Arborwear
Author Topic: What are you working on?  (Read 33022 times)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: What are you working on?
« Reply #160 on: July 10, 2016, 04:45:35 PM »
It's all done with smoke and mirrors. :D
Thanks. I always try to do the best I can.
Offline chopper2
« Reply #161 on: July 11, 2016, 09:27:27 AM »
how are the girts attached? I think that is the name.  The pieces that the outside boards are nailed to.  I have seen them mortised before, but in the earlier pictures I don't see any mortises for them.  Is there another way to attach them later?
Offline brendonv
  • Arborist
    • www.VorioTree.com
« Reply #162 on: July 11, 2016, 01:53:29 PM »
Post #133 is the door side, so no girts. Thats why ur not seeing the pockets.
"Trees live a secret life only revealed to those that climb them"
www.VorioTree.com
https://www.facebook.com/pages/Vorio-Tree-Experts-LLC/598083593556636
Offline chopper2
« Reply #163 on: July 11, 2016, 01:58:49 PM »
ok I get it now. not the same on both sides. thank you.
    • My homepage
« Reply #164 on: July 11, 2016, 03:45:17 PM »
No girts on the door side. There are door posts and headers in housings that were added after the fact. They would have been mortised in, had the fenestration been decided earlier.
Offline frwinks
« Reply #165 on: July 12, 2016, 12:39:41 PM »
looks like an awesome spot for a great looking barn 8)
    • My homepage
« Reply #166 on: August 03, 2016, 07:50:35 PM »
Not really a progres update, just a neat shot out the window of the barn.
Offline Greyhound
« Reply #167 on: August 03, 2016, 10:08:33 PM »
Working on a gate for the front porch to keep the dogs in.  White oak from my property we milled a few years ago.
    • My homepage
« Reply #168 on: January 08, 2017, 03:14:23 PM »
I haven't done any timber framing lately, so no new updates really. I had to plane the small door on the 16'x20' barn a little bit, so I took a winter shot of the barn. It's only 12 here now, but wasn't too bad inside out of the wind.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #169 on: January 08, 2017, 04:06:18 PM »
I'm continuously working on plans for this 36' x 62' Ag barn for a winery in California.
Hopefully I'll have them done very soon.
Jim Rogers
Offline logman
    • M&K Timber Works
« Reply #170 on: January 09, 2017, 01:38:08 PM »
I have 2 of these pavilions to cut.
LT40HD, 12' ext, 5105 JD tractor
M&K Timber Works
Offline brendonv
  • Arborist
    • www.VorioTree.com
« Reply #171 on: January 27, 2017, 02:45:20 PM »
Just a small frame. A warm up for my next project.
www.VorioTree.com
    • My homepage
« Reply #172 on: January 27, 2017, 03:30:41 PM »
Looks great!  :)
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #173 on: February 20, 2017, 12:03:07 PM »
Friday, I finished up a set of plans for a 16' x 32' grist mill building. The mill works will be separate from the mill building frame.
This frame will be raised in South Boston, VA at a historical museum site.
I hope to visit the site soon.
Jim Rogers
Offline Don P
    • Calculator Index
« Reply #174 on: February 25, 2017, 01:24:02 PM »
Jim,
I've been doing some consulting on the structure of an old mill here. It ran both coarse and fine millstones as well as 3 roller mills from an overshot wheel. The dam washed out in '61 but it has been kept in pretty good condition, we turned and cleaned out the wheel a few days ago by hand, bearings still good enough that one person could do it. There are a couple of gentlemen in the region up here that the family has consulted with on the machinery and those parts of the structure. I would like to visit when you come down if we can work it as well as put the owners and experts together if they are interested. You know how there are some accents you can pick out of a crowd, South Boston is one of those. Keep an eye on the old smaller stucco houses around there as well, a number of them are log cabins under all that mud.
Offline woodworker9
    • Elite Concrete Raising Co.
« Reply #175 on: February 27, 2017, 10:14:50 AM »
Jim,
If I may ask, how are the rafters attached to the tops of the walls on each side?  I am asking because I notice there are no cross ties from rafter to rafter.  What keeps the roof from sagging and pushing out the rafters?
Reason I ask is this is exactly how a horse barn/tack room was built on my property, and the rafters sagged pushed off the top of the walls over 70 years.
Thanks for the information and explanation in advance.
03' LT40HD25 Kohler hydraulic w/ accuset
MS 441, MS 290, New Holland L185
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #176 on: February 27, 2017, 02:34:57 PM »
In this case the rafters are secured to the top of the plate with two or three timberlok screws. The tongue and fork joint at the ridge also helps with strength.
This frame is only 16' wide and very low snow load. Metal roofing will allow any snow to slide off very soon, so "load duration" is very short.
Jim Rogers
Offline Don P
    • Calculator Index
« Reply #177 on: February 28, 2017, 08:03:05 AM »
The plates transfer the horizontal thrust from the rafters to the extended posts and then to the tie beams. This can get tricky.
I was enlightened on another aspect of mill construction the other day. The main components of a mill were carried independent of the mill building by a "Hurst Frame". A good description is here;
http://www.lousweb.com/Stover%20Mill/chapter_4part_1.htm
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #178 on: February 28, 2017, 11:07:19 AM »
DonP
Thanks for posting the link.
Jim Rogers
Offline Don P
    • Calculator Index
« Reply #179 on: March 02, 2017, 08:41:44 AM »
I happened upon this set of register drawings for a mill in AR, scroll down, click on one and then click for the viewer for the full set;
https://commons.wikimedia.org/wiki/File:Millstone_Assembly_of_Hurst_Frame_-_Boxley_Grist_Mill,_Boxley_vicinity_on_State_Route_43,_Buffalo_National_River,_Ponca,_Newton_County,_AR_HAER_ARK,51-PON,1-_(sheet_18_of_20).png
Another good resource for these old mills is Oliver Evans "The Young Mill-Wrights and Miller's Guide". I downloaded a 515 page pdf but neglected to save the link. This is from 1795 and through multiple reprints describes modern milling using elevators and conveyors driven by the mill rather than shoveling and hoisting from that time on to when the roller mills came into play. Difficult reading, I'm still wading. Engravings are at the end of the book starting around pg 470 followed by a list of subscribers who helped finance it I assume, Washington and Jefferson among the many names.
Working with trees services, and working and working...
Started by Daren on Urban and Community Forestry
Last post April 23, 2009, 02:01:44 PM
by chep
For all the hard working, "working class" folks out there.
Started by jjmk98k on General Board
Last post May 11, 2010, 07:19:21 AM
by Ianab
What I Have Been Working On
Started by Tree Feller on General Woodworking
Last post December 17, 2012, 11:07:43 PM
by Tree Feller
Working on the 4th
Started by highlandsaw on Sawmills and Milling
Last post July 13, 2014, 04:15:50 PM
by highlandsaw
