Arborwear
Author Topic: Milling Around the Logosol CSM  (Read 12468 times)
Offline Farm29
Re: Milling Around
« Reply #140 on: January 07, 2018, 08:16:34 PM »
Those benches are super nice wv I like to look for those " ugly" logs when I'm out and about we were cleaning ditches and took a few sycamores out and I saved a log that was 10-12" diameter 6' long but will take a 28" throat to saw it  ???  It will be a little narrow for a bench but hope to still make one with it that's what's fun about having a mill you can build stuff that you can't find at a store
96 lt40 Hyd 24 hp onan
460 rancher
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Milling Around
« Reply #141 on: January 07, 2018, 08:54:01 PM »
F29,
   Yeah the big difference in making bench stock is instead of cutting in the middle of the curve to help straighten out the log you want to leave the curve in the middle (?) of the log. I guess if you want the curve on one end you'd cut it that way. That's the beauty of them - each one is unique and anybody buying or getting one for a gift knows they have the only one of its kind. When you can get 2-3 they ache to surround a fire circle.
   You can make a nice bench from an 8" slab so don't sell those small logs short either.
   Remember you can cut a log that is wider that 28 total width from side to side as long as the log itself is not over 28" and you can clamp in the middle of the curve and still swing first one then the other end into line during cutting.
Offline moodnacreek
  • Sawin by the notches
Re: Milling Around
« Reply #142 on: January 07, 2018, 09:10:55 PM »
Richhiway, I see your not afraid of work. Don't get a sawmill, your too close to me !
Offline richhiway
  • Rich
Re: Milling Around
« Reply #143 on: January 08, 2018, 06:20:21 AM »
Nice Benches!
Logosol M-7
New Holland 35 hp tractor
International T-6 Dozer
Takeuchi mini excavator
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #144 on: January 13, 2018, 05:53:13 PM »
Built a log bunk for the Logosol mill. Makes it easier to just roll them on the mill.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #145 on: January 13, 2018, 07:25:31 PM »
To cut the notches for the bunk. Set your Skil Saw at the desired depth and make multiple cuts. Then just knock out the waste with your hatchet.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #146 on: January 13, 2018, 07:27:10 PM »
Use your hatchet to clean up the cut.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #147 on: January 13, 2018, 07:28:21 PM »
Clean up with a chisel.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #148 on: January 13, 2018, 07:29:32 PM »
Smooth up with a hand plane and your done.
Logosol M-7
Stihl Chainsaws
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Milling Around
« Reply #149 on: January 13, 2018, 07:33:43 PM »
Nice, smiley_thumbsup
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline richhiway
  • Rich
Re: Milling Around
« Reply #150 on: January 19, 2018, 08:41:30 PM »
Picked this ARPS blower this summer to clean up around the mill. I tried her out today and will put the video up.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #151 on: January 19, 2018, 08:43:18 PM »
Snow Blower. Moves a lot of snow but I bet it will use some fuel!
Logosol M-7
Stihl Chainsaws
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Milling Around
« Reply #152 on: January 19, 2018, 09:33:04 PM »
Better than 1,000 shovels  8)
1992 LT40HD
Offline richhiway
  • Rich
Re: Milling Around
« Reply #153 on: January 22, 2018, 06:15:24 AM »
 A short video changing the carriage on the Logosol. I found that by using two saws,one to cut the logs to cants and a second saw to cut the lumber saves time. You could have two carriages but as you see it only takes a minute to change. This saves a lot of file time, the saw that cuts the clean lumber stays sharp and the bars and chains will most likely last longer. If you have a helper he can sharpen while you keep cutting. Having two saws will let you keep milling if one gives you trouble also. I purchased a new 661 magnum and will try to post some video about the new saw.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #154 on: January 22, 2018, 06:23:16 AM »
  I have resisted buying a new all electronic saw for a while. I like the old Stihl 0 saws and having the ability to work on them. I had a lot of lumber to cut at a camp so I gave in a purchased a new 661 Magnum. When I got it home I went to install the studs to mount it on the Logosol but the cover has captive nuts. This is a nice feature as you can not loose a nut but it will not work with the Logosol setup. I had to change the studs and slightly modify a old cover to fit.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #155 on: January 22, 2018, 06:42:57 AM »
Letting you know about my new Stihl 661 Magnum. It is a 91cc saw with 7.2 H.P. The 046 magnum is 76cc saw with 6 H.P. In the cut you can not tell a huge difference. The new saw is quieter and seems to have more torque. Both saws have compression releases, you need that on a big saw. The new saw has a different style switch that I will show in another video. The new saw starts on the first pull nearly every time. The older saws usually do.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #156 on: January 22, 2018, 12:51:54 PM »
Handy Switch Design. Works easy with heavy gloves.Auto choke release, no half choke. Spring Loaded to be always on.
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #157 on: January 22, 2018, 12:56:31 PM »
Starts on first pull after sitting 2 months! Stihl 661
I give a lot of credit to all the well done videos. It's not as easy as it looks!
Logosol M-7
Stihl Chainsaws
Offline richhiway
  • Rich
Re: Milling Around
« Reply #158 on: January 22, 2018, 01:12:54 PM »
Turned a small pine log into some usable lumber with a few minutes effort.
two 2X4 one 4X4 one 1X6 and one 2X6X 12'
Logosol M-7
Stihl Chainsaws
Offline ToddsPoint
  • Stockmaker and Carver
Re: Milling Around the Logosol CSM
« Reply #159 on: January 23, 2018, 04:47:16 AM »
I've broke those 8mm studs before on my logosol.  I now keep an extra set.  Also, I replaced the rubber strips on the carriage which tightened it up a bit.  I bought my M7 used.  When I put my 660 with 28" bar on the carriage, the tip of the bar is slightly below center.  I had to put a .030 shim on the front stud to bring it up to level.  Gary
Logosol M7, Stihl 660 and 290, Kubota L3901.
Milling with the Logosol
Started by richhiway on Sawmills and Milling
Last post May 26, 2014, 02:47:25 PM
by richhiway
Setting up stihl 075AV for milling use with Logosol M7 mill or timberjig.
Started by Timberframiadreamin on Sawmills and Milling
Last post June 08, 2015, 12:27:54 AM
by mad murdock
logosol ph 261
Started by FeltzE on For Sale
Last post December 27, 2015, 02:59:13 PM
by steve marek
Logosol 360
Started by Doug Wis on Drying and Processing
Last post September 24, 2016, 08:58:38 AM
by Czech_Made
