Arborwear
Author Topic: Square log building  (Read 2528 times)
Offline stumpy
  • I feel alot more like I do now than I did before
    • Rustic-woodfurniture/Stumpy's Wood Works
Square log building
« on: September 22, 2004, 04:35:49 PM »
I am going to build a cabin out of 8X8 squared logs that I will be sawing myself. I have Red pine, White Pine and Balsam. I plan to cut i log out of each tree to get just the heart wood.
My questions are:
1) Other than looks, is there any problem with mixing species (those listed above)
2) I will be gluing between logs so how dry should they be
3) If I use all one species, is there any concern about using all balsam
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Timberworks
  • Guest
Re: Square log building
« Reply #1 on: September 23, 2004, 09:00:51 AM »
Balsam will dry much faster than Red or White Pine.
We have mixed R & W Pine with no problems.
Red pine will check more radically than White Pine.
Glueing the logs together is a no,no.
Most builders use a spline or chink joint between the log courses.
you could look at some of our photos at
www.timberworks.ca/dovetail.htm
Offline Dana
    • Green Leaf Farms
« Reply #2 on: September 23, 2004, 09:09:39 AM »
I would check with someone who knows more than me but,my understanding is that different species of wood shrink different amounts. So if you are to use two or three species of timber use the same species on a complete course to avoid settling problems.
My cant is not square, how to fix?
Started by RM Farm on Sawmills and Milling
Last post October 24, 2014, 07:37:10 PM
by StimW
square peg
Started by r.man on Firewood and Wood Heating
Last post October 23, 2013, 02:10:53 PM
by Logging logginglogging
How Square is Square?
Started by ARKANSAWYER on Timber Framing/Log construction
Last post June 17, 2011, 10:59:22 PM
by Coon
can't get square
Started by nstringer04 on Sawmills and Milling
Last post May 01, 2014, 05:08:40 AM
by ladylake
