Author Topic: stihl ms661  (Read 2148 times)
Offline 630red
stihl ms661
« on: October 16, 2015, 07:19:59 PM »
hi guys great info on here would like some advice,does the ms661 need 5min wot in wood to break it in?
Offline ZeroJunk
Re: stihl ms661
« Reply #1 on: October 16, 2015, 07:28:16 PM »
I don't know that it needs any break in at all, but 5 minutes isn't going to do anything.
Some think they pick up a little compression and power after a few tanks of fuel.
We may be talking about two different things. If you are talking about the electronic fuel control adjusting itself then maybe so.
If it is the latter the manual says 5 uniform cuts at full throttle.
Offline Texas-Jim
Re: stihl ms661
« Reply #2 on: October 16, 2015, 07:37:39 PM »
The saw should be kept under 85% power for first couple tanks. Im going from memory so i think thats right.
What we do in life echoes through eternity.
Offline 49er
Re: stihl ms661
« Reply #3 on: October 17, 2015, 09:32:45 AM »
I don't understand?
The fuel control can never calibrate itself unless at wide open throttle.
Husqvarna EC390 365xt
Jonsered 2188 2165 2260 2253 70e
Redmax GZ4000
Offline Spartan
Re: stihl ms661
« Reply #4 on: October 17, 2015, 02:47:28 PM »
Run it the way you will when you work right from the get go.  I run my saws hard and have never done a break in procedure, they are all fine.
I consider some stuff just paranoia
Offline Texas-Jim
Re: stihl ms661
« Reply #5 on: October 18, 2015, 08:16:36 PM »
oops sorry i mis spoke, if look at manual on page 40 there is a break in section. It says shouldn't be ran at high revs (unloaded) for first three tank fulls. There is no other break in procedure.
Offline Kingmt
Re: stihl ms661
« Reply #6 on: October 18, 2015, 11:40:01 PM »
My MS660 had a tag on it that said not to run at WOT for the first three tanks & never run it at WOT not under load.
Sawmill=Harbor Freight Item#62366
Chainsaws=MS180CBE(14"), MS290(18"), MS038(20"), MS660(20" & 36")
Staff=1Wife & 5 Kids :)
Please excuse my typing. I don't do well at catching auto correct.
Offline HolmenTree
Re: stihl ms661
« Reply #7 on: October 19, 2015, 07:23:55 AM »
Looks like all the info 630red needs is right here.
Mounting Cannon S2 (big Stihl) 42" bar on MS661 (small Stihl)
Started by neildorin on Chainsaws
Last post September 11, 2017, 06:01:44 AM
by Al_Smith
Stihl MS661
Started by sweetjetskier on Chainsaws
Last post November 10, 2013, 06:16:31 PM
by IndianSprings
Largest bar available for a Stihl MS661?
Started by randy_atx on Chainsaws
Last post January 28, 2018, 02:47:06 AM
by Jesper Jepsen
Stihl MS261 - MS661 bar compatibility
Started by George Zarifis on Chainsaws
Last post October 20, 2015, 12:43:36 PM
by George Zarifis
