Author Topic: Sill to Post Joinery  (Read 3081 times)
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
Re: Sill to Post Joinery
« Reply #20 on: March 14, 2019, 01:53:56 PM »
Should I make the tenons and mortises also be located 1" from the reference surfaces too?
Yes offset 1"
Quote
And how much relish should I leave?
At least 1 1/2"
Quote
And as far as the pegs go is 3/4" too much or should I go with 1/2" diameters?
Follow standard rules 1/2" diameter; larger takes out too much wood and weakens timbers.
Quote
Won't the stub tenon in the post contact the tenon in that cross sill? Will the mortise in the long sill for that post's stub tenon break through to the mortise for that cross sill?
Yes, most likely the two mortises will connect but trimming the post stub tenon by 1/8" and the cross sill tenon by 1/8" will allow some room. Trim during fit up until they don't touch.
Jim Rogers
Offline pizza
« Reply #21 on: March 19, 2019, 04:55:42 PM »
thanks!
How to protect exposed half-lap sill joinery?
Started by sheneman on Timber Framing/Log construction
Last post March 18, 2009, 06:56:39 PM
by ARKANSAWYER
Securing post to sill
Started by bic on Timber Framing/Log construction
Last post June 26, 2016, 12:10:27 PM
by fishfighter
Sill with scarf joints over post foundation
Started by Rait on Timber Framing/Log construction
Last post April 01, 2015, 10:41:46 AM
by Rait
3 way post joinery
Started by bigshow on Timber Framing/Log construction
Last post May 16, 2007, 07:17:40 PM
by Jim_Rogers
