Author Topic: small wack,small logs,small project  (Read 798 times)
Offline Dave H.
« on: January 31, 2016, 11:33:36 PM »
leftover 2nd and 3rd  cut  logs from a job i did.favor for a friend clearing land.they wanted 5 pines cut down where their house will be going. 1st cut(from base up 10ft)logs i already cut up into 2x6's and sold.these im useing for some small projects around the yard. first is a rack to put the cut lumber on instead of stacking it back on my ramp(had to move the lumber to bring up a new log),second will be a shelter for my well pump.
Offline Ocklawahaboy
  • Learning as I go
Re: small wack,small logs,small project
« Reply #1 on: February 01, 2016, 02:47:40 AM »
Looks good.  Do those two raised bunks mean you will be picking the lumber up with a forklift from the other side?  Should make for easy handling.  Will you sticker as you go?
Offline Sixacresand
  • John and Nancy
« Reply #2 on: February 01, 2016, 08:58:54 AM »
Looks like an ideal Winter day for milling and building in South GA.
A small (very small) timber frame project
Started by MattJ on Timber Framing/Log construction
Last post January 04, 2015, 09:14:23 PM
by MattJ
4900 International for small log truck ? To small or you think it would perform?
Started by RunningRoot on Forestry and Logging
Last post November 13, 2014, 07:59:01 PM
by Maine logger88
lamp
A small organized shop, small on the outside, big on the inside.
Started by woodbowl on General Board
Last post January 18, 2007, 10:21:13 AM
by Raider Bill
small equipment small results
Started by Tom L on General Woodworking
Last post May 28, 2015, 02:08:51 PM
by hackberry jake
