Author Topic: Chainsaw Boots, Recommendations....  (Read 12783 times)
Offline wfcjr
  • Working outside, ... when I can
« on: August 27, 2015, 10:10:12 AM »
Not sure if this belongs in this topic area, in General Forestry, or in Health/Safety, but here goes...
Looking for a quality pair of leather chainsaw boots.   Steel or composite toe, and whatever internal lining material that they use to make them "saw proof", or at least to limit the damage.
After years of wearing regular leather hiking boots, I figure it is time to wise up and have proper footgear in addition to my saw chaps.
Any thoughts and recommendations appreciated....
Offline John Mc
Re: Chainsaw Boots, Recommendations....
« Reply #1 on: August 27, 2015, 11:49:41 AM »
I think I remember a thread on this in the health/safety section - they were mostly focused on finding one that was comfortable and durable, but there was some mention of steel toas and other protection.
At one point someone (Labonville) was selling chainsaw protective socks.
I have some of the Jonsered rubber chainsaw boots that have protection on the top of the foot and up the shin. They look  little like stiffer mud boots. Unfortunately, I only wear them when it's wet out (and I need the waterproof feature)... they are not that comfortable to walk in. I always end up with my shins rubbed raw if I've had to do much walking (none of my socks are high enough to act as padding for the boot rim). Like a dummy, I did not buy them big enough to fit an insulating liner inside, so I can't wear them in th ewinter unless the temperature is pretty mild.
Offline Real1shepherd
« Reply #2 on: August 27, 2015, 02:34:30 PM »
Real loggin' boots like Wesco....COST, even without caulks.  Madsen's has a variety of boots that cost a little less than Wesco and are decent. I have no idea what you expect to pay? You can also get insulated rubber boots that are caulked with steel toes for way less than the leathers. I used to use them in the winter, but it needs to be COLD, 'cause they are really hot to wear.
Kevin
Offline wfcjr
« Reply #3 on: August 27, 2015, 05:17:10 PM »
Real loggin' boots like Wesco....COST, even without caulks.  I have no idea what you expect to pay? You can also get insulated rubber boots that are caulked with steel toes for way less than the leathers. .
Kevin
Prefer leather over rubber.  Only wear rubber boots in downpours.
I expect to pay less that it would cost for a trip to the emergency room and/or a prosthetic foot!
Understand that good gear is not inexpensive.
Thanks,
Online HolmenTree
« Reply #4 on: August 27, 2015, 11:59:29 PM »
Real logging boots in lace up design should be at least 8 inch high in the uppers for ankle support and have steel toe caps for crush and cut protection.
Composite  protective  toe caps offer as much cut protection as a piece of wood.
Offline barbender
« Reply #5 on: August 28, 2015, 12:15:34 AM »
wfcjr, I can't really offer any advice, I'm on the same hunt as you. Someone mentioned Labonville for protective socks, I believe they make actual leather chainsaw boots as well. I've read discussions about them on here before. One of the local saw shops has Husqvarna branded saw boots, I don't know if they are old stock because I have not seen them anywhere else, online included. They are a made in the U.S.A. boot, look to be excellent quality. If they were Gore-tex lined I'd be wearing a pair.
Offline ZeroJunk
« Reply #6 on: August 28, 2015, 07:48:11 AM »
I bought some Georgia Boot loggers on sale for less than $100. No, they aren't Wescos or Whites but they have steel toes and offer more protection than regular work boots. So, you just need to decide whether your level of use justifies paying 4 or 5 hundred bucks for a pair of boots.
Interestingly, most of the tree service guys that I do work for don't wear logger boots often. Just some steel toe work boots.
Offline DaveP
  • DaveP
« Reply #7 on: August 28, 2015, 07:57:43 AM »
Redwing makes a good 8" steel toe leather boot and, its is made in the USA.
                  Davep
Offline John Mc
« Reply #8 on: August 28, 2015, 08:38:11 AM »
I don't know if it's necessarily true, but I've heard that Steel toed work boots may not be the best choice if that's the only place that has protection. The theory behind that was that the chain will just slide along the steel until it drops off the back of the steel toe, cutting in to the top of your foot. The claim was that what might have been just losing a toe or two if the saw clipped a plain hiking boot was now destroying your foot. There were some gruesome photos to support this (one of those pictures you wish you could "un-see" once you've looked at it).
I'm curious if anyone else has heard this, and what they think of that claim. I never knew whether to believe it, or file it with the same story about a guy who never wears a seatbelt, because his cousin's first wife's uncle once survived a car crash by being thrown clear, and would have been crushed in the car had he been wearing a seat belt.
Online HolmenTree
« Reply #9 on: August 28, 2015, 10:16:08 AM »
That's funny John :D
The most common chainsaw cut to the foot is on the toe cap of the left hand boot, when limbing , bucking etc. Thankfully for over 40 years I have wore steel toe boots, I've nicked a quite a few of them. Then after a few months of wear a big hole will appear over the shiny steel cap as the leather wears away. I never saw or had a chain skid across the steel cap.
There are many steel toe logging and arborist boots available with built in Kevlar layers included. I wear a leather pair of Haix Volt boots with steel toe ,Kevlar and GoreTex.
Beautiful boots very comfortable even in 90 degree weather but not cheap.
B.C forestry standards call for mandatory steel toe.  You will see a little green Christmas tree logo on a certified forestry boot.
Offline John Mc
« Reply #10 on: August 28, 2015, 10:23:51 AM »
Thanks, HolmenTree. I guess that story I heard goes in the "safer to not wear a seatbelt" file.
In his defense, the guy who made this argument wasn't really arguing against steel toes, he was arguing for more protection than JUST steel toes.
Those boots sound nice. Are they also OK in colder weather? I'd love to find a place that has a variety to try on, so I could compare the fit. I should wear my rubber chainsaw boot more, but they are just too uncomfortable. The fit is not great, they make my feet sweat too much when it's warm out, and are not warm enough in the cold weather.
Online HolmenTree
« Reply #11 on: August 28, 2015, 12:22:51 PM »
John get the Stihl or Husqvarna rubber bottom with leather upper boots. They have Kevlar a and steel toe . Order one size larger to take felt liners for the winter.
Normal size for spring fall
Online HolmenTree
« Reply #12 on: August 28, 2015, 12:28:28 PM »
To add to last post. Wear Bama socks in them for spring fall (air conditioning) for the rubber bottoms.
« Reply #13 on: August 28, 2015, 03:20:55 PM »
Madsen's catalog is online, but you still have to order with them on the phone. They start with Wesco and go down the chain in price. They have all sorts of combinations and you'll pay near $300 for decent boots. I like the idea of Kevlar layers, but as HT said, when you slice yourself, it's usually on the top of your left boot as you limb and buck. Never had the chain 'skate' and do damage elsewhere than the steel tip. I'm not gonna say it's not possible, just not in my personal experience.
Kevin
Offline John Mc
« Reply #14 on: August 28, 2015, 04:26:21 PM »
...Wear Bama socks in them for spring fall (air conditioning) for the rubber bottoms.
Bama socks?
Online HolmenTree
Offline Skidder Kev
« Reply #16 on: August 28, 2015, 05:18:33 PM »
Bama is  a booty.  It wicks the sweat away from your feet keeping them dry.   I wear them in my viking rubber boots with leather uppers.
Offline John Mc
« Reply #17 on: August 28, 2015, 05:49:10 PM »
Thanks, HolmenTree.
There was an error in the link: should be ".com" not "-com" but I figured it out.
Online HolmenTree
« Reply #18 on: August 28, 2015, 06:25:00 PM »
http://www.gear-up.com/products/view/bama-socks-for-rubber-boots
There I got it fixed. My family and I were out on the lake with our pontoon boat. We anchored for the kids to swim. Had some time to check the site, Googled  Bama socks, had no pen but my wife had lip stick in here purse..............
« Reply #19 on: August 28, 2015, 07:13:34 PM »
I honestly don't know if that would work better than say REI's Moreno blend expedition socks. I wear these socks all yr around at work. Contrary to what most believe, you can wear quality wool blends socks in hot weather, they wick sweat well and your body regulates to the wool being on in the summer. I wear them for the padding in the warm months and the insulation in the winter. Like with anything wool, keep it CLEAN.
Kevin
Chainsaw boots?
Started by gman98 on Chainsaws
Last post January 09, 2018, 10:48:29 PM
by John Mc
Chainsaw boots
Started by MrMoo on Chainsaws
Last post January 17, 2003, 05:13:53 AM
by dan-l-b
chainsaw boots
Started by tj240 on Forestry and Logging
Last post July 31, 2014, 08:50:37 PM
by Andries
Chainsaw boots
Started by gman98 on Forestry and Logging
Last post May 25, 2016, 11:09:59 PM
by killamplanes
