Arborwear
Author Topic: Band lub below 32 degrees  (Read 2013 times)
Offline bkaimwood
  • Life's too short to sweat the small stuff
Re: Band lub below 32 degrees
« Reply #40 on: November 28, 2015, 06:02:16 PM »
MM....maybe you should have a speed limiter on that rig! :) Atleast put a block under the pedal!!
bk
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #41 on: November 28, 2015, 06:56:44 PM »
I had not taken the time to clean out the fender slot, so it was riding high.  I saw it in my rearview mirror and maybe heard the racket when it went cartwheeling into the air.  Maybe the wheel ran over it?  Anyway it took some serious "blacksmithing" to kinda make it fit again.   :-\
Note to self:  (Always clean the fender slot and connect the bungee.)
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #42 on: November 29, 2015, 01:12:25 PM »
Once I got to a job and a fender was missing.  An hour or so later the customer's wife came back with Dunkin Donuts for everyone and also a fender for me.  She said it sort of looked like my mill so she picked it up. It was fairly mangled which so that was a sideways compliment,  but it went back on ok anyway.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #43 on: November 29, 2015, 04:50:18 PM »
Wow.... That was not a blonde...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #44 on: November 29, 2015, 07:26:03 PM »
What's this bungee you speak of Lynn?
Guess I've just been lucky, never used a bungee, never lost a fender!
~Chuck~
I LOVE MY SAWMILL
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #45 on: November 29, 2015, 07:59:17 PM »
     My original fenders had one rubber bungee to hold 'em in place.  the new ones have two. (Yeah...  I've had a couple of "incidents.")
     I will say that a blowout at 70 mph will make your fender do bad and wondrous things, and you won't like the results. :(  That bungee cord wasn't no more than spit on a housefire.
WoodMizer LT50HDD51-WR
Lucas 1030 w/slabbing attachment
Offline flatrock58
« Reply #46 on: November 29, 2015, 08:10:51 PM »
Had a blowout when I was on the way home from buying my mill.  The fender took a direct hit.  I persuaded it back to it's near original form.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Piney Woods modified Dual tooth setter.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #47 on: November 29, 2015, 09:08:22 PM »
Mine originally had ball bearing loaded pins, but moisture and rust was never kind to them, plus they had a sneaky way of hiding.  The black bungee works fine and I have the hook on the fender end bent to prevent it's escape.
Offline Chuck White
« Reply #48 on: November 30, 2015, 07:21:20 AM »
Maybe I should make provisions for securing my fenders with a little more than gravity!
But you're right, if you don't get the fender pockets cleaned out, that shortens the security of the fender!
~Chuck~
I LOVE MY SAWMILL
33 degrees at 2 am!
Started by Woodhauler on Forestry and Logging
Last post February 16, 2013, 05:05:31 AM
by Woodhauler
22.5 degrees?
Started by Osric on General Woodworking
Last post November 24, 2007, 12:13:38 PM
by treecyclers
school me on degrees
Started by dustyhat on Sawmills and Milling
Last post November 24, 2015, 01:08:08 PM
by cwimer973
2 or 4 year degrees, what do you recommend?
Started by dustyjay on Forestry and Logging
Last post April 15, 2015, 06:50:33 AM
by SwampDonkey
