Anudder Question
Started by Fla._Deadheader, October 06, 2004, 05:57:34 PM
Fla._Deadheader
 Where can a feller find some strips of Cherry veneer??? I need some to make some 11" dia X 2" high X 4ply hoops. I worked in a furniture factory in Arkansas, and could get random strips there. Don't have any now. ::) ::)
Gilman
Deadheader,
Rockler Woodworking has some.  I've ordered from them numerous times and they've always been professional.
http://www.rockler.com/ecom7/search_results.cfm?filter=veneer
Speaking of photos, you have one of your hoops you discribed?  What do you use them for?
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Fla._Deadheader
Secret project  :D :D  thanks for the info. I was hopin to find someone that could supply remnants from a factory. ;D
Check with our Veneer member?
Fla._Deadheader
No, I believe he just makes thick veneer ??? Maybe I missed something ??? I need the edge banding veneer.???
Do a Google and see if you can find someone with a sawmill. ;D
CHARLIE
Veneer be them logs dat been unrolled. ;D
Charlie
Jason_WI
Harold,
Is this what you are looking for:
http://www.tapeease.com/thick.htm
Looks like they have three different thicknes available but only go to 1 3/4" wide. Kink of expensive though ::)
I have purchased peel and stick veneer sheets from here before. Local company from WI.
Are you looking for rotary or flat sliced veneer?
Jason
Norwood LM2000, 20HP Honda, 3 bed extentions. Norwood Edgemate edger. Gehl 4835SXT
Fla._Deadheader
How it's skinned don't matter. Just needs to be thin and just over 2" wide.
