on it for the moment is 22kw. My electricity supply only 15kw. I wonder if i could start it up with the 15kw. I have a brand new 11kw motor that i could retrofit and cut slow.
Thanks a lot guys.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: New owner.
« Reply #23 on: August 16, 2015, 10:55:38 AM »
Kbeitz,
 I think that's elevation,I had to do a double take myself.
Satamax,
 Thanks for the pictures and good luck with the mill.You must have some large support equipment to feed that beast.
Beautiful part of the world and yes the truck is a real gem.FF member Loggah needs one to tow his restored Lombard log hauler.That would turn some peoples heads.
 Best of luck,Mick
If it's not  elevation thats got to be one BIG  truck...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Satamax
Re: New owner.
« Reply #24 on: August 16, 2015, 04:19:40 PM »
Kbeitz,
Satamax,
 Best of luck,Mick
And a huge sawmill  ;D
Elevation obviously.
Offline Kbeitz
    • My Hobbies
Re: New owner.
« Reply #25 on: August 17, 2015, 06:43:51 AM »
Any advice?
Thanks a lot guys.
You might get away with useing a pony motor for startup.
Offline slider
  • sawyer,trucker,tree service
Re: New owner.
« Reply #26 on: August 17, 2015, 07:06:07 AM »
Good score on the mill Satamax .I have been following your post with interest for quiet some time.I'm glad you finally found you a mill.
al glenn
Offline Satamax
Re: New owner.
« Reply #27 on: August 17, 2015, 08:31:33 AM »
Thanks a lot guys.
Kbeitz, i could. I don't know where i'm heading thought.
Offline Satamax
Re: New owner.
« Reply #28 on: August 19, 2015, 02:49:34 AM »
For the moment, i'm searching ads for a frequency drive, which could limit the power.
Thanks.
Max.
Offline customsawyer
    • The Custom Sawyer
Re: New owner.
« Reply #29 on: August 19, 2015, 03:45:27 AM »
Great score on that mill. That thing is a beast. All I can tell you is if you get a log that will max that thing out you are going to need some strong hyd. for turning and clamping. If that mill can cut 40' long you might want to consider putting two turners and two clamps. I know that with the 40' logs I cut there is so many times that having the extra turner and clamp is the only way that I can turn the logs.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline Warped
Re: New owner.
« Reply #30 on: August 19, 2015, 05:12:50 AM »
Wow! My guess is he got a great deal on it.............after they were done with it in the Sahara   ;D
Good with the rough stuff and rough with the good stuff
Offline Satamax
Re: New owner.
« Reply #31 on: August 19, 2015, 05:46:39 AM »
Customsawyer, yep that thing will max out at 12m, so that's 40 feet pretty much. May be i have a bit of leaway. I'm getting cranky, i want to make it run :D  My latest idea on log dogs, something like log tongs pulled by an hydraulic ram. That would be prety easy for centering. One fixed, the other one moveable to accomodate short or long logs.   Ok, two turners. I'll see what i can find in the way of chains and the like. Thanks a lot.
Warped, sorry for being French  ;D but i don't get it!
Tho i got a deal. I paid may be half the price of a brand new LT10.
Offline 47sawdust
Re: New owner.
« Reply #32 on: August 19, 2015, 06:01:49 AM »
You might be French but you didn't get took on that deal.
I get sore just thinking about handling the lumber coming off that mill.Did a masseuse  come with the mill?
Mick
Mick
Offline Satamax
Re: New owner.
« Reply #33 on: August 19, 2015, 07:34:15 AM »
I'll have to look for the masseuse!  ;D
Offline 5quarter
    • Blue Harbor Refinishing
Re: New owner.
« Reply #34 on: August 20, 2015, 12:52:26 AM »
Satamax...the Sahara was once full of trees. and then that mill arrived. and then all the trees were gone.  :D :D
great score!
Offline whitebread
Re: New owner.
« Reply #35 on: August 20, 2015, 03:33:45 PM »
Not to take this off topic. I figured from the picture with the writing on the road that this was on the Tour de France route. Beautiful country.
Stihl 460, 290, and 250. Granberg CS mill and Mini-mill. New Holland TL-80 with 820TL loader and grapple.
Offline Satamax
Re: New owner.
« Reply #36 on: August 20, 2015, 04:41:38 PM »
Yep, ...... tour de france! Because of all the passes around, we get, from june, to end of september, all the idiots cyclists, who think they own the road. No lights, no reflectors, no yellow jacket. Toll last year, three deaths just in the Lautaret pass!
Don't start me on road cycling, or i'll rant forever  ;D
Offline Warped
Re: New owner.
« Reply #37 on: August 20, 2015, 04:49:47 PM »
Yeah, but they got good drugs.........if that's your thing   lol!
Offline Satamax
Re: New owner.
« Reply #38 on: August 21, 2015, 01:42:15 AM »
Noteven, their stuff doesn't get you high! :(
Offline Ianab
Re: New owner.
« Reply #39 on: August 21, 2015, 06:07:17 AM »
Just out of interest, 8,000ft around here puts you up in the snow and clouds on top of this hill.  :D
3500ft is about as high as you can drive...
I am know a new owner
Started by sjh on Sawmills and Milling
Last post October 05, 2003, 10:05:31 AM
by oldsaw
new mill owner
Started by sawguyver on Sawmills and Milling
Last post February 01, 2006, 12:34:39 PM
by sawguyver
new timberking owner should say hello
Started by sgtmaconga on General Board
Last post March 17, 2008, 10:56:29 PM
by WDH
Ezboardwalk Jr owner only please.
Started by hturner12 on Sawmills and Milling
Last post September 18, 2018, 07:55:23 PM
by Jeff
