Auger Bit Question
Started by Haggis, January 11, 2016, 09:58:45 AM
Haggis
Do these types of augers usually have cutting spurs on them? I was thinking about getting an 1.5" one for some projects but every one I look at seems to have no cutting spurs to create a nice clean entry to the hole.
Thank in advance.
Jim_Rogers
Some do, most don't.
Jim Rogers
Haggis
Dave Shepard
Very few that I have seen have spurs. For mortising, score the edges of the mortise, and you won't have any tear out.
Haggis
Quote from: Dave Shepard on January 11, 2016, 12:34:08 PM
I wasn't using this for mortise joints. I was actually going to be using it for legs holes for a shaving horse build I plan for this summer. Was hoping to keep the holes as clean as possible. I do have a brace & a 1" bit but thought that was a little on the small side for strength of the leg.
Brian_Weekley
After you drill out the holes, you might want to use a reamer to taper the leg holes--tapered fittings work well to hold the legs in the shaving horse.  I made a tapered reamer from a piece of oak and inserted an old hacksaw blade in a slot to serve as the cutter.  The problem was it was hard for me to make the reamer or to taper the legs to fit the holes because I didn't have the shaving horse first (Catch 22)!  But, you could also make one with a lathe, if you have one.
e aho laula
Haggis
Quote from: Brian_Weekley on January 11, 2016, 03:24:55 PM
Excellent idea. Will work on one of these before the sring hits. I can do this in my workshop at home in my vise.
