Arborwear
Author Topic: Detroit 4-53 fan  (Read 1185 times)
Offline Spartan
Detroit 4-53 fan
« on: March 10, 2016, 08:18:46 PM »
Anyone know where I can get a 22" suction fan?  I have a pusher on my TJ and want to get a suction fan.  Can't seem to find anyone with one.
Offline cuznguido
Re: Detroit 4-53 fan
« Reply #1 on: March 10, 2016, 09:09:23 PM »
Are you sure yours is not reversible?
Offline Spartan
« Reply #2 on: March 10, 2016, 09:39:11 PM »
Positive.  Same airflow when flipped over.  tried it.
Offline coxy
« Reply #3 on: March 11, 2016, 07:04:12 AM »
do you know how hot  you  will be in the summer we have a 518 with a suction fan that sits most of the summer cause its to hot to run and the blades are seized so we cant reverse them  its real nice in the winter it keeps your feet peachy
Offline Spartan
« Reply #4 on: March 11, 2016, 07:08:35 AM »
I will probably throw the pusher on again in the summer
Offline mad murdock
« Reply #5 on: March 11, 2016, 01:24:11 PM »
I would look for the spring loaded type of fan that allows individual turning of each blade.  We had that type of fan on a couple of our pieces of equipment back in the day, sure made a world of difference warmer in winter and way cooler in summer (for the operator).
JD AMT 626, Turbosawmill M6 Warrior Ultra liteweight, Granberg Alaskan III, lots of saws-gas powered and human powered :D
Offline lewis
  • the best tree is a stump
« Reply #6 on: March 11, 2016, 03:21:01 PM »
anderson bros, eugene oregon
Offline treeslayer2003
« Reply #7 on: March 11, 2016, 07:02:11 PM »
why? it won't cool any better. if it runs hot some thing else is the culprit.
Offline brianJ
  • Only get excersize if I choose the right hobby
« Reply #8 on: March 11, 2016, 07:46:43 PM »
Not really a fan of any of the Detroits much less the 4-53. :D ;D :o
Offline Spartan
« Reply #9 on: March 11, 2016, 08:12:01 PM »
It wont cool any better yes, but it also wont blow oil into the radiator and plug it up.
I know, fix the leaks.  Eventually I will.
Offline Logger RK
« Reply #10 on: March 11, 2016, 09:37:49 PM »
I've notice on them motors that are in need of a rebuild & have a lot of blow by,u can put the blow by tube in a gallon jug. So the fine oil mist isn't getting blown into the radiator & all over. Unless u have other bad leaks?
Offline lewis
« Reply #11 on: March 11, 2016, 09:47:59 PM »
Detroits  are like harleys,if they aint leakin they aint runnin
Offline Spartan
« Reply #12 on: March 11, 2016, 10:02:42 PM »
No, its a good strong motor, 4k hours on it or so.  I just think it sat for a while and the seals dried up.  I fixed my crank seal leak only to have the cam seal leaking now and possibly the upper cover as well.  It was murder trying to get the crank bolt out and seal, and the torque specs are the same for the cam.  So I am anticipating bad times.  That equals lots of down time which equals major investment.
Doesn't leak that bad but I just had to pull the radiator out and heat spray it as I was getting warm and its not even spring.  couldn't even see through it.  Now all is fine, just don't want to have to repeat the process too soon.
Eventually I will fix it, just not smart right now.
Offline coxy
« Reply #13 on: March 12, 2016, 07:28:22 AM »
easy off oven cleaner works the best on dirty radiators spray on let sit 15-20min and wash with a garden hose
« Reply #14 on: March 13, 2016, 07:55:57 PM »
yeah, btdt. it will then make the engine compartment oily n nasty. i rather clean the rad.
8.2 Detroit
Started by Birchwood Logging on Forestry and Logging
Last post March 03, 2014, 07:58:24 AM
by bigred1951
Detroit 3-53
Started by Tripp on Forestry and Logging
Last post April 17, 2012, 10:25:37 PM
by Tripp
wireless
Detroit 353
Started by Wild willy on Wanted
Last post December 09, 2011, 04:43:41 AM
by boatmiser
detroit 353
Last post March 28, 2010, 09:06:08 AM
by Wild willy
