Author Topic: tuning new 372xp  (Read 3543 times)
Offline flannigan
  • Member*
tuning new 372xp
« on: October 10, 2004, 09:39:07 PM »
Hello,
I have about 5 tanks worth of use on a new Husky 372xp.  The manual says it is set rich for break in and that I will get better power with tuning the carburetor now. Is this something others have done?  The power seems pretty good, but I could always use more.
By the way, for anyone shopping saws - this is my second Husqvarna - I've had a 55Rancher for a few years and used and abused it.  It's been the ultimate in reliabilily - just a little low on power (for a 20 inch bar at least).  I will continue to buy Huskys!
Offline SawMeister
Re: tuning new 372xp
« Reply #1 on: October 10, 2004, 10:07:05 PM »
I am in the same boat as you. I have a new 385XP with about 4 tanks of use. I had a fellow at a local saw shop that works on both husky's and Stihls tell me if it ain't broke why try and fix it? I don't put a lot of stock in this guy nor does his shop see a lot of business from me or my friends. The directions in the owner manual seem pretty clear but I would be afraid that I would screw something else if I were to try it myself.
Offline Timberwerks
  • Timberwerks Studio
« Reply #2 on: October 11, 2004, 06:29:02 AM »
I have both the 372 and 385 and both ran about 800 - 1000 rpm lower than max from the factory. After break in I used a tach and set the carb to run at 13,500 for the 372 and 13,000 for the 385. It did make a differance in performance. I did this after 10 tanks. I recomend using or buying a tach to keep your saws in tune.
Dale
Offline jokers
  • Chainsaw Freak
« Reply #3 on: October 15, 2004, 07:09:02 AM »
A tach is a handy tool to have but don`t use it to the exclusion of your senses and other feedback from the saw. For example, a tach won`t tell you if your lo speed setting is too lean yet the lo speed circuit in a conventional carb like what the 372 uses, supplies about 30% of the total hi speed fuel.
A tach without some fundamental knowledge of carb tuning can put you up the creek.
Check out Madsen`s website for some pretty good carb tuning info.
Russ
Tuning by ear vs. tuning with tachometer
Started by double clutchin weasel on Chainsaws
Last post January 03, 2014, 10:07:11 PM
by celliott
Husqvarna 372xp Original Edition vs. 372xp Current Edition "X-Torq" Saws.
Started by weimedog on Chainsaws
Last post March 25, 2018, 04:00:48 AM
by knuckledragger
Tuning
Started by shiggins on Chainsaws
Last post June 14, 2014, 01:06:53 AM
by shiggins
Tuning
Started by three feathers on Chainsaws
Last post September 03, 2014, 07:49:01 PM
by three feathers
