Author Topic: Rebuilding 18 volt batteries for cordless tools.  (Read 7850 times)
Offline John Mc
Re: Rebuilding 18 volt batteries for cordless tools.
« Reply #80 on: September 09, 2018, 10:34:49 PM »
Backfeeding a Nicad battery does two things:
  • it may "wake the battery up enough that the charger for that battery will now recognize it and at least make an attempt to charge it up
  • When back feeding, it works better to do a few brief "zaps" rather than one long one: connect for a 2 seconds, disconnect, connect for 2 more second, etc. Do that maybe half a dozen times (or more if you are backfeeding with a lower voltage source). Doing this makes a sort of square wave feedin ginto the battery that can break up internal pathways that have formed and may be creating a partial short, draining the battery.
My electrical engineer friend had me use the above technique and hook up two 12 volt car batteries in series (to make 24 volts) and use that to back feed (connect + to + and - to -) my 18 V nicad tool batteries. It worked on a couple of them. The ones that it did not work on, he had me open up and use a single 12V car battery to back feed each individual cell. Doing individual cells is much more effective than trying to do the whole pack at once, but it's more of a hassle, so worth seeing if you can resurrect the battery without disassembling it first.
He also strongly recommended NOT trying to resurrect Lithium-Ion batteries back feeding them with a higher voltage. He aid you really just want to use their regular charger on them. You might get away with it, but if you don't, lithium-ion sometimes just won't take the abuse, and the results are "not pleasant". (He did admit to knowing a lot more about NiCad than LI-ion, however.)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #81 on: September 10, 2018, 01:42:34 AM »
In the case of the Milwaukee chargers, if they don't see a minimum voltage, they won't charge. If a battery was left in a cold environment for a long time at a low charge, it can drop below that voltage. Normally the battery shuts off before it is too low to recharge, but long term storage or cold can drop it down. If this is the cause of not charging, the solution I've seen on YouTube, use at your own risk  ;), is to hook up a good, fully charged battery for a few minutes to get the dead battery over the threshold voltage. If you have a battery with a bad cell, then this won't work, and you may have a fire. I have one battery that was about 15v, and just needed a couple of volts to bump it up. The others were only 2-3 volts. They are junk.
After considering the risks, time, and expense of messing with old batteries, I've decided not to bother with them. I've also ended up with so many newer, larger batteries, it became a non issue.
There are a few more batteries and chargers not pictured. Four M18 chargers,  five Rapid Chargers, and 18 batteries (7-9.0ah) later, I seem to have enough:
Offline John Mc
« Reply #82 on: September 10, 2018, 08:06:03 AM »
The Interstate Battery store near me will rebuild NiCad batteries, but they won't touch Lithium-Ion. From what I undertand, their insurance company has a fit about working on LI-ion batteries. They don't know if that is over concerns about some danger in working on them, or the liability if you were the last one to work on a LI-ion battery and it goes up in flames sometime later while in use or storage (same concerns the airlines have about bringing those batteries on board).
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #83 on: September 10, 2018, 09:08:28 AM »
Banjo, is that a Lithium Ion or a NiCad battery?
They are all NiCads  I checked them this morning and two are extremely low.  They may have a bad cell, but if I have save half of what I started with, I consider it a win.
Dave with that many batterys and chargers, you may want to seek out a counceling group. :D Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #84 on: September 10, 2018, 09:20:48 AM »
Dave I'm impressed you know how many batteries and chargers you have :) 8) :) ;D ;D
Offline Ianab
« Reply #85 on: September 10, 2018, 03:53:05 PM »
Why you don't mess with Lithium batteries. The lithium is so reactive that it burns in almost anything, including water. If you short one out and it catches fire....
Offline ljohnsaw
« Reply #86 on: September 10, 2018, 04:44:57 PM »
Backfeeding a Nicad battery does two things: it may "wake the battery up enough that the charger for that battery will now recognize it and at least make an attempt to charge it up When back feeding, it works better to do a few brief "zaps" rather than one long one: connect for a 2 seconds, disconnect, connect for 2 more second, etc. Do that maybe half a dozen times (or more if you are backfeeding with a lower voltage source). Doing this makes a sort of square wave feedin ginto the battery that can break up internal pathways that have formed and may be creating a partial short, draining the battery.
Way back (mid-70's) I was into Remote Control (R/C) airplanes.  NiCad was the best we had and they were expensive.  You had to maintain those batteries year round.  If you didn't, they built up the internal shorts, ruining the battery.  An old R/C magazine had an article about zapping them back to life.  I made one.  Basically a large capacitor bank (about 3,000 mfd) that you would charge up with a 4 or 5 vdc source (IIRC).  You would place a AA battery in the holder that had a VOM attached to it.  You would then press a momentary switch a few times and watch the VOM to see if the battery would hold volts.  The ability of the capacitors to dump a LOT of amps of lower voltage is what did the trick.  It worked quite well!
John Sawicky
Online Don P
    • Calculator Index
« Reply #87 on: September 10, 2018, 04:54:27 PM »
I've also charged up failing battery packs then open them up, disassemble the jumpers from each cell and find the bad ones. I've taken 2 failing packs and made one decent battery. You can also buy those sub C batteries online and refurbish a pack that way.
Offline 78NHTFY
  • I'm old!
« Reply #88 on: September 10, 2018, 08:42:56 PM »
Don P--have done the same.  Now have three working Ryobi and two DeWalt 18 volt batteries.  Cost of the generic 18 volt batteries is about $ 13 ea.  A little soldering and it's a lot cheaper than $ 50 plus per new battery.  Youtube is good for stuff like that....All the best, Rob.
If you have time, you winů.
Cordless Tools
Started by clintnelms on General Woodworking
Last post August 24, 2016, 11:38:30 AM
by clintnelms
28 Volt Battery Power Tools
Started by Kirk_Allen on General Board
Last post January 14, 2005, 10:11:49 AM
by Weekend_Sawyer
Makita Cordless (18v X 2) Chainsaw & compatable tools
Started by mredden on Chainsaws
Last post March 16, 2019, 08:07:03 PM
by Bthomasb3
Ryobi cordless tools - Good or bad luck?
Started by Saki on General Board
Last post December 08, 2006, 11:19:26 PM
by brdmkr
