Author Topic: Maintenance time  (Read 1031 times)
Offline SasquatchMan
  • Get it done.
Maintenance time
« on: October 05, 2004, 05:33:29 PM »
What kind of time do y'all put in for cleanup, sharpening, check-up kind of stuff, say for an average day of cutting?  Or what's the typical run-hours/maintenance-hours ratio?
Senior Member?  That's funny.
Offline Frickman
  • Ouch, that hurt!
Re: Maintenance time
« Reply #1 on: October 05, 2004, 07:32:29 PM »
If I ran the saw all day I'll typically spend about thirty to forty-five minutes. That's cleaning, sharpening, and getting ready to go for in the morning.
Offline rebocardo
  • Atlanta GA
« Reply #2 on: October 05, 2004, 10:30:06 PM »
About 1/2 an hour per saw, greasing, cleaning, doing the air filter, etc.
Then for sharpening, 1 hour per chain on average for a 28" full comp chain. I usually use 4+ chains in one day, so I have to plan around which chains I am going to sharpen for the next day because I only have 12 (5 ripping and 7 cross cut).
I have had days where I had to quit early because I ran out of chains. Once a chain starts to dull and or gets hot, I swap it out on the next gas/oil fill.
I have found the presidential and vice president debates excellent times to catch up on sharpening.
Offline DanManofStihl
  • Cut em down Dan
« Reply #3 on: October 06, 2004, 06:17:21 PM »
I ususally just sharpen the chain and clean it off reall well clean the air filter and and do other minor stuff to it. It all depends on what I do with the saw how long i use and and what I use it for ae sticky pine juice and so on.
Two Things in life to be proud of a good wife and a good saw.
Time for some maintenance
Started by moosehunter on Sawmills and Milling
Last post January 10, 2019, 10:23:45 AM
by moosehunter
question
Bar Maintenance
Started by Larry on Chainsaws
Last post December 25, 2007, 03:08:18 PM
by SawTroll
Bar maintenance
Started by jargo432 on Chainsaws
Last post March 18, 2014, 03:51:52 AM
by LeeB
How often engine maintenance?
Started by shinnlinger on Sawmills and Milling
Last post November 13, 2008, 02:25:33 PM
by submarinesailor
