Author Topic: Heat box for sterilization help  (Read 6148 times)
Offline GeneWengert-WoodDoc
Re: Heat box for sterilization help
« Reply #20 on: December 04, 2017, 11:09:55 AM »
Heat in a kiln does not change the walnut structure.  You observations reflect differences in moisture content.
Offline losttheplot
« Reply #21 on: December 04, 2017, 06:27:19 PM »
Does the dehumidifier run ok at the higher temps?
[/quote]
Seems to, I've only put around 10 loads through it.
Its mostly Maple and Alder, the water comes out crystal clear and odorless.
I don't know how it would do with something like Oak.
I dont know if it has an over temp cutout.
I was quite surprised when I saw how hot it was getting in the Kiln.
I just set the dehumidifier to 35% relative humidity and let it do its thing.
I bought some temp/humidity meters, with the sensors on 6 ft of wire,  and put them at different places through the stack.
DON'T BELIEVE EVERYTHING YOU THINK !
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #22 on: December 04, 2017, 10:10:23 PM »
Thank you to all who took the time to contribute to this topic.  As I have said before, this sawmill hobby has become a slippery slope with a learning curve.
Caveman
Offline mike_belben
  • Pulp Friction
« Reply #23 on: December 05, 2017, 05:02:17 AM »
Have any of you quantified what kind of money youre spending on these kilowatt hours?  Are they as expensive as it sounds?
Im surprised that with the proliferation of outdoor wood boilers being fed slabwood, that they dont go hand in hand with kiln chambers.
Revelation 3:20
Offline E-Tex
  • Rather be Saw'n or Fish'n
    • www.L2Sawmill.com
« Reply #24 on: December 06, 2017, 12:08:01 PM »
I built a 4 ft by 4 ft by 16 ft box out of used 4 ft by 8 ft by 4 inch Styrofoam sheets.
Its wrapped in 6mil Polly and sealed with tuck tape when its full.
With 2 fans and a 70 pint dehumidifier it gets up to 140 +/- degrees.
No auxiliary heat.
Air dried wood takes less than a week to get the remaining water out of it.
I put some spalted maple in it, that was full of white grubs.
The bugs turned to powder.
how does it get this hot without additional heat source?  Does the dehumidifier have a heat source in it?  is it the process of the water leaving the wood?
And is it staying at the 140+/- constantly?  Thx.
LT-50 Wide, Mahindra 6065
L2 Sawmill LLC
Online fishfighter
« Reply #25 on: December 07, 2017, 05:46:08 PM »
We need some pictures of that sucker. 8)
Offline losttheplot
« Reply #26 on: December 07, 2017, 08:30:27 PM »
I bought the Styrofoam from a neighbour for $10 a sheet.
The sheets are stitched together with old chainsaw files and the inside joints were sprayed with a can of expanding foam.
For the first couple of runs I used borrowed box fans made from plastic. They work fine but I had to give them back so I bought a couple of attic fans from Amazon.
I got some temp/humidity meters from e-bay and placed them through out the stack, as long as I load it "loose" it does fine.
If the plastic vapor barrier is not sealed tight it will never stop putting out water, as it will suck in air/humidity.
It takes a couple of days to warm up and a few days to cool down.
I leave the wood in there untill I need it, keeps it dry.
I got fed up with making stuff for the house with air dried wood, then having it warp and shrink. We heat with a wood stove which makes the house very dry.
I put 6 and 8 inch Douglas-fir flooring in the house, the boards right in front of the stove have shrunk a tiny bit, the rest shows no sign of shrinking.
14 inch red Alder just went in so I will see how it does.
Online fishfighter
« Reply #27 on: December 11, 2017, 08:18:05 AM »
Outstanding and thanks for the pictures. I will start looking for parts that I will need to build a box like yours. ;D
Online Southside logger
« Reply #28 on: December 11, 2017, 10:46:31 PM »
I am curious,  have you run it with wood which was pretty green?  Just wondering how long it took to dry it out and what the quality turned out to be.  That is a great set up!!!
Offline losttheplot
« Reply #29 on: December 13, 2017, 07:19:29 PM »
I have never tried it with green wood.
If I was gonna try, I think I would sticker stack it in the kiln then leave it open on the ends and just run the fans for a week or two first.
That is just an assumption and you know what they say about those  :) :) :)
« Reply #30 on: December 13, 2017, 10:42:13 PM »
My gosh that is some awful purdy wood there!!  Really held it's color.
« Reply #31 on: December 14, 2017, 04:16:57 PM »
For a fast drying wood, like pine and poplar, leaving the kiln open and blowing air through the pile and then having itexit (single pass dryer is the technical name) can be very efficient.  Run the fans when the humidity is under 90% RH only.  Higher humidity will waste electricity and achieve little drying.
For harder to dry woods, if they go into the kiln green, then keep the vents fairly much closed so you control the humidity inside at a high level, which will give you slow drying and high quality.
For white woods like hard maple, aggressive air drying, protected from rain, will get the whitest color.
Online fishfighter
« Reply #32 on: December 19, 2017, 07:54:08 AM »
So, I been kicking a few ideas around in my head for a sterilization box.
Building it like the OP's box, but adding even more heat by using stove heating elements. Reason is that down here in the south, the humidity runs high about 95% of the year above 70%.  Using the stove Tstat and controls, I think I could get it dialed down to about 150F. With a dehumidifier in the works, that just might speed things up some.
Am I thinking this would help out or am I wrong? Like I said, just kicking this around. ;D
« Reply #33 on: December 19, 2017, 10:22:47 PM »
We are concerned about the average relative humidity.  A good source of values, in terms of EMC is
www.woodweb.com/knowledge_base_images/zp/equilibrium_moisture_content.pdf
As an example, in July, Alexandria, LA has 15% EMC which is about 75% RH average for the month.
Online fishfighter
« Reply #34 on: December 20, 2017, 06:34:21 AM »
Hey, thanks. ;D
Offline kelLOGg
« Reply #35 on: December 25, 2018, 06:19:50 AM »
Don't know if you ever got an answer so here's mine. The heat gain comes from the resistive motor windings of the compressor. (If I turn the DH unit off and leave the circulating fans on I can still get a heat gain due the same principle). The evaporation and condensation of water inside the kiln yields a net heat gain of zero so there is no help there.
I used to run my kiln up to 140F and the unit lasted about a year. Home DH units (as mine is) aren't designed to operate at that temp. Now I try to keep it under 100 and just wait longer. OK for a hobby.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline farmfromkansas
« Reply #36 on: December 28, 2018, 11:53:53 AM »
 Thinking this would be great in my store room.  Is the styrofoam the blue dow board foam?  I have a few sheets of 1" and now they are selling 2" at Menards. Probably would have to use a few boards and some kind of long screws with big washers to put this together.
« Reply #37 on: December 30, 2018, 12:52:32 PM »
Not all foam boards are the same with respect to their durability to heat. Some disappear at 130 F.  Check the temperature rating if used for a kiln.
« Reply #38 on: January 01, 2019, 09:46:27 PM »
Just looked up blue Dow board.  Appears dow board will only handle up to 160 degrees.  The foam pictured in lost the plot's pics must be of another type.
Wood Sterilization Options
Started by Bhutt123 on Drying and Processing
Last post January 20, 2018, 07:41:59 PM
by Hot Shot Rob
Sterilization Cycle Really Works
Started by YellowHammer on Drying and Processing
Last post November 09, 2013, 10:15:33 PM
by WDH
Very small scale sterilization
Started by nybhh on Drying and Processing
Last post December 24, 2018, 10:41:19 AM
by Southside logger
Sterilization Experiment in Solar Kiln
Started by btulloh on Drying and Processing
Last post June 06, 2018, 04:33:55 PM
by btulloh
