Making Pellets For Pellet Stoves
Started by GF, September 29, 2004, 07:33:31 AM
GF
Has anyone built a low end pellet processing machine for pellet stoves that would use sawdust from there sawmill?  Curious if anyone has attempted this, with the rising cost of propane etc the thought has been bouncing around in my head to attempt this.   :o
Murf
Pellets that you buy are almost always 100% hardwood, not just for burn quality but because if your fuel supply was constantly changing throughout the fuel charge, you would need to constantly vary the feed rate to accomodate the different BTU outputs.
If you produce very much sawdust, you can often make a deal with some local producer, they take your sawdust and pay you in pellets. Even if you only cut softwood, there is a market for that too for animal bedding and such.
Best of luck.
GF
I pretty much cut white oak and red oak trees.
Buzz-sawyer
i ran a pelletizing plant at one time, in our operation we used a large upright PAN and spun in varying speeds to get different sized pellets, we used esentially MARMALITE stuff to bind them together then conveyed them through a oven dryer............(we pelletized lime dust but I would think it would be the same regardless of the powder/dust used in proccess. :)
    HEAR THAT BLADE SING!
FiremanEd
GF,
I've been looking for the same thing with no luck. If you find anything let us know.
Timber Harvester has a press that produces 2.5" discs that have been pressed through a tapered pipe to 40,000psi per their guy at the Richmond Expo this May. I asked them what the market was for the product.... "uh,,,," was the response. Any ideas anyone?
Full time Firefighter / Paramedic
WoodMizer LT300 as secondary, full time job.
AccuTrac Electric Edger
slowzuki
The lignin (sp?) in the wood fibre is the bonding agent.  The correct moisture content is obtained by steam injection.  The pellets are extruded through a die and break off at the right intervals when the moisture level is correct.
I can't remember the pressures they used, but high!
Ken
GF
So it sounds like I need to create a die along with some high pressure to extrude, sounds like a job for my metal lathe and milling machine, and some hydraulics.
raycon
http://www.pelletheat.com/howto.htm
The link shows no details but has pictures  ;D
Extrusion (screw),die and shear and you have pellet making capacity?
I had an old brown and sharpe universal mill we set up to make an extrusion screw once (thermoplastic) it was'nt that big a deal to hog it out once we figured out what we wanted. If you go down that route I have a design guide somewhere (extrusion screw).
Lot of stuff..
GF
Ray,
   I sent you a message about the design. Thanks
FiremanEd
I tracked down the manufacturer of the machine I saw in Richmond this spring. It's sold by HighPoint who mainly makes/sells moulders, edgers, resaws etc and sell in conjunction with Timber Harvester.  www.highpointinc.com
They currently have two machines. One produces 2.5" logs like those you can get for a fireplace and the other produces the same diameter product that breaks off into hockey puck sized hungs of compressed sawdust. Both will burn in a regular wood stove. They did say that I was the 10th or 11th person to call in the last month asking about a machine to make the normal pellet stove pellets. They are looking into modifing their existing machines or building another from the ground up. No word on an ETA but he's supposed to call me as soon as they have something.
If/when I get a call I'll pass it on to everyone here.
Fla._Deadheader
  Just how big ARE them pellets??? Saw sumpin on the toob a few minutes ago, that MIGHT be whatcher lookin for ;D ;D ;D
Jason_WI
My uncle has a 100 ton hudraulic press. I could make a die and press out one at a time :D :D With the amount of sawdust that I make I would surly freeze this winter... ::)
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
GF
Might have to come up with something to heat with, propane is Oklahoma from one vendor I checked it $1.75 gallon, and its stil in the 70's and 80's, nights in the 50's to 60's.
GF
FiremanEd
   Let us know when you find something out.
Fla._Deadheader
STILL ain't heard how BIG them pellets are ??? ???
Haytrader
I'll betcha the same equipment used to make cattle cake would make wood pellets.
I just contracted 25 ton of 5/8" cake for my cows.
Here they have 3/4", 5/8", 3/8", and 1/4" dies for the pellet mill.
http://www.aaronequipment.com/inventory.asp?stockNumber=68710&categoryID=50&subcategoryID=26
Here is a used mill for sale.
Sprout Waldron is one name I remember making mills.
All kind of equipment here.
http://www.ex-factory.com/NonFrames/WH.htm
Haytrader
Murf
The big problem is going to be fuel quality.
My brother-in-law (outlaw??) has a corn stove, and if the corn is a little dusty or has much in the way of debris in it the whole fuel delivery system goes south and the thing just shuts down.
I also know a few people with pellet stoves and it's exactly the same, if there is even a little sawdust or a few stray chips in there, even a good sized sliver, the whole operation stops.
I wouldn't want to try to use it as the primary source of heat if it was a little tempermental.
Fla._Deadheader
  For what it's worth, I saw a "pasta" machine that took a slurry mixture and compressed the Spaghetti strings through the die. There was a 4 legged cutter, like in a meat grinder, that turned against the bottom of the die and cut the strings to length. It was adjustable for different lengths. They were making fish feed pellets. ;D ;D
  They said the pasta machines were not used much anymore. Should be able to find 1 or 2 pretty easy ???
Buzz-sawyer
Im thinkin a low pressure press of some sort would make pellets if you used a binder........a liquid of some sticky sort and made doough and let it dry....... ??? ??? ???
Ron Wenrich
Anybody up for some reading?  :P   Seems that there is some info done on this by the Department of Energy -  A handbook for small-scale densified biomass fuel (pellets) manufacturing for local markets.
Here's the link:  http://www.osti.gov/energycitations/product.biblio.jsp?osti_id=10115219
PDF file with 7714K  I'm downloading mine right now.
This hasn't got anything to do with anything, except the subject of this thread keeps reminding me of my Granddaddy.
He believed that, once you reached a certain number, it didn't matter if you could accurately count any higher or not since those numbers were so big that they no longer registered in your mind.
units, hundreds, thousands, ten thousands, hundred thousands, millions, billions, goat pillions, rabbit pillions, ...
Course, now we hear the government use trillions pretty regularly but I still can't conceive of the number. :D
VA-Sawyer
Ok Tom, let's see if I can put this in perspective for ya.....
If you had a thousand Millionairs and they put all their money in one spot, it would be a billion dollars.
To get yourself a TRILLION dollars... you would have to bleed a Million of them Millionairs bone dry !  :o
VA-Sawyer
