cat 931 transmission problem
Started by 350 cummins, November 15, 2015, 07:10:24 PM
350 cummins
hoping someone can point me in the right direction, have a cat 931 loader sometimes when you start it, it works properly and the next time you start it the transmission won't drive (will move forward a little but no reverse) has anyone had this happen or know what might be wrong
thank you
clark 662   john deere 440B   '52 D47U      '7? michigan 75IIIA    JCB 214   '71 KW 8v71    '8? Rounder L700   Lumbermate 2000  '78 Chev C65  Hitachi EX60     cat 931 '90 L800 w/atlas picker    IH TD5 loader       central boiler dealer   range road firewood processor dealer
coxy
I have almost the same thing in my 518 you can run it all day good if you shut it off leave it set a few min start it up try to go no go rev it up a few times then it will go with no trouble I don't know if there is a charge pump in a cat tranny but as long as it keep going im not fixing it  :)  have you tried new filters
350 cummins
new filters, pump rebuilt, cleaned suction screen, o-ring on cover
no change with anything that we have done
not sure what to try next
treeslayer2003
does it have spring applied trans brake? could be a problem, my IH did that once but turned out to be a week charge pump. if it weren't for the brake holding i would not have known any thing was wrong.
