Arborwear
Author Topic: Timber King 2500 vs WM LT70 Super Wide  (Read 3118 times)
Offline footer
Re: Timber King 2500 vs WM LT70 Super Wide
« Reply #20 on: February 10, 2016, 11:06:08 AM »
Well, the thing is on Order and is supposed to be about 6 weeks out. Will start adding pictures and such once it arrives. Will Baugh from Woodmizer Missouri is going to deliver it and do the set up / training once its done getting built.
Offline mjl_2007
« Reply #21 on: February 10, 2016, 11:12:53 AM »
I run a Super 70 wide with all the support equipment. Bought it last fall. It's had a couple hiccups, but Wood-Mizer has been excellent about getting it taken care of. I'd be happy to help answer any questions you might have.
Wood-Mizer Super 70 Wide stationary operation
Offline Cypress Man
« Reply #22 on: February 10, 2016, 08:23:13 PM »
I have  a two year old LT70 wide head dcs. It does not have the improved debarker design and it does not debark small diameter logs. Marty, do you know if WM will offer a upgrade kit to swap over to the new type?
LT70 wide head electric, IC5 Power conveyor, transfer table, Stop and Load Log Deck, Catapiller 360B Telehandler, Woodmizer twin blade edger, Logosol PH360 moulder, Extrema 26" Planner, Grizzly 16" dual conveyor resaw, Prentice 210D log loader
Offline chardin
  • Member*
« Reply #23 on: April 21, 2017, 08:57:09 AM »
I recently purchased a timberking 2200 the machine is solid I checked the design and build of all I could look at timberking, cook, woodmizer and having engineering back ground 26 years I know quality welds and dependable engineering and timberking surpasses the competition though the others are quality. As for the 2500 formerly the 2400 I would have one had the cost been lower the kubota diesel engines just sip fuel.  I do like the debarker new design much better mine is belt drive works great just a little long
Wood Mizer LT70 Super Wide (Vidjayo on da way)
Started by 4x4American on Sawmills and Milling
Last post December 23, 2017, 02:40:14 PM
by moodnacreek
LT15 Wide, LT70 Wide, where's the Wide Edger?
Started by Dave Shepard on Sawmills and Milling
Last post March 25, 2018, 11:53:41 PM
by Darrel
LT70 wide head DCS Electric
Started by Cypress Man on Sawmills and Milling
Last post January 05, 2014, 06:48:54 PM
by JFarmer
Wide head LT70 Wood-Mizer
Started by Bibbyman on Sawmills and Milling
Last post June 07, 2013, 09:27:40 AM
by terrifictimbersllc
