Author Topic: ???Loader???  (Read 707 times)
Offline JB Griffin
???Loader???
« on: October 25, 2015, 08:44:22 PM »
Has anyone seen a loader like this before? Not a Waldon but similar and bigger. Has a Perkins diesel, hyd drive like a bobcat(no brakes) 4x4, owner thinks its a late 70's-early 80's model.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline JB Griffin
Re: ???Loader???
« Reply #1 on: October 25, 2015, 10:33:18 PM »
I might add that the owner said that it will pick up a 3/4ton(5-7k) truck easy and he thinks it might weigh around 10k lbs with the foam filled tires that are on it.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: ???Loader???
« Reply #2 on: October 26, 2015, 10:20:19 AM »
It looks kind of like an Omni.
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
Re: ???Loader???
« Reply #3 on: October 26, 2015, 11:50:23 PM »
The construction details are different but the size and configuration are very similar to the Cat 910 loader I use. It's a great machine for a small sawmill operation.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Wanted log loader trailer or truck mounted loader
Started by 03westernstar on Wanted
Last post October 09, 2014, 02:13:42 AM
by backwoods sawyer
Which log loader to buy
Started by hobby logger on Forestry and Logging
Last post November 08, 2010, 09:33:06 PM
by firefighter
The no name loader
Started by yukon cornelius on General Board
Last post June 08, 2017, 12:12:50 PM
by coxy
Can you ID this loader
Last post November 27, 2016, 07:34:29 AM
by yukon cornelius
