BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: Borneman layout tool mod.  (Read 3689 times)
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« on: February 22, 2016, 10:37:03 AM »
I just modified my Big Al tool to make laying out peg hole location easier. I just scribed every 1/2", starting with 2". Now I can just line the edge of the tool up with the edge of the mortise and mark the hole without having to find the center. Works for 1.5" or 2" off the face. If I was doing more than that, I would put another set of scribes on the 4"/5" bar. I think this would be a good feature to see from the manufacturer.
    • My homepage
Re: Borneman layout tool mod.
« Reply #1 on: February 22, 2016, 05:53:03 PM »
I realized later this morning that the way I'm using the tool only works when you are scribing and pricking the tenons and laying out from the non-reference side of the timber. When I square rule, I drop the peg location down from the reference edge, so I'll take a square and continue those scribes all the way across the tool, and most likely will add them to the other side to get the .5" layouts as well.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #2 on: February 23, 2016, 12:06:43 PM »
Dave:
Next time we see each other face to face, I'll have to show you a new and improved "Al" layout template.
I was sent one to do a product review, which is in the works.
Jim Rogers
Offline Brian_Weekley
  • I am Batman!
« Reply #3 on: February 23, 2016, 02:02:47 PM »
Jim,
Is that available at the TFGuild?  I can't read the contact info on the square.
(Never mind--found it online at the Timber Frame HQ)
Thanks,
Brian
e aho laula
Offline Heartwood
  • Will Beemer
    • Heartwood School
« Reply #4 on: February 23, 2016, 05:44:38 PM »
$170 for the new one from Brice at TFHQ, and $130 for the original from the Guild, is a good price point separation, in my opinion. I hope the Guild's will remain popular.
The Guild's version is much lighter (aluminum vs. stainless, I guess), but Brice's has more bells and whistles. I have both.
    • My homepage
« Reply #5 on: February 23, 2016, 06:29:17 PM »
I see several things about it that I don't like. I need the graduations to start from the edge of the tool. If they don't, then the two features that I would want the graduations for don't work. I also don't like all that speed square junk on there. I'll just finish scratching mine up, and it will do exactly what I want. :)
Offline Heartwood
  • Will Beemer
    • Heartwood School
« Reply #6 on: February 24, 2016, 09:33:44 AM »
Dave,
Modifying the tool you already have to suit your needs is a good thing.
The gradations on the new one start exactly 1.5" from the edge on one side and 2" from the other, so I think that works.
Also the protractor markings are handy for those who do compound work, and much more accurate here than on a Speed Square. There used to be the Super Square around that was quite coveted by Guild members who used Hawkindale anglesĖbasically a framing square with a slot in the middle and the protractor markings. It's not made anymore so I think Brice added it to this model.
Offline opticsguy
« Reply #7 on: February 24, 2016, 11:13:02 PM »
Although i am not a timber framer I would certainly enjoy learning and doing!!  That is a very cool tool. If about 50% of the price I would consider one.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Offline rjwoelk
    • countrysidefirewood
« Reply #8 on: February 25, 2016, 01:00:17 AM »
That was one thing I would like to learn about is big al, I have seen it used but never explained, is therena book or write up on or a utobe. Heard lots of good things.
Offline Heartwood
  • Will Beemer
    • Heartwood School
« Reply #9 on: February 25, 2016, 08:08:43 AM »
Jack Sobon's Build A Classic Timber Frame House explains its use, as does my new book Learn To Timber Frame due out in May through Storey Publishing.
Offline Jim_Rogers
  • Board Moderator
    • jrsawmill.com
« Reply #10 on: February 25, 2016, 09:02:06 AM »
I did a short youtube video about the fence labels.
Search for JimRogers117 and you should be able to find it.
Jim Rogers
Offline PineHill4488
« Reply #11 on: June 13, 2016, 02:20:08 PM »
Mr. Beemer,
You and Darling Wife made sure a copy of LtTF was delivered before Father's Day 2016. I spent the weekend vastly enjoying it. Your supportive inscription is great motivation.
Thank you!
Greg
Fall 2013 purchased Stihl MS 660 and an Alaskan 36" mill, am happy with the setup, hobbyist not a volume producer, have milled oak, hickory, yellow pine, and power poles.
Offline sdesocio
  • Member*
« Reply #12 on: May 19, 2017, 12:21:53 AM »
So am I crazy or did the guild stop selling the big al?
Offline jander3
    • Peeling Logs
« Reply #13 on: May 19, 2017, 04:11:20 PM »
I called thr Guild last week.  They do not sell the big al.  The refered me to timberframehq.com.  i ordered one from there.
Jon
Borneman layout temp
Started by brendonv on Timber Framing/Log construction
Last post June 17, 2014, 06:14:52 AM
by brendonv
big al layout tool
Started by danwhitejr on Timber Framing/Log construction
Last post February 10, 2006, 12:46:25 PM
by Jim_Rogers
Cool New Tool!...Layout tape.
Started by Rooster on Timber Framing/Log construction
Last post April 17, 2016, 09:45:35 AM
by Jim_Rogers
Tractor 3pt Multi-tool - And Another Log Handling Tool Added
Started by tcsmpsi on General Board
Last post February 08, 2007, 07:18:52 PM
by SPIKER
