AVAILABLE
Author Topic: Sawing Prices over 12 foot.  (Read 3461 times)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« on: April 28, 2016, 08:25:26 AM »
For over 5 years I've been sawing softwood at 250/thousand and hardwood at 300/thousand.
During those 5 years I have learned to use my mill to saw wood for different markets. I can make a ton of money on just log flower boxes which pays way more than sawing lumber. This is just 1 example.
I am gonna raise the sawing per bf on anything over 12 foot.
I know some of you do it already for the reason it just takes more manpower. time and equipment use.
One thing I can do is to turn anything away thats over 12 foot and recommend another sawmill. Knowing where ALL the sawmills are in my area and how they saw, if I did recommend them, the drive would be rediculas for a customer to take his logs over 12 foot to them.
So what would be a fair price to saw over 12 foot?
2-1/2 days a week I have help,  the rest of the time I work by myself, I can do it by myself with just me and my backhoe....but its tough, especially when logs get to 16-20 length.
So what is you price recommendation or what are you charging?
Thanks Y'all.
Offline slider
  • sawyer,trucker,tree service
Re: Sawing Prices over 12 foot.
« Reply #1 on: April 28, 2016, 08:40:47 AM »
I've been at 30 for a while now with no complaints David.
al glenn
Offline LittleJohn
  • I am not a professional, I just pretend I am...
« Reply #2 on: April 28, 2016, 08:42:42 AM »
You could look to charge by the hour??
I personally like sawing the long stuff, the board feet add up faster, assuming relatively straight logs with minimal stress  :D ;D
In most cases I leave pine logs at 17' saw them and load onto a trailer, then zip in half and stack on my 8' piles (then again I have a helper, heavier equipment and its my own wood/lumber)
Offline Sixacresand
  • John and Nancy
« Reply #3 on: April 28, 2016, 08:53:24 AM »
$350 and I provide an off bearer.
« Reply #4 on: April 28, 2016, 09:55:19 AM »
Not an option. To many people coming into the yard to pick up lumber, buy benches, birdhouses, etc. and dropping off logs.
Offline Hackermatack
« Reply #5 on: April 28, 2016, 12:32:25 PM »
I have a manual mill on a homemade trailer and really have no problem with logs up to 24" diameter & 16' long. I always try to set up with my logs on a good roll way that is about the same height as the mill, I also have a homemade turner powered by a 12 volt winch. The turner uses a hinged arm to lift the log and turn it from below rather than using a cable and a roll hitch like many do. I started out sawing on the ground and using my tractor to turn big stuff and hated it, waste too much time getting on and of the tractor. Your price is more than fair so maybe go up a little and spend some money to make things easier. Sounds like you saw in one location and have the logs trucked to you so some sort to live deck, a good turner, and a few rollers could ease the burden. Does not take many big fat 16'ers to make a good days pay.
Jonsered 2230, 590, 70E. Kioti DK 35 /w fransguard winch. Hudson Oscar 236
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #6 on: April 28, 2016, 12:40:16 PM »
Dave,
   Novel idea. Are you doing any mobile sawing or only at your site? I typically charge $.30/bf for good, normal logs or $60/hr for specialty sawing or small, short logs. No difference if hardwood or softwood. Nearly all mine is hardwood. Customer provides labor at those rate or $.35/bf I dead stack and $.40/bf if I stack and sticker. I'd rather just saw and let him provide labor. I don't get a lot of long logs and have never thought much about it. 16' is normally as long as my customers want although once in a while they will want a longer 2X8 or such for making a 20' beam or such. I'm not ready to change my rates for longer stuff right now.
   I have thought about a different rate for wide stuff that I sell. I am thinning a few poplars off my place and currently have a customer who wants nearly all 1X12 and first wanted them 16' long. Takes a big tree for me to provide that. Turned out he only needs 4-1X12X16's and okay if the rest are 8' 1X12's which are lots easier to provide. That still leaves me with the upper logs and such to cut for other customers. I don't like to store much lumber as I have no support equipment to handle it.
    If I get may more calls for buying wide lumber I may raise those rates. I like cutting long, wide boards if its the customer's logs.
Offline derhntr
  • Sawing lumber is addicting
« Reply #7 on: April 28, 2016, 02:23:31 PM »
I weighted the Pros and cons of BFT vs PH, as I seldom get good sized or quality logs I have went by the hour. Was $70 per hour with helper provided, thinking of bumping it up a little. Most of my customers are looking for widest boards so have not had to worry much on cutting to size. Last job I bucked logs to length, sawed fire wood with chain saw, cut down a Sassafras tree, quartered sawed larger trees. Cut stickers Never sat down and figured how many board feet cut. Would guess around 1000-1100 board feet. Billed job for 10 hours plus mill delivery fee. Would have lost if charged by board foot.
2006 Woodmizer LT40HDG28 with command control (I hate walking in sawdust)
US Army National Guard (RET) SFC
« Reply #8 on: April 28, 2016, 03:43:40 PM »
I am stationary. I do not travel.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #9 on: April 28, 2016, 04:06:39 PM »
i'd sure do it, make surcharges up for 14-16 and 18-20 feet.   Make 'em think twice about giving you long logs so they can cut the lumber in half & make sure you get paid for the extra work of handling both logs & lumber.
I dislike cutting long when I have to help handle the wood (not usually, except the edging).  Also cutting accurate gets more time consuming as length goes up.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline btulloh
« Reply #10 on: April 28, 2016, 04:09:58 PM »
Hackermatack, have you posted pictures or anything about your log turner?  I couldn't find anything and I'd like to see how you made it.
HM126
« Reply #11 on: April 28, 2016, 04:30:21 PM »
I have not posted any pictures of it or even taken any for that matter. Next time I saw, maybe tomorrow I will. Not doing much milling rite now but I have a couple of burls I want to carve up. I don't have anything big to put to show how it works but I think it is pretty easy to figure out. The winch that I run it with has a wireless remote which works great when I'm alone because I can work the log some with a peeve while operating the winch. I sawed some 18' pine this spring and some of them were a easy 24" top end I had a helper but could have done it alone, he ran the peeve while I ran the winch. Sawed a lot of 8 x 12's out of them when the were finished we just tipped them off the back side of the mill onto some skids and moved them with the tractor.
Offline scully
  • Orange Mills Matter
« Reply #12 on: April 28, 2016, 06:39:22 PM »
I have slowly but surely developed a price range . Mostly based on portable sawing . Length and over size 36+" I charge more sometime allot more . 350 a thousand for 12 and over is good but everything better be in order and plenty of help etc. If it's all on me and I need to hire help etc. I go up bye the nickle per BF  soft or hard wood . Hourly is good to but I usually save that rate for the disaster jobs.
I bleed orange  .
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #13 on: April 28, 2016, 07:30:17 PM »
An old engine lift with a winch on it makes for an easy log Turner.
Love machine shop work
and Wood work shop work
And now a saw mill work
« Reply #14 on: April 28, 2016, 07:40:50 PM »
.......and that calculates into how much per bf over 12 foot?
« Reply #15 on: April 28, 2016, 07:41:30 PM »
I think when you get out past 16' it falls into the specialty sawing category anyway. At least where I live lumber yards don't stock any lumber over 16' so you have to order ahead and pay a premium. As for good strait smooth 16' logs under 24" I like to saw them, takes the same amount of time to turn and dog a 16' as a 8. For me it is way ahead of 8' pole wood.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #16 on: April 28, 2016, 09:13:03 PM »
Many years ago, when I was sawing at something like 50 cent per bdft, I had a higher rater for short stuff, long stuff and other factors. But that higher rate was only 5 cents per bdft.
Then this customer came in with a load of firewood chunks and wanted some 5/4 out of it for flooring for some future barn.
It was very difficult to cut all these short small pieces.
I got pithed off and said never again for this short money.
So I raised my rates by half of what I get for anything shorter than 8' and longer than 16', as I can cut up to 22' with my 6' bed extension.
Now if they want the short stuff cut, I will do it but I get paid good for it.
It takes time to add a fence or deck to the mill in order to hold/clamp a short small piece.
Sometimes that fence board gets cut. Sometimes the deck board gets broken.
But I figure that I'm getting paid for these boards by charging the higher rate.
The carpenter from Boston who's cherry log I cut the other day, (and posted about it in the "what are you sawing" thread) said he had called another mill and told them it was 5' long. And they said that they wouldn't cut anything shorter then 8'. So I got that job because I would cut short stuff. But he paid for it.
Jim Rogers
« Reply #17 on: April 28, 2016, 09:16:40 PM »
Thanks Jim.  :)
« Reply #18 on: April 28, 2016, 09:34:43 PM »
Jim,
   With the short stuff I drop back to my hourly rate so I get compensated accordingly. That's what its for.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #19 on: April 28, 2016, 09:54:36 PM »
Maybe you could work out a linear foot price with the curve steepening as the lumber gets longer.  I know that the lumber yard prices are more per bf as the boards get longer.
sawing by the foot prices
Started by beav39 on Sawmills and Milling
Last post June 15, 2008, 12:23:54 AM
by Ironwood
sawing 25 foot logs
Started by gdingee on Sawmills and Milling
Last post July 02, 2009, 01:40:12 AM
by Brucer
Sawing my first 21 foot beams.
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 12, 2018, 11:18:10 PM
by Andries
$1.14 Per-Board-Foot Sawing Charge
Started by DR_Buck on Sawmills and Milling
Last post May 16, 2011, 08:41:07 AM
by paul case
