Author Topic: sawmill question  (Read 5341 times)
Offline Byron sawman
sawmill question
« on: December 30, 2015, 07:46:34 PM »
Thanks for adding me. I recently acquired a Belsaw circular sawmill that was put together with pieces and parts. I think I've almost got it workable. My main question is; should the blade be dished toward the log or the board. I have acquired one blade of each, which do I use. Thanks in advance for any advice you have and Happy New Year to all.
Offline Gearbox
Re: sawmill question
« Reply #1 on: December 30, 2015, 08:42:35 PM »
The saw cup should be toward the board . It should be almost in contact with the board side saw guide when stopped and when up to speed it should not hit the guides 1/16 max on each side
Online beenthere
« Reply #2 on: December 30, 2015, 09:07:07 PM »
Maybe this will help too. Very popular among circular saw people.
http://www.fpl.fs.fed.us/documnts/misc/circsaw.pdf
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: December 30, 2015, 10:09:35 PM »
Welcome to the Forestry Forum, Byron sawman.
~Chuck~
I LOVE MY SAWMILL
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #4 on: December 31, 2015, 07:50:25 AM »
Welcome to the FF Byron sawman.
For the blade to cut without heating and distorting it should be flat on the log side.
How big are the blades you have and are they fixed tooth or inserted tooth?
Dan
Offline Solomon
  • I finally figured out how to upload pictures!!!!
« Reply #5 on: December 31, 2015, 08:15:08 AM »
This should be an interesting thread,  I know nothing of Circle Mills so I will be watching this thread from the side lines.
 You've come to the right place, this site is akin to an Encyclopedia of knowledge when it comes to saw mills and related topics.
 Thanks for bringing this to the forum !! :P
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
Offline Gearbox
« Reply #6 on: January 01, 2016, 04:28:31 PM »
I may not have been clear when I said board side . I should have used cant side or log side . I guess I was speaking Minnesota .
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: January 01, 2016, 10:22:10 PM »
Welcome to the Forestry Forum, Byron sawman.  These "circle saw guys" will steer you correctly.   :P
Offline DMcCoy
« Reply #8 on: January 02, 2016, 08:03:28 AM »
Welcome. The blade should have the concave side towards the carriage side or log side when stopped.  With the blade teeth turning toward you if the log passes on the right it is a right hand mill.
« Reply #9 on: January 05, 2016, 05:58:00 PM »
Thanks for all of the welcomes. Looking forward to learning a lot from the members of this forum. I've sent my blade out to be re-tensioned. Should have it back in a couple of days. Thank-you all for the helping hand.
Offline Lambee10
« Reply #10 on: January 08, 2016, 04:40:39 PM »
Welcome.  Good to have another Belsaw in action.  Keep asking questions as you come across them.  I did.
All animals like me...at feeding time.
M-14 Belsaw and the toys to go with it.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #11 on: January 08, 2016, 10:38:33 PM »
Good to have you on board Byron sawman. My only experience with a circle mill was when I was about 25, I pulled greenchain in a mill that had a 60" saw on the bottom and a 42" top saw and if they didn't run right the saw filer would take them off and pound on them with a big hammer.  And they had removable teeth as I recall.
1992 LT40HD
Offline Sixacresand
  • John and Nancy
« Reply #12 on: January 09, 2016, 08:35:02 AM »
Welcome to the Forum, Byron Sawman.   I used to dream of having a Belsaw when I saw their ads in the back magazines like Popular Mechanics.  Good luck!
« Reply #13 on: January 16, 2016, 05:37:31 PM »
I am looking for Belsaw parts. I'm getting very tired of losing the can't. I have a worn out locking dog cam for my carriage. It has straight cut knurling that is worn out. I am looking for another cam or someone's better simple idea of modifying what I have to work. I have a pretty crude machine shop, but have a lot of fabricating knowledge. Thanks again for your time and patience.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #14 on: January 16, 2016, 06:14:30 PM »
Why not anneal it and reknural it and reharden it.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Chuck White
« Reply #15 on: January 16, 2016, 06:40:18 PM »
~Chuck~
I LOVE MY SAWMILL
« Reply #16 on: January 16, 2016, 08:21:39 PM »
I'm sorry I forgot to mention that it is cast iron from the sparks. I also had an idea that I could locate an indexing head and use a cutoff wheel on the mill to repair it? Still would rather have a new one or make a new one.
Offline Kbeitz
    • My Hobbies
« Reply #17 on: January 16, 2016, 09:41:32 PM »
If you have the tools and it sounds like you do then i would make one out of drill rod.
You can buy it from McMaster Carr. It comes soft so you can lathe it.
When your finished it's real easy to harden it.
« Reply #18 on: January 24, 2016, 04:13:15 PM »
Hi Guys, This sawmill has been a real struggle. I bought this as a basket case. I thought the basics was all here. I have had a lot of frustrating adventures trying to bring it back. Does anyone have any information, books, photographs or some location where I might be able to find these? I was told this was a Belsaw but I see no information so far on which one it is, considering I have three casted stands with wood mounted on top of them as part of the frame. Any information would be appreciated, thank-you.
Offline dgdrls
« Reply #19 on: January 24, 2016, 05:04:40 PM »
Hi Byron,
Search the web under Foley Belsaw,  I think you will find some
good nuggets,
Post some photos of what you have and lets see if we can help you
get this machine sawing straight.
Best
Dan
Sawmill Question
Started by texrose on Sawmills and Milling
Last post February 11, 2014, 01:17:52 PM
by dboyt
Sawmill Question
Started by TFramer34 on Sawmills and Milling
Last post March 23, 2010, 11:45:09 PM
by TFramer34
another sawmill id question
Started by jeep534 on Sawmills and Milling
Last post February 17, 2015, 08:07:13 AM
by Lambee10
SawMill Question
Started by sawwood on General Board
Last post December 01, 2009, 09:15:35 PM
by easymoney
