Tally-I/O
Author Topic: Thinking ahead for a harvest  (Read 1625 times)
Offline Mountain View
« on: April 01, 2016, 10:23:28 AM »
New to the forum and looking to tap into the vast knowledge within the membership.
I have a 100 acre parcel which is @70 acres hardwood (mainly hard maple, beech, some ash, oak, yellow and white birch) with the remaining being old pasture.
I am at a high point of land therefore the beech do very well.  The property was raped by poor logging @45-50 years ago therefore most of my trees (I have only had the property 4 years) are close in size.  There is a fair bit of crowding in my bush due to similar size trees. Eventually (In my lifetime I hope , just turned 50) I hope reap some financial benefit from the maples being logged. They are tall and straight but all around that 10" at BH.  Thoughts on thinning. Way too much for me to do I would have to bring someone in. I am an hour and a half west of Ottawa.
Paul
Offline Tarm
  • White Pine Fever!
Re: Thinking ahead for a harvest
« Reply #1 on: April 01, 2016, 04:34:22 PM »
It sounds like you have a classic northern hardwood even aged stand. It was probably given a diameter limit cut 50 years ago. If you have a hardwood pulp/bolt market in your area then a thinning is in order. It is best to get a forester to mark an improvement cutting. The idea is to remove the poor quality, low vigor and value trees, giving the high value (maple, oak, yellow birch etc.) more room to grow. Get the job done by a logger with a processor. That should leave you a stand with minimal damage. Maple trees grow slow but you should be able to turn a 10 inch tree into a 16 inch tree in your lifetime.
Good luck.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #2 on: April 01, 2016, 05:27:30 PM »
No advice, but Welcome to the Forestry Forum, Mountain View.   :)
« Reply #3 on: April 01, 2016, 06:35:32 PM »
Thanks for the advice and the welcome. I am enjoying catching up on the thousands of posts.
Offline Clark
« Reply #4 on: April 01, 2016, 07:23:42 PM »
You aren't in the exact same area as ehp but he has shown some spectacular logs he has cut (closer to Toronto). It sounds like where he is at has forest management down so that landowners can't high-grade a stand and leave it for whomever comes next.
Be that as it may, I would also suggest a forester. With higher quality timber they will pay for themselves in short order and the continued benefits of growing the best timber will pay dividends over time.
Clark
SAF Certified Forester
« Reply #5 on: April 02, 2016, 11:20:58 AM »
Thanks Clark, I planned on having a forester come in an walk the property with me and discuss what is best.  Have the trees marked then open it up for bids would likely follow.  I have heard horror stories of landowners having the logger set the price only to discover later they undervalued the harvest by thousands.  Does anyone have any ideas on hardwood pulp values, a rough estimate?
Offline Ron Scott
  • Forester
« Reply #6 on: April 03, 2016, 08:01:13 PM »
Sounds like you are on the right track. Get yourself a certified forester and seek their professional advice in managing your property to meet your objectives. They will know the current prices for the marketable timber products by species for your area.
~Ron
Offline WildlandFirefighter912
« Reply #7 on: April 04, 2016, 07:21:15 PM »
Paul
Check the basal area. More than likely thin out the inferior trees.
As others said...find a consulting forester
Offline Mountaynman
  • work from the southern adks to the catskills in NY
« Reply #8 on: April 05, 2016, 09:01:52 PM »
you wont make much money on the current harvest of pulp but find a forester that has a good reputable cut to length crew with an awesome operator go look at some jobs that they have done and turn the man loose you wont find someone to mark pulp wood anymore or want  to pay the man to do it marking the leave trees wd take as much time the good operators tday make a forestors job a little easier not sure about up there but here after a good thinning we can put a 1/3 of an inch of growth on a tree in the best conditions making a 10" tree a 20" tree in ten years
1999 546 Fabtek 2009 450J 1999 Prentice 210E Run Husky 372xps and 660 Stihls
Offline lshobie
« Reply #9 on: November 20, 2016, 08:04:04 AM »
HI Paul, did you ever find anyone to check out your property?  I am in the renfrew area and know some people you can trust.
Cheers.
Louie
Clark 664C, Woodmizer LT40, Alaskan Mill, Huskys, Stihls, and echos.
Thinking ahead, Quonset Hut heating and cooling
Started by jayhdjr on Alternative methods and solutions
Last post December 20, 2017, 05:18:01 PM
by jayhdjr
Way Ahead
Started by jargo432 on General Board
Last post February 10, 2015, 10:45:08 PM
by coxy
Looking ahead
Started by Herb Brooks on Sawmills and Milling
Last post June 05, 2014, 01:17:04 PM
by papow22
Plan ahead
Started by bandmiller2 on Sawmills and Milling
Last post March 01, 2015, 08:46:59 AM
by IndianaJoe
