Baltic Abrasives Technologies
Author Topic: ford backhoe hydraulic fitting ..help!  (Read 1799 times)
Offline 47sawdust
« on: April 02, 2016, 07:49:12 AM »
The hose for my bucket on my 550  ford separated from the fitting and I need to replace it.I'm a first time owner and I'm not sure how to proceed.The fitting in question is behind 6 other fittings so I'm assuming I have to remove whats in the way to access it.It looks like barked knuckles and swearing will be the order of the day.It is a 4 stick machine and the fitting is below the controls.
 Any tips or new swear words are appreciated.
 Thanks,Mick
Mick
Offline 69bronco
Re: ford backhoe hydraulic fitting ..help!
« Reply #1 on: April 02, 2016, 08:09:28 AM »
You'll come up with a few new words of your own before your done! I'd look the hoses you take off over real close, replace what you need. Mr. Murphy says the one beside it will blow next : :-[
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #2 on: April 02, 2016, 08:22:27 AM »
Start taking off hoses until you can get a wrench to work on the bad hose.  That's the only way to do it.  Welcome to the world of heavy equipment repair  ;D ;) :) 8)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: April 02, 2016, 08:25:43 AM »
Just be sure to put the removed hoses back where they were or you may have to repeat your cussin' assignment.
Offline 47sawdust
« Reply #4 on: April 02, 2016, 08:50:15 AM »
Thanks for the replies.I will take a picture and use some colored zip ties to mark hose location before I start.A good pressure wash is in order as well,this machine hasn't had a lot of love,but it has a good home now.
Mick
Offline sandsawmill14
  • love my job (most days)
« Reply #5 on: April 02, 2016, 08:51:17 AM »
x2 go ahead and mark them i've had a 555 ford since '93 or '94 and those lines are easy to confuse but not so easy to straighten out so i mark with tape as i take them off :)
Offline whiskers
  • Over what hill? I don't remember any hill.
« Reply #6 on: April 04, 2016, 09:00:22 PM »
http://www.surpluscenter.com/hydraulics/
this site has some handy information that I found helpful while getting my old 4400 ford bh back together. fittings can be confusing since there's several styles to deal with. get the free catalog, lots of good stuff there.
many irons in the fire.........
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #7 on: April 04, 2016, 09:05:43 PM »
I have a 2 stick 550C. Yes you will have to remove what you need to move just to get to it.
Just take some spray paint and paint the hose on each connection before removing.
Its aggravating, I know and it will take a little time.
WATCH out for the "O" rings. Its probably a good idea to replace the o-ring too.
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #8 on: April 06, 2016, 12:46:13 AM »
A dot with a center punch on each fitting works good too for smaller numbers.
If you can get to them, a rap with a hammer with another larger hammer on the opposite side for backup makes the fittings some easier to loosen.
Scott
[Magicman]
hydraulic fitting
Started by rockwall on Forestry and Logging
Last post August 10, 2016, 08:28:57 AM
by Furu
What is this hydraulic fitting called?
Started by Don P on General Board
Last post April 10, 2018, 08:26:58 AM
by Don P
WM hydraulic hose fitting problem.
Started by Jim_Rogers on Sawmills and Milling
Last post October 07, 2013, 03:45:24 PM
by bill m
Ford 550 backhoe cab parts
Started by 47sawdust on Wanted
Last post June 20, 2015, 08:03:46 PM
by 47sawdust
