Arborwear
Author Topic: Putting a license place on an LT40HD?  (Read 2024 times)
Online OlJarhead
    • Dartplayer
« on: February 25, 2016, 12:38:48 PM »
OK, so in WA State you have to license trailers but I didn't see any good place other than the fenders to do this.  Has anyone else had to put on a plate and if so, where did you place it?  How?
Thanks!
2016 LT40HD26 and Mahindra 5010 W/FEL
Offline ncsawyer
Re: Putting a license place on an LT40HD?
« Reply #1 on: February 25, 2016, 01:48:33 PM »
This is a picture of my old 1994 LT40.  It had a license plate bracket with a tag light.  You can see it just below the manual toe board.
I now have a new LT40, but I can't remember if it has the same tag bracket...this has my curiosity up.  I will have to check when I get home.
We don't need a plate here in NC.  That is probably why I have not noticed.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #2 on: February 25, 2016, 03:11:51 PM »
Mine is hanging beneath the rearmost fixed rail.  Woodmizer put it there. There is a license plate light above it.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
« Reply #3 on: February 25, 2016, 03:14:13 PM »
Thanks!
Jeff may soon stop by and tell you that "a sawmill is not a trailer".  Are you sure it is regarded as such by your state, or might it fall into a different category with woodchoppers, log splitters, generators, etc?
Online OlJarhead
    • Dartplayer
« Reply #4 on: February 25, 2016, 03:27:56 PM »
Found it!  Right where you suggested!
Too easy.
And yes in WA State it is required though they don't have 'sawmill' under trailers so wrote it in LOL
« Reply #5 on: February 25, 2016, 03:31:48 PM »
Must be a different mill I thought you got some sawdust on yours.  :) :D
Offline ncsawyer
« Reply #6 on: February 25, 2016, 03:48:17 PM »
Too easy.
Ah...same as my old one...now I will not have to out and look at my new one!
Offline KirkD
« Reply #7 on: February 25, 2016, 03:49:23 PM »
Thanks!
Mine is mounted in the center of the band wheel cover on the idler wheel side.
Wood-mizer LT40HD-G24 Year 1989
Online OlJarhead
    • Dartplayer
« Reply #8 on: February 25, 2016, 03:55:57 PM »
One log only at WM....lots more to go but there is sawdust on the mill :)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #9 on: February 25, 2016, 04:47:19 PM »
In Maryland, I have a "mobile equipment tag" on my woodmizer.
lots of dull bands and chains
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: February 25, 2016, 10:28:40 PM »
Thanks!
Eric, But an LT40 is not a trailer, it is a piece of equipment, kind of like certain farm implements!
Maybe it doesn't need to be plated!
I know all states are different, here in NY a plate is not required!
~Chuck~
I LOVE MY SAWMILL
Offline Brucer
  • The Kootenay Sawyer - retired (for now)
« Reply #11 on: February 26, 2016, 02:29:53 AM »
Gotta have a plate in BC. Even though it's a sawmill, it's considered a trailer here. The rules vary all over the map.
When I bought my mills, the WM rep sent me to one specific agency because they were the only ones who had figured out how to handle the plates for a sawmill.
Bruce    LT40HDG28 bandsaw with two 6' extensions.
Offline pine
« Reply #12 on: February 26, 2016, 02:39:30 AM »
In WA state (where OlJarhead is located) if it is towed behind a vehicle it is a trailer. Yes I know some individuals have strong opinions that they hold saying otherwise but in WA state it is a trailer and must be licensed as such.  Been around and around on this one many, many times.  Each state has their own rules and we have 50 different states.
Canada has ten provinces and three territories.  Does their national system override the provincial or do they vary as much as we do down here?
Offline Dloiselle
« Reply #13 on: February 26, 2016, 07:21:18 AM »
I agree as for NY. It falls under agricultural equipment, same as my hydro seeder, my firewood processors I have had were the same, wood splitter, wood chippers etc. WHere is gets funky here is for example, I was carrying seed, fertilizer or mulch bales on the seeder, then it is a trailer. SMH :) NY alays finds a way to get into your pocket
Kenworth W900 Triaxle Dump
Bobcat E42
Cat 257B3
Harley Rake, Grapples, 4in1, High Dump Bucket, forks, etc
Hyundai Dozer
20 Ton Equipment Trailer
40' Gooseneck
22' 9 Ton Tag Trailer
American 24HH Splitter
Husky, Stihl
Now to figure out what mill to get
Offline sawguy21
« Reply #14 on: February 26, 2016, 11:53:25 AM »
It is all over the map here too. Each province establishes their own rules for licensing drivers and vehicles.
Offline CharlieA
« Reply #15 on: February 26, 2016, 02:02:01 PM »
Brucer, I was sent to the same one in Salmon Arm.  ;)
Good, Fast, Cheap... Pick 2.
Offline DaveinNH
« Reply #16 on: February 26, 2016, 04:58:11 PM »
About a week after I bought my mill last August Wood-Mizer sent me a certificate of origin for just the trailer kit portion of my mill (LT40HD). I was able to use that to get a title (NH requires it) and my plates.
Wood-Mizer LT40HD26     Polaris 6x6 Big Boss
Ariens 34 Ton Splitter       Stihl 460, 261, 70
Online OlJarhead
    • Dartplayer
« Reply #17 on: February 26, 2016, 05:08:25 PM »
Too late now but would be nice if they sent that with a price on it for JUST the trailer...then I'd not have to pay the taxes on the whole thing! lol
« Reply #18 on: February 26, 2016, 05:16:46 PM »
Are you talking property tax or sales tax?
Online OlJarhead
    • Dartplayer
« Reply #19 on: February 26, 2016, 05:18:17 PM »
Sales
Bought the mill in OR (no sales tax) pulled it back to WA (sales tax) and since I need to tow it around I have to register it which means I have to pay the taxes in WA on it....cost me $2300!  :o
I went for my license, They went for their gun
Started by etat on General Board
Last post February 27, 2004, 04:48:16 PM
by etat
loggers license
Started by logman81 on Forestry and Logging
Last post March 11, 2011, 08:49:04 AM
by bill m
New License Plate
Started by Hokiemill on General Board
Last post November 16, 2005, 02:11:04 PM
by Murf
business license
Started by TnSawyer on Sawmills and Milling
Last post March 25, 2007, 09:42:58 AM
by Brad_S.
