Arborwear
Author Topic: Band lub below 32 degrees  (Read 2029 times)
Offline mapletree
« on: November 22, 2015, 12:11:08 AM »
What is the best lub for a band blade below freezing?
Offline redprospector
Re: Band lub below 32 degrees
« Reply #1 on: November 22, 2015, 12:59:11 AM »
That's kind of like asking everyone what their favorite beverage is. You're going to get a lot of different answers.
Personally, I like diesel year around.
Offline Andries
  • Making buildings out of big curvy logs
« Reply #2 on: November 22, 2015, 01:20:07 AM »
Windshield washer fluid.
Rated for -40 degrees.
. . . . 'cause thats what works here.
(We're North of Normal)
LT30G24
Ford 545 Series loaders
Stihl chainsaws
Offline bkaimwood
  • Life's too short to sweat the small stuff
« Reply #3 on: November 22, 2015, 06:25:35 AM »
Wondering what ratio you use redprospector, if any?
bk
Offline Joe Hillmann
« Reply #4 on: November 22, 2015, 07:07:06 AM »
I use a winter blend diesel.  And when that gels up I take that as a sign it is too cold to run the mill
Offline drobertson
« Reply #5 on: November 22, 2015, 07:09:10 AM »
same here, and I still add a shot of pin-sol with it as well,
Offline ladylake
« Reply #6 on: November 22, 2015, 07:19:21 AM »
 Diesel, a drop every 2 or 3 seconds.   Steve
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: November 22, 2015, 08:06:28 AM »
Check out the chart in Spark's download attachment..
Offline mapletree
« Reply #8 on: November 22, 2015, 09:02:34 AM »
Thank you for the replies.  I had not thought about windshield washer.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #9 on: November 22, 2015, 09:08:08 AM »
I've been running straight windshield washer. I don't usually run much lube on fresh wood. Resawing usually gums things up, however.
Offline justallan1
  • living and learning
« Reply #10 on: November 22, 2015, 09:29:48 AM »
I find windshield washer fluid when it's on sale at Walmart for $2 and add a couple glugs of Pinesol for good measure.
When I'm sawing pine and find a pitchy log I take it off the mill and call it firewood. It's just not worth the hassle and time to mess some of them for me.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #11 on: November 22, 2015, 10:02:06 AM »
75% diesel and 25% bar oil here, year round.  Works great.  And, like ladylake, 1 drop every 2-3 seconds.  Quiet and clean and uses much less that you'd ever think with no staining of the wood.
Offline ladylake
« Reply #12 on: November 22, 2015, 10:17:17 AM »
 Running diesel in the winter is a lot cheaper than washer fluid , takes at the most 1/2 gal per day and it keeps the blade real clean.  Steve
Offline samandothers
« Reply #13 on: November 22, 2015, 10:23:21 AM »
I fall in the windshield washer group.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #14 on: November 22, 2015, 06:27:39 PM »
mapletree, what kind of mill do you have?  If you run one with solid steel wheels the diesel won't hurt a thing.  I have a cooks with metal band wheels, and I use diesel.  If I run one that had belts on the wheels, I would probably reconsider and use something else.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #15 on: November 22, 2015, 07:37:49 PM »
     It only gets below freezing here enough most winters to be a pita.  But if I don't pay attention I can crack a lubemizer pump, and that's a REAL pita!  WW fluid in the wintertime.
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #16 on: November 22, 2015, 09:01:54 PM »
In the Winter, I purge my Lubemizer pump with pure WW fluid.  Our available WW fluid is usually 0 which is OK straight but not so much diluted.  RV-Marine fluid is -50 so it is my choice for diluting.
Of course, our cold is not as cold as the frigid glaciated regions.  :o
« Reply #17 on: November 22, 2015, 09:35:20 PM »
I just run straight diesel. I used to run some bar oil mixed with it, but really haven't noticed any difference since I quit doing it. If it gets cold enough to gell the diesel, add a little heet, or power service to keep it flowing.
To the guy's using windshield washer fluid, look into buying it by the drum. I use it in my skidder tires. The last I bought was under a buck a gallon (can't remember exactly, but like 80 cents a gallon). I bought winter blend concentrate. You'd have to water it down some to keep from turning everything blue, but at 50/50 it didn't freeze when we hit 27 below a couple of years ago. Just food for thought.
Offline Napoleon1
« Reply #18 on: November 22, 2015, 09:55:35 PM »
if you use windshield washer fluid you need to find a auto detailer and buy the concentrate by the gallon it will make quite a few gallons cheaper.
Offline Grizzly
  • I wanna go camping!
« Reply #19 on: November 22, 2015, 10:26:17 PM »
Yep. I can't seem to find WW fluid or RV anti-freeze for less than $2.50/liter and I can buy diesel for $1.14/liter
 :D :D  Only for 8 months of the years! After that we have fairly poor sledding for the summer........... ;D
2011 - Logmaster LM-2 / Chinese wheel loader
Jonsered saws - 2149 - 111S - 90?
Cooks Cat Claw & Dual tooth setter
2000 Miners 3-31 Board Edger
33 degrees at 2 am!
Started by Woodhauler on Forestry and Logging
Last post February 16, 2013, 05:05:31 AM
by Woodhauler
22.5 degrees?
Started by Osric on General Woodworking
Last post November 24, 2007, 12:13:38 PM
by treecyclers
school me on degrees
Started by dustyhat on Sawmills and Milling
Last post November 24, 2015, 01:08:08 PM
by cwimer973
The joy of sharping chain at 10 degrees
Started by alsayyed on Chainsaws
Last post July 24, 2007, 06:35:59 PM
by Tony_T
