Arborwear
Author Topic: starter question  (Read 1853 times)
Offline teakwood
  • Switzerland
starter question
« on: February 29, 2016, 11:33:42 AM »
 my excavator has a 8.3l cummins. sometimes the starter turns fine and sometimes the starter just makes a klick noise and wont turn! Whats the problem? do they have carbons like a car starter who might be worn?
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
Re: starter question
« Reply #1 on: February 29, 2016, 12:03:14 PM »
If you haven't already check your grounds  :)
Offline Mountaynman
  • work from the southern adks to the catskills in NY
« Reply #2 on: February 29, 2016, 12:30:22 PM »
bettin on bad ground or greenitis in the cable just replaced the ends on my forwarder with all soldered on connections no problems this winter
1999 546 Fabtek 2009 450J 1999 Prentice 210E Run Husky 372xps and 660 Stihls
Offline teakwood
  • Switzerland
« Reply #3 on: February 29, 2016, 12:47:37 PM »
checked al the cable connections and cleaned them. Probably the starter solenoid. also hit the solenoid case with a hammer.
Offline Plankton
« Reply #4 on: February 29, 2016, 01:12:04 PM »
Sounds like the solonoid, when it clicks you can check your voltage drop. You can jump the terminals to by pass the solonoid too before you replace it.  make sure you have battery voltage to the hot post on the solonoid when the key is on, could also be a intermittent connection there.
Double check your grounds same thing happened to me a month ago thought they were good, went through them again and problem solved.
Offline Knocker of rocks
« Reply #5 on: February 29, 2016, 01:30:11 PM »
Bad battery
Offline teakwood
  • Switzerland
« Reply #6 on: February 29, 2016, 01:30:18 PM »
Batterys are 2 month old.
There is just on big red cable and a small black one going to the solenoidcase. How do i jump them?
How is a starter grounded? because its bolted on the engine and engine is grounded to chassis? Will check those grounds
Offline Northern Logger
« Reply #7 on: February 29, 2016, 01:49:52 PM »
New or not, check all of your batteries separately.  Need about 13.5 volts across each set of terminals.
Offline Plankton
« Reply #8 on: February 29, 2016, 02:32:08 PM »
Sounds like your ignition wire and the big red is battery power, should be direct from battery.
Jump across the two large terminals that's what the solonoid does inside. Jumping manually bypasses the solonoid you can see if the starter has an issue or the solonoid is not connecting.
Offline teakwood
  • Switzerland
« Reply #9 on: February 29, 2016, 03:03:18 PM »
Ok. checked all the battery terminals, grounds and engine-chassis ground cable, wire brushed them put a little WD-40 on them, reconnected and she fired right up! 8) 8) Was just a bad connection
Thanks guys, really appreciate all the help!
Offline lynde37avery
  • machines from the 1970's making a living today
« Reply #10 on: March 01, 2016, 07:32:11 AM »
Solenoid is bad i guarantee it. I just did one on my old skidder.  And it made the same click,click noise.
Detroit WHAT?
Offline UN Hooker
« Reply #11 on: March 02, 2016, 08:15:35 PM »
  If yer runnin a Cummins in anything, and your battery & connections are good,and you still get the "click click", then 90% of the time one of the solenoid contacts is worn thin. Only one arcs and wears - so I only replace the one. I only buy and use the 24volt ones in all solenoids. They can be bought in some starter repair shops for $$ or on flee-bay for cheap. They are easy to change but do not over tighten the bolts in the plastic cap, it will crack.
     The pic. below shows 3 contacts.  The one on the left is worn (the end facing you) the center is the standard 12V - the one on the right is the 24V.
         UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
Starting with a starter question.
Started by luvmexfood on Forestry and Logging
Last post March 28, 2015, 05:44:37 AM
by shinnlinger
starter
Started by trapper on Bluecreeper
Last post May 17, 2016, 06:11:58 AM
by Tam-i-am
3-53 Starter
Started by jwilly3879 on Forestry and Logging
Last post April 06, 2015, 03:40:03 PM
by lumberjack48
new starter
Started by hayton1960 on Timber Framing/Log construction
Last post September 08, 2005, 06:18:10 AM
by hayton1960
