Arborwear
Author Topic: oil  (Read 2876 times)
Offline coxy
oil
« on: January 21, 2016, 08:12:35 PM »
Chevron      iso 100   does any know what it was used for  was told it was a food grade oil then was told it was oil for air drills/hammers   its clear and not to thick but its tacky going to use it for bar/chain oil
Offline snowstorm
Re: oil
« Reply #1 on: January 21, 2016, 08:15:53 PM »
years ago i used texaco rock drill oil for bar oil. it was cheap $5 for 5 gal
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oil
« Reply #2 on: January 21, 2016, 08:19:37 PM »
Chevron ISO 100 is a very high grade of synthetic hydraulic/turbine oil with exceptional high temperature stability.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
Re: oil
« Reply #3 on: January 21, 2016, 08:39:57 PM »
ISO designation is industrial oil
ISO oil used in Food Machines has an FM designation,
The comparison in viscosity for ISO 100 is in the range of SAE 30 weight oil
Dan
Offline coxy
Re: oil
« Reply #4 on: January 22, 2016, 07:30:57 PM »
don't know if it makes a difference but it says aries iso 100
Offline Gearbox
Re: oil
« Reply #5 on: January 22, 2016, 11:12:52 PM »
In the Chevron book ISO 100 is a heavy wt ISO 32 lube oil .I see nothing in the book with aries . [Its a 300 page book didn't read it all ] Then there is delo 100 for detroits. It may be newer or older than my book
Offline Gary_C
  • Sunrise on the Prairie
Re: oil
« Reply #6 on: January 23, 2016, 01:22:41 AM »
ISO 100 is a designation of viscosity. It is comparable to a SAE 30/40 weight.  You would need more information to determine how the oil was formulated. Could be a compressor oil, hydraulic oil, etc. I doubt it would be an engine oil if it does not have the engine type ratings.
Offline coxy
Re: oil
« Reply #7 on: January 23, 2016, 05:26:58 AM »
how do I find this out
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oil
« Reply #8 on: January 23, 2016, 08:07:19 AM »
See Reply #2 above.  LINK
Offline Gary_C
Re: oil
« Reply #9 on: January 23, 2016, 10:16:57 AM »
You would have to find more information from the packaging label. You have two identifiers, the manufacturer is Chevron and the viscosity is ISO 100. The other missing identifier would be the product identifier. There is no way of determining the use the product was formulated for without the product name.
But it makes little difference if you are going to use it for bar oil. It may not have the tackifiers that bar oil has but it is heavy enough to cling to your bar and chain long enough to provide the necessary lubrication. The only problem may be flow in cold weather.
Oils are formulated first by blending various feed stocks to establish the viscosity. Then they add various special additives like anti wear, extreme pressure, detergents, seal softeners, tackifiers, colors, etc for the intended use. It's nearly impossible to backtrack to determine the additives without a product label.
So it would be risky to use as an engine oil or hydraulic oil, compressor oil, or gear oil where specific additives are essential. Bar oil just needs to stick so the lubricant can do it's single pass job. It does not have to resist long term breakdown from heat nor suspend carbon nor keep seals soft nor protect gear teeth from extreme pressures. Just stick to it.
Offline coxy
Re: oil
« Reply #10 on: January 23, 2016, 10:47:01 AM »
its vary tacky  thick but not real thick its a cool 10deg out and pours ok out of a 5 gal bucket in a 1gal jug used it yesterday seamed to be ok in the saw oiler but if it could be used for other things would be great to  MM I cant get the link to up load   thanks for all the help
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oil
« Reply #11 on: January 23, 2016, 11:36:56 AM »
Google: Chevron ISO 100
Offline dgdrls
Re: oil
« Reply #12 on: January 23, 2016, 05:56:58 PM »
https://cglapps.chevron.com/msdspds/PDSDetailPage.aspx?docDataId=323782&docFormat=PDF
"Chevron Aries lubricants are designed to give maximum protection to percussion rock drills. They are formulated from highly refined, high viscosity index, paraffinic base stocks and additives"
Dan
Offline Gearbox
Re: oil
« Reply #13 on: January 23, 2016, 07:58:08 PM »
Good find .My book calls it Vistac . Like I said Older or newer .
Offline Gary_C
Re: oil
« Reply #14 on: January 23, 2016, 08:14:19 PM »
Here is another Chevron ISO 100 that Google found.  Rando HD
Now we know that Chevron makes both Aries and Rando HD in an ISO 100 viscosity, nothing more.
Offline coxy
Re: oil
« Reply #15 on: January 23, 2016, 08:20:02 PM »
MM im lucky I can get on the ff let alone google something  :D oh what I did is   I went to the ff  :)  thanks for all the info guys
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: oil
« Reply #16 on: January 23, 2016, 10:10:34 PM »
OK, my Reply #2 was a direct quote from a Chevron site that I Googled.  That was their definition, not mine.   :)
Offline coxy
Re: oil
« Reply #17 on: February 05, 2016, 01:50:36 PM »
well I bought 15 5gal buckets of it for 10$ a bucket should have bar oil for a while  :D
Offline lumberjack48
  • 36 yrs ago, cutting Ash saw logs
Re: oil
« Reply #18 on: February 08, 2016, 06:37:30 PM »
  I used it back in the 60's for bar oil. But was a little to expensive so i quit using it.
 Rock Drill Oil
