Author Topic: Makita 6401  (Read 1007 times)
Offline gunscrew
Makita 6401
« on: December 12, 2015, 09:11:51 AM »
Just bought my second 6401 this one was used cranked right up cut great but I noticed the dampening spring that attaches to the handle bar was out of alignment. seems the handle bar has moved forward. looks like saw was probably hung in a log and in process of getting it out pushed spring out of alignment by pulling up on handle. now I know this is a picky thing but it bugs me. Doesn't seem  to be broke handlebar just to far forward.Question is how do I move it back to get spring lined back up. Do I loosen up the other dampening springs and pull it back?Or should I just ignore it.
Offline dougand3
Re: Makita 6401
« Reply #1 on: December 12, 2015, 10:41:22 AM »
Welcome, gunscrew. Here is the IPL:
http://s30387.gridserver.com/partsDiagrams/Makita%20DCS6401.pdf
What part # seems out of alignment? Eg: 88,90,93 are spring units holding fuel tank/handle to crankcase.
If you could post a pic - would help.
Offline fordf150
Re: Makita 6401
« Reply #2 on: December 12, 2015, 11:33:38 AM »
probably the upper A/V spring is bent. 6401 did not come with the spring travel limiter IIRC. replace part number 038114152 and add a limiter to it. part number 038-310-070.
might consider ordering 010-114-039 instead of just the single A/V spring too.
Offline gunscrew
Re: Makita 6401
« Reply #3 on: December 12, 2015, 03:59:58 PM »
yes its the spring that attaches to the cylinder and handle bar can't move handle bar back enough to get spring in proper position, don't want to force it . It has some movement but not enough to get things lined up right.
Offline gunscrew
Re: Makita 6401
« Reply #4 on: December 12, 2015, 04:05:06 PM »
its the # 70 (spring) thats pushed forward out of alignment the handle won't come back far enough to screw it back to the handle. thanks for the replys
Offline gunscrew
Re: Makita 6401
« Reply #5 on: December 19, 2015, 07:02:46 PM »
well had time to mess with it today took all the dampers out , handle bar off, and when everything is in place the     hole where the spring on the handle bar screws   to the cylinder lines up exactly center of the handlebar the is no way to get the spring installed.My other 6401 has enough room although tight to install the spring in front of the handle. what gives.
Offline dougand3
Re: Makita 6401
« Reply #6 on: December 19, 2015, 10:36:23 PM »
So, there is not enough room between handlebar and cyl for the spring to fit? Could the handlebar be bent out of shape? Could this handlebar be for a non-AV 6401?
Makita 6401 Question
Started by Cypressstump on Chainsaws
Last post June 02, 2012, 05:19:23 PM
by lumberjack48
Makita DCS 6401 with Big Bore Kit
Started by KC on Chainsaws
Last post July 30, 2009, 07:22:49 PM
by KC
question
Makita 6401 oiling very very well, mostly the clutch!
Started by shootingarts on Chainsaws
Last post January 20, 2014, 12:06:16 PM
by shootingarts
newbie - Stihl 441 vs Makita 6401 w BB
Started by gemniii on Chainsaws
Last post August 30, 2009, 04:26:03 PM
by chipsfly09
