Author Topic: Finding Hinges for Large Barn Doors  (Read 4571 times)
Offline WV Sawmiller
    • Green's Sawmill Services
Re: Finding Hinges for Large Barn Doors
« Reply #20 on: January 19, 2016, 07:31:54 PM »
Hi Howard,
I took your advice and ordered some 10" pneumatic wheels filled with foam so I shouldn't get a flat.  This should definitely take the pressure off the hinges.  Great suggestion!
   Great. Hope that works for you. I have seen people use them and if they didn't  have good level ground they'd pour a circular concrete track for the roller to run on.
Offline timberlinetree
« Reply #21 on: January 20, 2016, 04:49:48 AM »
Thank you sir. These are what the hinges on barns around here look like. I think some of these are hand made and 100 yrs old. That tire should help,have seen them on gates before.
I've met Vets who have lived but still lost their lives... Thank a Vet
Family man and loving it :)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #22 on: January 20, 2016, 08:24:49 AM »
In Reply #14 Kbeitz was explaining how to straighten and make superduty hinges like that out of auto leaf springs.
Offline gspren
« Reply #23 on: January 20, 2016, 10:55:10 AM »
   Around here I've never seen a barn door with level enough ground in front to use a wheel, and then there is snow and ice. I have seen barn doors both hinged and sliding where the bottom 12 or so inches were hinged so you could swing them up and hook to the main door to get clearance over uneven ground.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #24 on: January 20, 2016, 01:17:27 PM »
My pole barn doors are only 9x10 high full  1" Hemlock with battens and are on sliders from TSC.
They roll very easily and I cant believe another 2' would make that much difference.
Dont have to worry bout the wind blowing them around either.
Kbeitz, how do you make the bolt holes?
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo vintage Homelite super xl12
241 acres of woodland
Offline Don_Papenburg
  • I need money
« Reply #25 on: January 20, 2016, 10:29:41 PM »
Drill them slow or use the Bridgeport and a ballend mill tool with a slow  self feed.
cutting oil helps.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #26 on: January 21, 2016, 06:59:22 AM »
Think I'm a little late with my picture. Sorry... i forgot.
It's hard to show what it really looks like. This is one made just useing two parts instead of three.
Leaf spring hinge...
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Glenn1
  • Drying lumber one board at a time
    • GPS Hardwoods
« Reply #27 on: January 21, 2016, 10:08:47 PM »
I appreciate your effort, thanks!
Vacutherm IDry, Nyle 53 Kiln, New Holland Skid Steer, Kaufman Gooseneck Trailer, Whitney 32A Planer
Offline Glenn1
    • GPS Hardwoods
« Reply #28 on: February 06, 2016, 07:52:40 PM »
Today, we put together 22 hinges.  The steel is 3/8" by 3" wide.  We inserted  a 5/8" steel pin into a 1" tube with a 3/16" wall.  These hinges in conjunction with a 10" fixed wheel on the bottom of the door should do the trick.
Offline smoothED
« Reply #29 on: February 15, 2016, 04:29:58 AM »
I make mine almost like that, more like a piano hinge. 1" and 1 1/4"pipe,and drill holes in the 1 1/4" for grease fittings
old barn/new doors
Started by giant splinter on General Board
Last post June 12, 2012, 09:42:41 PM
by shelbycharger400
Need help with large carriage doors construction
Started by OneWithWood on General Woodworking
Last post April 17, 2015, 05:30:59 PM
by OneWithWood
Kiln Doors and Large Span OPening
Started by PA_Walnut on Drying and Processing
Last post May 01, 2018, 11:14:13 PM
by YellowHammer
Insulated Barn Doors
Started by Brian_Weekley on Timber Framing/Log construction
Last post May 07, 2014, 04:09:14 PM
by D L Bahler
