Author Topic: Ok Experts... Husqvarna 576 or 372xp and why?  (Read 9459 times)
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
« on: August 29, 2015, 12:51:09 PM »
One of my buds runs a 385 non stop. Getting older. Wants a new saw. Wants similar power in a lighter package to pull a 24in bar. My suggestion was to let me build him his old style 372 with a 372xpw top end, new bearings & seals.... no base gasket & my typical tweaks etc. Mostly OEM...good torque.. a lot lighter than a 390.. a mild build that doesn't push the components too hard.
He wants new. Did his "on line" research and has decided to chase a 576 a local dealer has for 900 bucks with a 24in B&C. $$900??? That sounds really pricy when he can get 390 for approx. $1000 with bar & chain & tax from the same place!
SO Why a 576 vs. a 372xp or 372xp built into a 372XPW??
Husqvarna 365sp/372xpw Blend, Jonsered 2171 51.4mm XPW build,562xp HTSS, 560 HTSS, 272XP, 61/272XP, 555, 257, 242, 238, Homelite S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline Jhenderson
Re: Ok Experts... Husqvarna 576 or 372xp and why?
« Reply #1 on: August 29, 2015, 06:19:08 PM »
He can still buy a new 372. If I wanted a smaller saw that's what I'd buy. I'm not familiar with a 376 but I have run a 375. If I had to earn a living with that I pump gas instead.
Offline Pine Ridge
  • Part-time logger, Full time loafer
« Reply #2 on: August 29, 2015, 06:33:28 PM »
I like the 372 myself, good power to weight and balanced well, a little lighter than a 576.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
Offline JohnG28
« Reply #3 on: August 29, 2015, 06:34:30 PM »
I have no answer to that question, other than when a guy wants something sometimes he just has to get it. I personally would go 372xpw of those options, maybe he needs to do his "online research" in a different place.  ??? :D Good luck with him and the new or "new" saw either way.  :)
Offline weimedog
« Reply #4 on: August 29, 2015, 06:46:38 PM »
LOL I'm assuming that's 576 & 575 that would lead you to pumping gas...
Offline WV Mountaineer
« Reply #5 on: August 29, 2015, 08:12:20 PM »
Any 372 version is a great saw and feels a lot lighter in the hands than the 576's I have run.  I don't know the actual weights but, the 576's feel the same weight as my 385 XP.  I'm sure they aren't but, I'm also sure they aren't a lot heavier than the 372's either.  They just feel this way to me.
I run about 3 gallons of gas today through my 385 cutting logging butt offs and, crotch wood into firewood.  That is where this big saw really shines.  It is a hoss.  However, while I love that saw, after going through the big stuff and moving into the 4-10 inch stuff found in the tops, I am simply pooped from swinging that saw out in front of me for 6 hours.  I was wishing for my 372 my uncle is borrowing.  It would have been much better.   I can't see where the 576 would have made in difference in felt weight versus the 385. But, know I would have noticed a difference if felt weight using the 372.   I'd go with the 372 all day, every day.
In my opinion, there is no better saw made in pound versus output than a 372 or 440.  Especially a tricked out one that can pull those longer bars with ease through big hardwoods.  So, the decision would be simple for me if I didn't want to run a 385 any more.  I'd buy a tired ole 372, go back through it and put a new lower end and, let you build the top end.   It is the perfect saw.  I think you will agree after watching many of your videos online.  ;D  God Bless
Edit:  BTW, I'm no expert either.
Trying to live for the Lord, spend all the time I got with family, friends, hunting, fishing, and just enjoying my blessings.
Offline HolmenTree
« Reply #6 on: August 29, 2015, 11:55:44 PM »
A 576XP  Auto tune is smoother and will pull a 32" b/c better then any 372.
The 576 AT has been around for over 5 years now and is a proven performer.
From my contacts info in the PNW  many timber fallers are replacing their 390XP's with 576XP AT's
No real difference  in weight between a 372 or a 576. The thicker top handle of the 576 fools a lot of people making them think it's heavier.
Offline celliott
« Reply #7 on: August 30, 2015, 12:35:54 PM »
I'm sold on autotune. If I were buying new, between those two saws I'd probably get the 576.
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Offline weimedog
« Reply #8 on: August 30, 2015, 02:46:31 PM »
Better than a 372xpw built at .020 squish? And do you think the 576 is going to be around in the Husqvarna product offerings for a while vs. the 372XT? I do agree they are smoother with more torque than any X-torq 365/372. Worked on a 575 a month or so ago, they were built heavy. Haven't worked on a 576 yet. I too am a fan of Autotune.  Wish Husqvarna didn't drop the 455 auto tune!  ::)
Offline Cut4fun
« Reply #9 on: August 30, 2015, 03:08:12 PM »
Most guys in the tree business seem to prefer the 576 over the NE 372 x-torx saws.
Just to compare PHO dry weights.
http://chainsawrepair.createaforum.com/husqvarna/husqvarna-pho-weights/
OE 372 the ones I liked.  14lb 3.5oz
385  16lbs 7.3oz
NE x-torx 372 xt 14lb 6.3oz
575 15lb  4.8oz
576  15lb 7oz
390 16lb 3oz
I ran a 576 non-AT demo saw when they first came out at one of my gtg's and they were ballsy in the cut  compared to stock 372.  In other words more torque.
Offline HolmenTree
« Reply #10 on: August 30, 2015, 09:52:28 PM »
The 576 Auto Tune runs even stronger then the 576 non AT.
Offline HolmenTree
« Reply #11 on: August 30, 2015, 11:25:41 PM »
385  16lbs 7.3oz
575 15lb  4.8oz
576  15lb 7oz
390 16lb 3oz
According to the offical Husqvarna website:
372XP XT  14.11 lbs
576 XP       14.55 lbs
576XP AT  14.99 lbs
390 XP       15.65 lbs
Offline JohnG28
« Reply #12 on: August 31, 2015, 08:21:17 AM »
Pretty sure C4F has all the weights posted right on the scale over on csr. Same scales used with pics to verify.
Offline HolmenTree
Offline weimedog
« Reply #14 on: August 31, 2015, 09:57:10 PM »
Wonder why that much weight difference on the AT vs. non AT
Offline HolmenTree
« Reply #15 on: September 01, 2015, 09:44:31 AM »
Micro processor , wiring  and hardware  probably add up. Not sure if they both have the same 2 barrel carb.
Here's  3 nice new 576XP Auto tune I had 5 yrs ago for the speed competition.
Offline Spike60
« Reply #16 on: September 02, 2015, 09:25:38 AM »
But a 372XPW at .020 can't be bought at his local dealer. 'course there's this guy in Cortland I know who can build one.  :)  576 and 372XT will ride into the sunset together in about 18 months or so when the new saw I can't talk about replaces them.
For a guy who hates vibration as much as you do, the 576 would be a Godsend. As smooth as your 555. This is almost a "forgotten chassis" for Husky. Guess I need to bring one up to the farm next trip so you can experience it, eh? (I did have a 576AT up there a few years ago the very first time I came up BTW.)  Willard's overall assessment is pretty accurate IMO.
Weight generalizations in this thread are a bit off. The 575 was indeed heavier and closer to a 385 than the original 372. But the 576 lost weight, while the 372XT gained weight and they are now pretty much the same in feel. (Except those vibes!).
Willard: Are those all G models on your tailgate? They have the low top air filter cover. (Which Walt has a thing for. LOL) The only G available in the states was the non-AT version. I did manage to score a couple 576XPGW's before they went away. Properly tuned, a regular 576 will stay with the AT, but the AT is obviously better at staying at the top of it's game.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline HolmenTree
« Reply #17 on: September 02, 2015, 10:10:24 PM »
Bob,  not G models. These are the very early 2009 units if I remember correctly.  I'm  with Walt I like the low top model too. Why does a saw that has the best air filtration on the market need a bigger air filter?
But I can see the HD filter high top being a good seller in the PNW where the 576 appears to have  received a good customer base. ... low top would look out of place matched up with those long bars. :D
Offline NH-Murph
  • Location: In New Hampshire... about 1/2 way up and all the way West
« Reply #18 on: September 03, 2015, 12:26:23 PM »
It's hard to beat the new and used factory and aftermarket parts availability for the good ol' 372xp....
Offline Cut4fun
« Reply #19 on: September 03, 2015, 08:19:43 PM »
385  16lbs 7.3oz
575 15lb  4.8oz
576  15lb 7oz
390 16lb 3oz
372XP XT  14.11 lbs
576 XP       14.55 lbs
576XP AT  14.99 lbs
390 XP       15.65 lbs
I should have said, weights posted are ACTUAL weights. Not wishing what they were on printed paper like you show from husky.  :D
Husqvarna 372xp Original Edition vs. 372xp Current Edition "X-Torq" Saws.
Started by weimedog on Chainsaws
Last post March 25, 2018, 04:00:48 AM
by knuckledragger
Used Husqvarna 372xp
Started by husky55guy on Chainsaws
Last post May 04, 2014, 12:24:34 PM
by SawTroll
Husqvarna 372XP
Started by dirtmod454 on Chainsaws
Last post February 25, 2012, 04:20:56 PM
by WildDog
Husqvarna 372XP
Started by xlogger on Chainsaws
Last post February 24, 2013, 10:54:12 AM
by cutter88
