Author Topic: PTO speed  (Read 903 times)
Offline thechknhwk
    • Story of the Trees
PTO speed
« on: April 01, 2016, 09:37:06 PM »
I have an implement that states it needs to run at 305-350 PTO speed, but I'm not sure how to figure it out.  I have the 540 mark on my tach, so can I use a straight ratio to figure the appropriate engine RPM's to achieve the desired PTO speed?
For example
2100rpm = 540pto
2100/540 = 3.88 RPM's per PTO rpm, so 325*3.88 = 1264 RPM's.
The manual does say to run between 1000-1300 RPM's, but it also says exceeding the recommended PTO speed can damange the implement.
Any insight is welcome; I did search the interwebs for a conversion table but was unsuccessful.  The tractor is a Kubota L3800.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: PTO speed
« Reply #1 on: April 01, 2016, 10:24:27 PM »
Google "handheld tach".  Once you get it set for the proper PTO rpm's, you will know the proper engine speed.  That may be a solution.
Offline fishpharmer
Re: PTO speed
« Reply #2 on: April 01, 2016, 11:08:01 PM »
thechknhwk, you have already deciphered the solution.  Your calculation for engine rpm to pto rpm is correct.  It also equals the manuals recommended engine rpm.
What type of implement is it, I am curious?
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline thechknhwk
Re: PTO speed
« Reply #3 on: April 01, 2016, 11:32:01 PM »
I may show & tell after I figure it out.  I'm sure you'll see a picture pop up sooner or later.  It's not anything super special, but I try not to be a show off.  Unless maybe it's my barn :D
Online John Mc
Re: PTO speed
« Reply #4 on: April 02, 2016, 08:20:35 AM »
You've got it right, it's just a linear relationship. The easy way to think of it is what percent of the rated 540rpm PTO speed is your desired speed, then take that same percent of the 540PTO engine speed to get your PTO where you want it. (if you want half rated PTO speed, run your engine at half the 540PTO RPMs)
In this case 325/540 = 60.2%
60.2% of 2100 = 1264 RPM
Offline gspren
Re: PTO speed
« Reply #5 on: April 02, 2016, 09:43:33 AM »
  The only thing I'll add is that your rated PTO horsepower is at 540 so when you drop to a lower RPM you also lower your available HP, that may or may not be a problem depending on your "secret" implement.
Offline thechknhwk
Re: PTO speed
« Reply #6 on: April 02, 2016, 12:47:01 PM »
Thanks all
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: PTO speed
« Reply #7 on: April 02, 2016, 03:16:01 PM »
Snow Cone Machines do not need much horse power.   :)
Saw speed on M-14
Started by dustyjay on Sawmills and Milling
Last post March 25, 2015, 08:24:21 AM
by bandmiller2
saw rpm speed what the !
Started by minesmoria on Chainsaws
Last post February 08, 2006, 08:35:55 AM
by sawguy21
Need to speed up
Started by CLL on General Board
Last post February 24, 2009, 09:03:37 PM
by CLL
13 speed
Started by coxy on Forestry and Logging
Last post June 24, 2017, 11:34:17 AM
by ScottAR
