Author Topic: New Guy with my Sawmill Build  (Read 12710 times)
Offline Jimmysmill13
« on: December 16, 2015, 06:08:33 PM »
This is a saw mill I have been building over last couple months. I would like to see what you guys think and if you have any good or bad point on the mill. I still need to attach the motor and add some blade/wheel guards.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: New Guy with my Sawmill Build
« Reply #1 on: December 16, 2015, 06:12:32 PM »
Hello Jimmysmill13, and Welcome to the Forestry Forum.  Adding your location to your profile will help with questions.
Pictures must be loaded into your gallery and posted to your reply from there.  Review the Picture Posting thread at the bottom of the home page.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: December 16, 2015, 06:27:26 PM »
I'm sure everyone would love to see pictures of your build.
I just this year made one my self.
So ask any questions.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Den-Den
    • Dennis Wood Art
« Reply #3 on: December 16, 2015, 07:15:14 PM »
The pictures look great.
A couple of questions:
* What band speed are you planning?
* How fast will the guide bearings be spinning?
« Reply #4 on: December 16, 2015, 07:29:12 PM »
I am look at around 4000 to 5000fpm, I will have a 13hp engine.
I am not sure what the speed will be on the bearings at this point.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: December 16, 2015, 07:43:56 PM »
That is the way to do it.   8)
My question is also about the blade guides.  Maybe it is the picture angle, but be sure to give the blade teeth plenty of room in front of the guide rollers.  You want to avoid any chance of the teeth contacting the rollers and removing set.
Congrats on the pictures.   :)
« Reply #6 on: December 16, 2015, 07:52:42 PM »
Thanks Magicman, I see what you are saying about the blade guides, and I will have to make some adjustments and allow more space for the blade teeth.
Offline dustyhat
« Reply #7 on: December 16, 2015, 09:31:57 PM »
Looks like your well on your way, the thing i will critic is the base where the track wheels are needs to be longer, motor weight ,wheel covers, and other weight, with the saw up high cutting a log it will probly be top heavy front to back. other than that it looks like a very good start.
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
« Reply #8 on: December 16, 2015, 10:09:14 PM »
Thanks Dustyhat, I agree and I may end up having to adjust this. I have put close to 200lbs on the motor mount at it's highest point and believe it or not it's very stable. The reason for the shorter stance was to maximize the sawmill base as its only 13' long. If you take notice to the side wheels on the base rails this also was added to help control any instability witch has worked out nicely.
Offline dustyhat
« Reply #9 on: December 16, 2015, 10:18:10 PM »
There was a guy on here that was having trouble with sawdust clogging up his acme thread, and causing it to bind up. cant remember what he did , but maby he build some kind of brushes to keep them cleaned out. you might want to think about that :)
Offline sawmilllawyer
  • Ride hard, die free.
« Reply #10 on: December 16, 2015, 10:21:27 PM »
Sawmill build is looking good. Welcome to the forum.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
Online ljohnsaw
« Reply #11 on: December 16, 2015, 11:40:42 PM »
Jimmy,
You nailed the picture posting thing 8)  Really nice, clear pictures.  Having just completed my build, I see some things that may need attention:
Awesome track!  Your track looks like it is flat on top - you will need a scraper/brush to keep the sawdust from building up and causing you trouble.
You have a really nice T-handle that looks like you will be using it for your blade tension - NICE.  However, it is also on the side where you have the motor/drive belt.  You will want your drive belt to remain constant tension.  Maybe you will address this with a spring-loaded idler pulley?  Or, swap out the bolt you have on the idle side for a T-handle as well.
I made my own blade guides like yours.  The minute I added water-lube, the bearings ceased up.  I'm guessing water brought sawdust into them.  I ended up buying Cook's guides and they work great.
On your vertical guides, did you put some wear plates/Teflon in there?  Would probably help it move smoothly.
Do your guide bars stay in alignment with the blade (more important vertically, not so critical front to back)?    You want to be able to consistently cut square but if one side of the blade leads the other, that doesn't matter so much.  On your blade guide bars, you have hex bolts - consider either welding on a T handle or replace with handles you can work without tools like this:
  You want to keep the guides up to the wood and being able to do it without tool is much nicer.
As far as keeping your ACME threads free of sawdust, I would slip some PVC pipe over it.  Make the pieces just long enough that they fit when all the way up or down.  Hang the bottom one from the ACME nut.  The top one will just rest on the nut.  Hopefully, that will cover all the thread you will be actually using.
Keep in mind that you are going to want to operate your mill from the idle wheel side so you are not getting covered in sawdust!  Did you have to flip your blade (turn it inside out)?  Your rotation is opposite from most mills I've seen.
John Sawicky
Offline redprospector
« Reply #12 on: December 17, 2015, 12:03:38 AM »
Welcome to the forum Jimmysmill13!
I won't repeat what's been said. What I will say is, nice job. I like the way that you have your pillow blocks spread out. I got mine too close together, and have to replace shafts way more often than I'd like. I would recommend putting some split locking collars on the shafts to keep them from being able to move.
The only other concern I have would be for the carriage wheels. It looks to me like you used idler pulleys. I don't think they will hold up long. But I've been wrong before.  ;)
« Reply #13 on: December 17, 2015, 12:10:51 AM »
If the OD of the bearings is 1 1/2", and your blade is traveling at 5000 sfpm, your guides will be spinning at about 12,732 rpm. That's pretty dog gone quick.
Offline Kbeitz
    • My Hobbies
« Reply #14 on: December 17, 2015, 06:30:42 AM »
Wow... Looking good.
 I also think that you will need a spring-loaded idler pulley on your belts.
When sawing the belts will warm up and start to slip. I use a back idler
on my setup spring loaded and it really made a difference.
I also used Cooks bamdsaw guide wheels and they work great.
I also use the 13hp engine. Don't put to much set in your blades and
you will be good with that HP. I bet that like me you will be making a
bolt on extension soon.
Offline justallan1
  • living and learning
« Reply #15 on: December 17, 2015, 09:25:26 AM »
Jimmy, welcome to The Forestry Forum.
Great looking build so far. I will agree with ljohnsaw on your blade tensioner, but it wouldn't be a big deal to use the other wheel for your drive wheel and flip your blade inside out, from the looks of things.
Just a random question, did you already flip the blade inside out to make it saw the direction you are showing in the pics? I ask because both mills I've had they come to me with the teeth going the opposite of what you show. I don't know if it matters a bit, just curious.
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #16 on: December 17, 2015, 09:35:51 AM »
Your mill looks nice and very rugged with many well-thought-out things on it.  Takes longer than you think, huh?  :)
The only thing that stands out to my eyes is your driven shaft, not the idle shaft.  The pulley to be driven by the engine is quite a ways away from the pillow block bearing.  I'm afraid you're going to have shaft breakage problems.  I'm thinking somehow the space between the pulley and the outboard pillow block needs to be smaller.  I would also recommend using red locktite on all the pillow block bearings.  Smear it all over the shaft and the set screws.  This will keep them from constantly loosening up.  This is for use with the cheap Chinese bearings.  The expensive US bearings probably won't have this problem.  Use heat to get the loctite to let loose for repairs if needed.  The guide bearings you're using are used by many mills.  They wear out pretty fast but are cheap and easy to replace as well.  Keep some gear oil in/on the ball bearings inside and they'll last a good long while.  Gear oil is a high pressure, high shear load oil with lots of sulfur in it (hence the smell) that uses that sulfur and a sacrificial wear surface that gets replenished using more oil on the next revolution (in an oil bath gearbox).  If you have any more questions, this is the best place to get them!  I'm not aware of any other place on the internet with a collection of so many smart, capable men from so many walks of life.  Collectively, we can do anything.
Nice looking homemade mill, buddy.  You have really nailed alot of the common problems with homemade jobbers.
Online ljohnsaw
« Reply #17 on: December 17, 2015, 11:03:51 AM »
It doesn't matter which way you run your blade (as long as the teeth are cutting ;)).  The important thing is that the drive wheel is PULLING the blade through the wood, not pushing it!  What you have should work just fine.  Your wood will just be left-handed :D
John Sawicky
« Reply #18 on: December 17, 2015, 12:23:15 PM »
Jimmy,
 (Image hidden from quote, click to view.) You want to keep the guides up to the wood and being able to do it without tool is much nicer.
Thanks for all the good info,
I didn't think of saw dust building up on the track, I will add something to control that issue as well.
I will be adding a spring loaded idler pulley and I haven't come up with a design yet but I think I am also going to have the motor be able to slide for belt adjustments.
I do like your T-handles and will be welding some handles on to the bolts at some point.
The blade guides I do like so far but they have not been proven yet since I have not been able to run it but I have looked at the cooks and if this fails I will purchase a set. It will be an easy retrofit.
The blade guides do stay in alignment. I made the guides adjustable in every direction if for some reason they become out of alignment.
The acme thread on this mill was not my original design. I originally had a cable and pulley system and I just couldn't get it to balance out properly and I had a lot of binding so this is actually design number 3 and I wish I would have started with the acme thread originally. It would have made everything better. This is the other reason you see the acme thread to the rear of the mill instead of being centered. I plan on using some vacuum cleaner hose to help keep the dust out of the treads.
 I will be operating the mill from the idler pulley side and pushing forward. The engine shaft would be facing me and the motors shaft rotation is counter clockwise so the blade will be moving to the right as the teeth direction indicate. I may not fully understand you last question on this so let me know if that makes any sense at all.
« Reply #19 on: December 17, 2015, 12:32:25 PM »
Thanks!
I did put some collars with set screws on do think this should be a split lock instead?
I am not sure if the idler pulleys will hold up either. I did make them easy to switch out if one goes bad. It just a pin and collar holding them in place. It was away cheaper option then rail wheels.
First sawmill build
Started by BraschBrothers on Sawmills and Milling
Last post January 29, 2017, 01:14:15 PM
by Joe Hillmann
Sawmill build
Started by TreeStandHunter on Sawmills and Milling
Last post December 04, 2018, 09:22:58 AM
by Crusarius
My new sawmill build
Started by Piddler on Sawmills and Milling
Last post February 08, 2018, 07:17:59 PM
by Kbeitz
Sawmill build
Started by joegeds on Sawmills and Milling
Last post February 18, 2016, 10:34:33 AM
by york
