Author Topic: Looking to buy a Bandmill  (Read 8775 times)
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Looking to buy a Bandmill
« Reply #80 on: March 07, 2016, 06:59:32 PM »
X2 for kb. 👍👍
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline Gitrdone64
« Reply #81 on: March 07, 2016, 09:16:23 PM »
If you have a barn or large shead you could hang it from the rafters when you
need to use the trailer.
I got plenty of room to store it.
40x40 shop
30x75 barn.
I'd rather be a has been then a never been!
Hud-son Oscar 236 Pro
Offline justallan1
  • living and learning
« Reply #82 on: March 07, 2016, 09:59:24 PM »
I have an idea kicking around in my head.
Was going to build a trailer for my new sawmill but now thinking of buying a heavy car hauler type trailer to set the mill on and use a winch to pull up the log onto the trailer from rear and roll onto sawmill bed. So if not using sawmill I could still use trailer for other task or to haul logs home.
Here Is what I did for the HFE-21. The biggest problem with the trailer with side rails was safety. If a log rolls, there was no where to go. With the right safety precautions it was fine. I could dead stack lumber on each side of the track and take the entire trailer home at night or when leaving the mill and trailer I would park the truck real close and off-bear right onto it. The nice thing with using the trailer was that between the track, the steel framed box for the track and the trailer, it was stiff enough that I had little to no flex and it was a piece of cake to level.
Offline Gitrdone64
« Reply #83 on: March 07, 2016, 10:34:01 PM »
Cool idea the trailer I am speaking of has no side rails.
Offline Gitrdone64
« Reply #84 on: March 08, 2016, 05:35:07 PM »
Justallen1 this is the kind of trailer I was talking of.
I want one with slide in ramps.
Mount the winch up at gooseneck and pull log up from end of trailer.
102" wide by 24' long.
Offline Upper
« Reply #85 on: March 08, 2016, 05:56:35 PM »
You could use those ramps as a log arch,maybe
Stihl 661
Alaskan 36 CSM
36" guillotine splitter powered by a GMC V6
I like to build stuff
LT35HD Wood-Mizer
Offline Gitrdone64
« Reply #86 on: May 20, 2016, 09:58:21 PM »
Well I haven't been on in a while. I feel in my shop working on adding a second floor and broke my knee in three places back on 3/16/2016.
Did buy a new trailer for healing logs or saw mill its a 24' car hauler with a dove tail. Did get one of the pecan trees cut up and loaded onto the trailer.
Waiting on broke leg to finish heeling so I can build the sled frame for saw mill.
Have 12k winch to pull logs onto trailer.
Offline Gitrdone64
« Reply #87 on: May 20, 2016, 10:00:47 PM »
Still have 2 more trees to lay down. about same size. No hurry to saw them and dry. My kids are holding off for about 5 years on building them a house. So now we can cut logs up and let them air dry slowly.
Online thecfarm
« Reply #88 on: May 21, 2016, 06:01:59 AM »
Spend your healing time on here!!! Hope all heals well.
Offline Gitrdone64
« Reply #89 on: May 22, 2016, 01:05:22 PM »
I haven't wanted to do much of nothing. Getting to feel much better. Hope the doctor will let me start walking in June.
Offline BigDogTreekillr
« Reply #90 on: March 03, 2017, 06:08:20 PM »
Definitely don't let walking in sawdust discourage you from the WM 10 and 15. Both are great rigs and very dependable. Adding a power feed makes sawing all most effortless in comparison to pushing it. Add a bucket or dust collection system. I have had a lt 15 with the yanmar diesel and power feed for 3 years now and wouldn't trade it for nothing! Great Lumber and can saw all day on 1 tank of fuel!
Mopar Go Far! Whoopaaa
Tru-cut bandmill
Started by dunit on Sawmills and Milling
Last post January 05, 2018, 03:55:54 PM
by Doug Clark
another bandmill
Started by dancan on Sawmills and Milling
Last post December 23, 2007, 09:04:59 PM
by Furby
Got a bandmill
Started by Carpenter on Sawmills and Milling
Last post April 18, 2011, 02:33:29 PM
by metljakt
New bandmill toy, now what have i done,,?,,,,,,,,
Started by Hbarker on General Board
Last post February 02, 2006, 04:53:46 PM
by IL Bull
