Tally-I/O
Author Topic: Band width question?  (Read 1174 times)
Offline kenfrommaine
« on: April 22, 2016, 06:09:12 PM »
Hello everyone
I have been lurking for sometime and gathered a lot of interesting things from this group. Lots of knowledge here for sure. Thank you for letting me join.
I am starting a bandsaw build and have some questions.
I have 20" bandsaw wheels they have 1" axle holes and the wheels themselves are 1.5" wide, what width blade can I or should I use use? Also what is the opinions of this motor DuroMax XP18HPE 18 HP Electric Start Go Kart Log Splitter Gas Power Engine Motor they sell for just over $300. on ebay new. Any good?
Thanks again and I will be asking I am sure lots more questions.
Ken
Re: Band width question?
« Reply #1 on: April 22, 2016, 06:11:56 PM »
Here are the specs on the motor above....SPECIFICATIONS
Displacement:   440cc Bore: 92, Stroke: 66.
Max Output:   18.0 HP / 3600 RPM.
Max Torque:   21.0 ft/lb.
Shaft Size:   1" Diameter, 2 Long, Keyway,
Shaft End:   3/8 Size 24 UNF - Drilled and Tapped
Measurement from Center of Shaft to Base:   5"
Dimensions Of Unit:   16.4L x 17.9W x17.4H
Fuel Tank Capacity:   1.7 Gallons
Average Run Time:   1/2 Gallon Per Hour (at 1/2 load)
Dry Weight:   77 lbs
Recommended Fuel Type:   Gasoline - 87 Octane Rating Or Better
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #2 on: April 22, 2016, 06:28:27 PM »
First, welcome to the forum, it's the best.
If your wheels/tires/belts have a good crown, you can run pretty much whatever you want.  Adjust your tracking accordingly to keep the teeth off the rubber.  Most common is 1-1/4" followed by 1-1/2".  Most common tends to be most cheap.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: April 22, 2016, 08:30:24 PM »
kenfrommaine, I am not a sawmill builder, but Welcome to the Forestry Forum.
Offline ozarkgem
  • age 65 yrs old
« Reply #4 on: April 22, 2016, 09:00:35 PM »
For 18 HP use the  1 1/4 width blades.
« Reply #5 on: April 22, 2016, 10:26:10 PM »
Thanks for the welcome and thanks for the input. The wheels I have are from an old large band saw I don't think they have a crown I think they are flat surface. I will check in the am.  Is 18 hp enough? I am looking to build this mill for sawing out both hard and soft woods. I am a cabinet maker/contractor and also cut some logs. I have some large pasture pine that I would like to slab out for counter tops and bars etc. along with regular boards. So I need to build this big enough to handle I figure 30" to 36" logs, not cutting a lot of slabs but want the option.  Mostly the mill will be cutting 12" to 24" logs. I have a welder, plasma cutter and most of the necessary tools/toys. Looking at some of the pics of the mills some of you have built is very impressive. thanks again.
Offline redprospector
« Reply #6 on: April 23, 2016, 12:44:24 AM »
Just my 2 cents.
I don't think your wheels are going to work well for you. At 1 1/2" wide you're going to need a band that's wider than the wheels, and the center bore being only 1" I'm going to say is too small for what you are wanting to do. The mill I built has 1 1/2" shafts, and I've had problems with them a time or 2.
You could probably get by with 18 hp, but more is always more better. ;)
I've ran mills with 14hp, 16hp, 20hp, a 53? Hp VW, and the one I'm running now has a 27 hp Kohler. I love cutting with the VW, but the 27 horse has hydraulics on the bed and will out perform at the end of the day.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #7 on: April 23, 2016, 12:51:44 AM »
You need to use something like 4150 steel for your 1" axles or something better than cold roll.
With flat wheels you could have a machine shop crown them for you or you could buy some
band saw tires. Band saw tires is a strip of crowned rubber or polyurethane that fits around
your wheels.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline ozarkgem
  • age 65 yrs old
« Reply #8 on: April 23, 2016, 06:24:52 AM »
Just my 2 cents.
Never thought about a VW engine. I would think that would kick butt.
Offline Ox
« Reply #9 on: April 23, 2016, 08:29:43 AM »
I have a 13hp engine on my mill.  I was able to saw a monster black cherry that was just under 3' across.  There is just over 32" of clearance between the guides.  It was maxed out.  The 13hp did it.  Slowly, but did it.  Normal logs there is no problems for me.  I'm not in production, just for us so speed isn't an issue.  Just to give you a little perspective that your 18hp will be good enough, I'm betting.  :)
Offline muggs
    • Hardins industries
« Reply #10 on: April 23, 2016, 09:30:45 AM »
The specs on the engine don't add up. 18 hp at 3600 rpm . The torque should be more like 27 ft. lbs. I think they are being optimistic  on the horsepower.     Muggs
Offline Bruno of NH
« Reply #11 on: April 23, 2016, 09:45:37 AM »
I have a 13hp honda on my mill and run 1 1/2 bands and cut big logs . When a band starts to dull I change it out right off .
Bruno
Lt 40 wide with 38hp gas and command controls Riehl Steel edger,F350 4x4 dump and lot of contracting tools
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #12 on: April 23, 2016, 10:06:34 AM »
Welcome to the Forestry Forum, kenfrommaine.
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline Ox
« Reply #13 on: April 23, 2016, 05:32:48 PM »
I don't know about the torque but my 13hp is 420cc.  At least that's what the sticker says.  A 430cc should be around 12 - 15hp or so, according to this theory.
Width of your band wheel, width of your blade?
Started by valley ranch on Sawmills and Milling
Last post March 09, 2015, 12:41:02 AM
by valley ranch
Length and width of band saw bed
Started by Grappletractor on Sawmills and Milling
Last post March 22, 2006, 06:56:17 PM
by Grappletractor
Band saw wheel width
Started by black on Sawmills and Milling
Last post August 24, 2015, 08:30:53 PM
by bandmiller2
Blade Band Width
Started by MartyParsons on Sawmills and Milling
Last post May 21, 2007, 07:54:28 PM
by theorm
