Author Topic: 47" - 50" 3/8 Stihl-mount sprocket-nose bars  (Read 1029 times)
Offline DonnerParty
  • Chainsaw Miller
« on: January 21, 2016, 02:14:38 PM »
Just making sure I'm aware of all of the bars that are currently available in this size before I buy one. I have only been able to find a 50" GB bar at LeftCoastSupplies in 3/8" .063. Not unreasonable at $285. Anything else available in a 3002 Stihl mount in this size range in 3/8"? I love Stihl bars, but only see a hardnose (duromatic) 47" and it's pricey.
Offline beauj5
Re: 47" - 50" 3/8 Stihl-mount sprocket-nose bars
« Reply #1 on: January 22, 2016, 10:58:30 PM »
I may be wrong, but I believe Stihl goes from 42" to 60" and nothing in between.  I know Cannon makes bars from 16" up to 96".  I have a 60" from them, but I had to order it because they had to make it as they were out of stock at the time, so it took almost a month and almost 4 bills, but I have one.  Its a bit heavy though.  They also make double ended bars you can put a handle on those longer bars as they get heavy and awkward on uneven ground.  Anyway, check with Cannon.  I don't shop at Bailey's ( 100% Mom and Pop guy), but you can look on their website for lengths and prices.  Anyway, that's my 2 cents and experience.  Sde note and totally irrelevant, why don't they have the cents symbol on a keyboard like they do the dollar sign $ ?  I'd use it more :D
When the road forked, I went straight.
T540xp, 562xp, 034 super mag, 044, 460, 576, 056 super mag, ms460, 066, ms880, 090.
Offline DonnerParty
  • Chainsaw Miller
« Reply #2 on: January 22, 2016, 11:19:04 PM »
Thanks for the reply. I can still get a duromatic (hardnose) bar in 47" from Stihl. Not sure why they don't list them on their site anymore.
I couldn't find a Cannon bar over 42" in 3/8", but I guess they would make one. Way heavier and way more $ than GB. Guess I'll go with the GB, as I've had good luck with them and the price is good.
Thanks for your 2  :-*
(cents symbol: is option-4 on a mac, FYI)
Offline Al_Smith
« Reply #3 on: January 24, 2016, 07:02:37 PM »
If you get over 42"they are nose heavy as the dickens .
I've got a 42" Oregon on an 084 Stihl and it's not bad .Conversely I have a 48" that fits either a Mac 125 or a Homelite 2100S that is like trying to lift a bowling ball on the end of a broomstick .
Every so often a long bar pops up on flea bay and they are certainly proud of them .Let me tell you though the novelty of running a long bar fads very quickly .
Offline DonnerParty
  • Chainsaw Miller
« Reply #4 on: January 24, 2016, 07:10:02 PM »
Thanks for the reply. I only use long bars for milling, which is most of what I do. Planning on going with the 50" GB at this point.
Offline Redbull661
  • Member*
  • 661
« Reply #5 on: January 26, 2016, 11:53:40 PM »
3002 50" cannon or oregon bar ...if it's .063 groove .404 tip,  you can just change the tip out to a 3/8ths tip.  single large aluminum rivet to drill...easy.
any suggestions on a "full chisel" chain for stihl 310? what about bars???
Started by fury1973 on Chainsaws
Last post January 23, 2012, 05:10:56 PM
by tcrew
Stihl 090, 48" and 36" Bars, CLEAN
Started by brendonv on For Sale
Last post February 27, 2014, 08:33:30 PM
by brendonv
Looking for a Stihl Mount 96" (or longer) bar
Started by fwfp on Chainsaws
Last post September 13, 2011, 10:44:25 AM
by clww
"frost bite Chainsaw bars"
Started by logger444 on Forestry and Logging
Last post September 19, 2014, 11:47:07 PM
by Maine logger88
