Arborwear
Author Topic: PTO wheel wobble  (Read 583 times)
Offline climber2
  • We are nothing compared to trees...
PTO wheel wobble
« on: December 07, 2015, 09:40:07 PM »
So I tried running my mill for the first time today and noticed the PTO wheel wasn't looking right. I took off the band and wiggled the wheel... It moved the whole shaft moved.
Question is, is this appropriate or is it like normal with bearings...wobble equals wear. This is a timber harvester 36htd25, 2001 model year. The PTO shaft is supported by two pillow block bearings.
Timber Harvester 36htd25, 06 Ram 2500 5.9, 95 Chev 3500hd, 445ct Bobcat w/ Wallenstein winch, Bandit 200+, Morbark M12r, Countless chainsaws...
Online beenthere
Re: PTO wheel wobble
« Reply #1 on: December 07, 2015, 10:04:14 PM »
climber
How about some pics of your setup? That would help put the problem together..
You have pics in your gallery, of trapped fox and beaver. So know you can do that... just have never seen a post where you talked about your trapping.. that would be interesting to hear about as well.
Offline dutchman
  • Sawyer SW PA TimberHarvester 30HT
« Reply #2 on: December 07, 2015, 10:32:08 PM »
I run a 30HT. I have double pillow block on the drive side and a single ball bearing on the idle
side.
My pillow blocks are radial bearings.
I have replaced both pillow bearings completely, and new pulley, and new drive shaft.
On the idle side I replaced the bearing.
The only time I had a lot of play was when I had a cracked drive shaft.
Check all the mounting bolts first.
Offline climber2
« Reply #3 on: December 07, 2015, 11:03:42 PM »
climber
True, I just can't figure out how to post with a picture. I think its an issue with the platform i m using.
I do very much enjoy trapping BTW...
Offline climber2
« Reply #4 on: December 07, 2015, 11:56:01 PM »
side.
Any pointers on where to find those drive bearings? I did not get any manuals for this machine so I'm kind of blind when it comes to parts...
Online beenthere
« Reply #5 on: December 08, 2015, 12:17:45 AM »
Quote
Have your gallery open, and your post open.
Just click on your pic in your gallery.. the one you want to show.
You will see the line just below your pic when it enlarges. That is the line you paste into your post. Nothing to it.  ;)
Opinion: Band wheel w nothing btw blade and wheel
Started by chisel on Sawmills and Milling
Last post June 14, 2004, 02:26:41 PM
by Fla._Deadheader
Saw wobble
Started by CX3 on Sawmills and Milling
Last post February 20, 2016, 09:20:55 AM
by paul case
Head wobble through the cut, lt 40's
Started by drobertson on Sawmills and Milling
Last post August 07, 2012, 08:33:27 AM
by drobertson
Saw wobble. Need some expertise.
Started by francismilker on Sawmills and Milling
Last post January 15, 2013, 05:28:19 PM
by dboyt
