Author Topic: Husqy 141 oil cap problem  (Read 945 times)
Offline bruciie
« on: October 28, 2004, 05:42:59 PM »
Hi
I can't open my 141 oil cap.  I can turn it round and round but it just stays in the same position.  It won't unscrew.
Any suggestions for getting it off.
Bruce
Offline rebocardo
  • Atlanta GA
Re: Husqy 141 oil cap problem
« Reply #1 on: October 28, 2004, 09:37:21 PM »
Assuming it is like every other oil cap, slip a small blade screw driver between the case and cap, lift up on the screw driver while turning the cap. If that fails, get a pair of vise grips, clamp on the ridge, and lift up/pull while turning.
Husqy 55 clutch problem
Started by kyfarmer on Chainsaws
Last post October 21, 2004, 08:18:08 PM
by kyfarmer
I want a Husqy. 372 vs 575
Started by David B on Wanted
Last post November 19, 2005, 12:58:55 PM
by sawguy21
question
Husqy 55 won't run
Started by jteneyck on Chainsaws
Last post September 02, 2009, 09:48:26 PM
by jteneyck
replacing rin on Husqy
Started by kelLOGg on Chainsaws
Last post November 07, 2010, 08:59:12 AM
by Cut4fun
